[PATCH] score: Add thread pin/unpin support
Wed Aug 29 12:25:10 UTC 2018
This is a proof of concept patch.  Support for clustered scheduling is
not implemented.
Update #3508.
 cpukit/include/rtems/score/scheduler.h             |  48 +++
 cpukit/include/rtems/score/scheduleredfsmp.h       |  33 ++-
 .../rtems/score/schedulerpriorityaffinitysmp.h     |   2 +
 cpukit/include/rtems/score/schedulerprioritysmp.h  |   4 +-
 cpukit/include/rtems/score/schedulersimplesmp.h    |   4 +-
 cpukit/include/rtems/score/schedulerstrongapa.h    |   4 +-
 cpukit/include/rtems/score/smpimpl.h               |   3 +-
 cpukit/include/rtems/score/thread.h                |  12 +
 cpukit/include/rtems/score/threadimpl.h            |  49 ++++
 cpukit/score/Makefile.am                           |   2 +
 cpukit/score/src/schedulerdefaultpinunpin.c        |  37 +++
 cpukit/score/src/scheduleredfsmp.c                 | 113 +++++--
 cpukit/score/src/threaddispatch.c                  |  57 +++-
 cpukit/score/src/threadunpin.c                     |  40 +++
 testsuites/smptests/Makefile.am                    |  11 +
 testsuites/smptests/configure.ac                   |   1 +
 testsuites/smptests/smpthreadpin01/init.c          | 323 +++++++++++++++++++++
 .../smptests/smpthreadpin01/smpthreadpin01.doc     |  12 +
 .../smptests/smpthreadpin01/smpthreadpin01.scn     |   7 +
 19 files changed, 729 insertions(+), 33 deletions(-)
 create mode 100644 cpukit/score/src/schedulerdefaultpinunpin.c
 create mode 100644 cpukit/score/src/threadunpin.c
 create mode 100644 testsuites/smptests/smpthreadpin01/init.c
 create mode 100644 testsuites/smptests/smpthreadpin01/smpthreadpin01.doc
 create mode 100644 testsuites/smptests/smpthreadpin01/smpthreadpin01.scn
diff --git a/cpukit/include/rtems/score/scheduler.h b/cpukit/include/rtems/score/scheduler.h
index a6066c8e4a..fe6315daef 100644
--- a/cpukit/include/rtems/score/scheduler.h
+++ b/cpukit/include/rtems/score/scheduler.h
@@ -137,6 +137,36 @@ typedef struct {
+   * @brief Pin thread operation.
+   * @param[in] scheduler The scheduler instance of the specified processor.
+   * @param[in] the_thread The thread to pin.
+   * @param[in] node The scheduler node of the thread.
+   * @param[in] cpu The processor to pin the thread.
+  void ( *pin )(
+    const Scheduler_Control *scheduler,
+    Thread_Control          *the_thread,
+    Scheduler_Node          *node,
+    struct Per_CPU_Control  *cpu
+   * @brief Unpin thread operation.
+   * @param[in] the_thread The thread to unpin.
+   * @param[in] cpu The processor to unpin the thread.
+  void ( *unpin )(
    * @brief Add processor operation.
    * @param[in] scheduler The scheduler instance to add the processor.
@@ -405,10 +435,28 @@ Priority_Control _Scheduler_default_Unmap_priority(
     Thread_Scheduler_state   next_state
+   * @brief Does nothing in a single processor system, otherwise a fatal error
+   * is issued.
+   * @param[in] scheduler Unused.
+   * @param[in] the_thread Unused.
+   * @param[in] node Unused.
+   * @param[in] cpu Unused.
+  void _Scheduler_default_Pin_or_unpin(
   #define SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP \
     _Scheduler_default_Ask_for_help, \
     _Scheduler_default_Reconsider_help_request, \
     _Scheduler_default_Withdraw_node, \
+    _Scheduler_default_Pin_or_unpin, \
     NULL, \
     NULL,
 #else
diff --git a/cpukit/include/rtems/score/scheduleredfsmp.h b/cpukit/include/rtems/score/scheduleredfsmp.h
index 018568190e..72c906eefe 100644
--- a/cpukit/include/rtems/score/scheduleredfsmp.h
+++ b/cpukit/include/rtems/score/scheduleredfsmp.h
@@ -7,7 +7,7 @@
- * Copyright (c) 2017 embedded brains GmbH.
+ * Copyright (c) 2017, 2018 embedded brains GmbH.
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
@@ -43,13 +43,24 @@ typedef struct {
   int64_t generation;
-   * @brief The ready queue index depending on the processor affinity of the thread.
+   * @brief The ready queue index depending on the processor affinity and
+   * pinning of the thread.
    * The ready queue index zero is used for threads with a one-to-all thread
    * processor affinity.  Threads with a one-to-one processor affinity use the
    * processor index plus one as the ready queue index.
-  uint32_t ready_queue_index;
+  uint8_t ready_queue_index;
+   * @brief Ready queue index according to thread affinity.
+  uint8_t affinity_ready_queue_index;
+   * @brief Ready queue index according to thread pinning.
+  uint8_t pinning_ready_queue_index;
 } Scheduler_EDF_SMP_Node;
 typedef struct {
@@ -105,6 +116,8 @@ typedef struct {
     _Scheduler_EDF_SMP_Ask_for_help, \
     _Scheduler_EDF_SMP_Reconsider_help_request, \
     _Scheduler_EDF_SMP_Withdraw_node, \
+    _Scheduler_EDF_SMP_Pin, \
+    _Scheduler_EDF_SMP_Unpin, \
     _Scheduler_EDF_SMP_Add_processor, \
     _Scheduler_EDF_SMP_Remove_processor, \
     _Scheduler_EDF_SMP_Node_initialize, \
@@ -162,6 +175,20 @@ void _Scheduler_EDF_SMP_Withdraw_node(
+void _Scheduler_EDF_SMP_Pin(
+void _Scheduler_EDF_SMP_Unpin(
 void _Scheduler_EDF_SMP_Add_processor(
   Thread_Control          *idle
diff --git a/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
index d988d5752a..e8ee528c90 100644
--- a/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
+++ b/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
@@ -61,6 +61,8 @@ extern "C" {
     _Scheduler_priority_affinity_SMP_Ask_for_help, \
     _Scheduler_priority_affinity_SMP_Reconsider_help_request, \
     _Scheduler_priority_affinity_SMP_Withdraw_node, \
     _Scheduler_priority_affinity_SMP_Add_processor, \
     _Scheduler_priority_affinity_SMP_Remove_processor, \
     _Scheduler_priority_affinity_SMP_Node_initialize, \
diff --git a/cpukit/include/rtems/score/schedulerprioritysmp.h b/cpukit/include/rtems/score/schedulerprioritysmp.h
index 6671da5b7a..7d579f1846 100644
--- a/cpukit/include/rtems/score/schedulerprioritysmp.h
+++ b/cpukit/include/rtems/score/schedulerprioritysmp.h
@@ -7,7 +7,7 @@
- * Copyright (c) 2013, 2016 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2013, 2018 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -89,6 +89,8 @@ typedef struct {
     _Scheduler_priority_SMP_Ask_for_help, \
     _Scheduler_priority_SMP_Reconsider_help_request, \
     _Scheduler_priority_SMP_Withdraw_node, \
     _Scheduler_priority_SMP_Add_processor, \
     _Scheduler_priority_SMP_Remove_processor, \
     _Scheduler_priority_SMP_Node_initialize, \
diff --git a/cpukit/include/rtems/score/schedulersimplesmp.h b/cpukit/include/rtems/score/schedulersimplesmp.h
index bc75b205d5..d9b4c1d46c 100644
--- a/cpukit/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/include/rtems/score/schedulersimplesmp.h
@@ -9,7 +9,7 @@
  *  Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
@@ -72,6 +72,8 @@ typedef struct {
     _Scheduler_simple_SMP_Ask_for_help, \
     _Scheduler_simple_SMP_Reconsider_help_request, \
     _Scheduler_simple_SMP_Withdraw_node, \
     _Scheduler_simple_SMP_Add_processor, \
     _Scheduler_simple_SMP_Remove_processor, \
     _Scheduler_simple_SMP_Node_initialize, \
diff --git a/cpukit/include/rtems/score/schedulerstrongapa.h b/cpukit/include/rtems/score/schedulerstrongapa.h
index d961f20c68..bc113197e7 100644
--- a/cpukit/include/rtems/score/schedulerstrongapa.h
+++ b/cpukit/include/rtems/score/schedulerstrongapa.h
@@ -7,7 +7,7 @@
  *  Dornierstr. 4
     _Scheduler_strong_APA_Ask_for_help, \
     _Scheduler_strong_APA_Reconsider_help_request, \
     _Scheduler_strong_APA_Withdraw_node, \
     _Scheduler_strong_APA_Add_processor, \
     _Scheduler_strong_APA_Remove_processor, \
     _Scheduler_strong_APA_Node_initialize, \
diff --git a/cpukit/include/rtems/score/smpimpl.h b/cpukit/include/rtems/score/smpimpl.h
index 75d36ac865..532e5a6b4e 100644
--- a/cpukit/include/rtems/score/smpimpl.h
+++ b/cpukit/include/rtems/score/smpimpl.h
@@ -79,7 +79,8 @@ typedef enum {
   SMP_FATAL_MULTITASKING_START_ON_UNASSIGNED_PROCESSOR,
   SMP_FATAL_SHUTDOWN,
   SMP_FATAL_SHUTDOWN_RESPONSE,
-  SMP_FATAL_START_OF_MANDATORY_PROCESSOR_FAILED
+  SMP_FATAL_START_OF_MANDATORY_PROCESSOR_FAILED,
+  SMP_FATAL_SCHEDULER_PIN_OR_UNPIN_NOT_SUPPORTED
 } SMP_Fatal_code;
 static inline void _SMP_Fatal( SMP_Fatal_code code )
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index 7e0e2722dd..4c1b1b542d 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -313,6 +313,18 @@ typedef struct {
   Scheduler_Node *requests;
+   * @brief The thread pinning to a processor level.
+   * Must be touched only by the executing thread with thread dispatching
+   * disabled.  If non-zero, then the thread is pinned to its current
+   * processor.  The pin level is incremented and decremented by two.  The
+   * least-significant bit indicates that the thread was pre-empted and must
+   * undo the pinning with respect to the scheduler once the level changes from
+   * three to one.
+  unsigned int pin_level;
    * @brief The thread processor affinity set.
   Processor_mask Affinity;
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index 4ab855d3ff..9f9475d9fd 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -1953,6 +1953,55 @@ size_t _Thread_Get_name(
   size_t                buffer_size
+#if defined(RTEMS_SMP)
+#define THREAD_PIN_STEP 2
+#define THREAD_PIN_PREEMPTION 1
+void _Thread_Do_unpin(
+  Thread_Control  *executing,
+  Per_CPU_Control *cpu_self
+#endif
+RTEMS_INLINE_ROUTINE void _Thread_Pin( Thread_Control *executing )
+  _Assert( executing == _Thread_Executing );
+  executing->Scheduler.pin_level += THREAD_PIN_STEP;
+#else
+  (void) executing;
+#endif
+RTEMS_INLINE_ROUTINE void _Thread_Unpin(
+  pin_level = executing->Scheduler.pin_level;
+  if (
+    RTEMS_PREDICT_TRUE(
+      pin_level != ( THREAD_PIN_STEP | THREAD_PIN_PREEMPTION )
+    executing->Scheduler.pin_level = pin_level - THREAD_PIN_STEP;
+  } else {
+    _Thread_Do_unpin( executing, cpu_self );
+#else
+  (void) executing;
+  (void) cpu_self;
+#endif
 #ifdef __cplusplus
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index e345f77daa..cdd9740d41 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -26,6 +26,7 @@ endif
 if HAS_SMP
 libscore_a_SOURCES += src/percpustatewait.c
 libscore_a_SOURCES += src/profilingsmplock.c
+libscore_a_SOURCES += src/schedulerdefaultpinunpin.c
 libscore_a_SOURCES += src/scheduleredfsmp.c
 libscore_a_SOURCES += src/schedulerpriorityaffinitysmp.c
 libscore_a_SOURCES += src/schedulerprioritysmp.c
@@ -38,6 +39,7 @@ libscore_a_SOURCES += src/schedulerdefaultaskforhelp.c
 libscore_a_SOURCES += src/schedulerdefaultsetaffinity.c
 libscore_a_SOURCES += src/schedulersmp.c
 libscore_a_SOURCES += src/schedulersmpstartidle.c
+libscore_a_SOURCES += src/threadunpin.c
 endif
 ## CORE_APIMUTEX_C_FILES
diff --git a/cpukit/score/src/schedulerdefaultpinunpin.c b/cpukit/score/src/schedulerdefaultpinunpin.c
new file mode 100644
index 0000000000..19bb4e1827
--- /dev/null
+++ b/cpukit/score/src/schedulerdefaultpinunpin.c
@@ -0,0 +1,37 @@
+ * Copyright (c) 2018 embedded brains GmbH
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/scheduler.h>
+#include <rtems/score/interr.h>
+#include <rtems/score/smpimpl.h>
+void _Scheduler_default_Pin_or_unpin(
+  (void) scheduler;
+  (void) the_thread;
+  (void) node;
+  (void) cpu;
+#ifdef RTEMS_SMP
+  if ( _SMP_Get_processor_count() > 1 ) {
+    _Terminate(
+      RTEMS_FATAL_SOURCE_SMP,
+#endif
diff --git a/cpukit/score/src/scheduleredfsmp.c b/cpukit/score/src/scheduleredfsmp.c
index 0980a336cc..315ba35fbb 100644
--- a/cpukit/score/src/scheduleredfsmp.c
+++ b/cpukit/score/src/scheduleredfsmp.c
@@ -143,7 +143,7 @@ static inline Scheduler_Node *_Scheduler_EDF_SMP_Get_highest_ready(
   Scheduler_EDF_SMP_Context *self;
   Scheduler_EDF_SMP_Node    *highest_ready;
   Scheduler_EDF_SMP_Node    *node;
-  uint32_t                   rqi;
+  uint8_t                    rqi;
   const Chain_Node          *tail;
   Chain_Node                *next;
@@ -199,7 +199,7 @@ static inline void _Scheduler_EDF_SMP_Set_scheduled(
 static inline Scheduler_EDF_SMP_Node *_Scheduler_EDF_SMP_Get_scheduled(
   const Scheduler_EDF_SMP_Context *self,
-  uint32_t                         rqi
+  uint8_t                          rqi
   return self->Ready[ rqi ].scheduled;
@@ -211,7 +211,7 @@ static inline Scheduler_Node *_Scheduler_EDF_SMP_Get_lowest_scheduled(
   Scheduler_EDF_SMP_Node *filter;
-  uint32_t                rqi;
+  uint8_t                 rqi;
   filter = _Scheduler_EDF_SMP_Node_downcast( filter_base );
   rqi = filter->ready_queue_index;
@@ -240,7 +240,7 @@ static inline void _Scheduler_EDF_SMP_Insert_ready(
-  uint32_t                       rqi;
+  uint8_t                        rqi;
   Scheduler_EDF_SMP_Ready_queue *ready_queue;
   int                            generation_index;
   int                            increment;
@@ -283,7 +283,7 @@ static inline void _Scheduler_EDF_SMP_Extract_from_ready(
-  uint32_t                       rqi;
+  uint8_t                        rqi;
   self = _Scheduler_EDF_SMP_Get_self( context );
@@ -346,7 +346,7 @@ static inline void _Scheduler_EDF_SMP_Allocate_processor(
   Scheduler_EDF_SMP_Node        *scheduled;
-  uint32_t                       rqi;
+  uint8_t                        rqi;
   (void) victim_base;
@@ -623,7 +623,7 @@ static inline void _Scheduler_EDF_SMP_Do_set_affinity(
-  const uint32_t         *rqi;
+  const uint8_t          *rqi;
   node = _Scheduler_EDF_SMP_Node_downcast( node_base );
   rqi = arg;
@@ -648,16 +648,78 @@ void _Scheduler_EDF_SMP_Start_idle(
+  Thread_Control          *thread,
+  Scheduler_Node          *node_base,
+  Scheduler_Context      *context;
+  Scheduler_EDF_SMP_Node *node;
+  uint8_t                 rqi;
+  context = _Scheduler_Get_context( scheduler );
+  rqi = (uint8_t) _Per_CPU_Get_index( cpu ) + 1;
+  node = _Scheduler_EDF_SMP_Node_downcast( node_base );
+  node->pinning_ready_queue_index = rqi;
+  _Scheduler_SMP_Set_affinity(
+    context,
+    thread,
+    node_base,
+    &rqi,
+    _Scheduler_EDF_SMP_Do_set_affinity,
+    _Scheduler_EDF_SMP_Extract_from_ready,
+    _Scheduler_EDF_SMP_Get_highest_ready,
+    _Scheduler_EDF_SMP_Move_from_ready_to_scheduled,
+    _Scheduler_EDF_SMP_Enqueue,
+    _Scheduler_EDF_SMP_Allocate_processor
+  (void) cpu;
+  node->pinning_ready_queue_index = 0;
+    context,
+    thread,
+    node_base,
+    &node->affinity_ready_queue_index,
 bool _Scheduler_EDF_SMP_Set_affinity(
-  Scheduler_Node          *node,
   const Processor_mask    *affinity
-  Scheduler_Context *context;
-  Processor_mask     local_affinity;
-  uint32_t           rqi;
+  Processor_mask          local_affinity;
+  uint8_t                 rqi;
   _Processor_mask_And( &local_affinity, &context->Processors, affinity );
@@ -672,18 +734,23 @@ bool _Scheduler_EDF_SMP_Set_affinity(
     rqi = _Processor_mask_Find_last_set( &local_affinity );
-  _Scheduler_SMP_Set_affinity(
-    context,
-    thread,
-    node,
-    &rqi,
-    _Scheduler_EDF_SMP_Do_set_affinity,
-    _Scheduler_EDF_SMP_Extract_from_ready,
-    _Scheduler_EDF_SMP_Get_highest_ready,
-    _Scheduler_EDF_SMP_Move_from_ready_to_scheduled,
-    _Scheduler_EDF_SMP_Enqueue,
-    _Scheduler_EDF_SMP_Allocate_processor
+  node->affinity_ready_queue_index = rqi;
+  if ( node->pinning_ready_queue_index == 0 ) {
+      context,
+      thread,
+      node_base,
+      &rqi,
   return true;
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index d6207bc898..4693fafa7a 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -9,7 +9,7 @@
  *  COPYRIGHT (c) 1989-2009.
  *  On-Line Applications Research Corporation (OAR).
- *  Copyright (c) 2014, 2016 embedded brains GmbH.
+ *  Copyright (c) 2014, 2018 embedded brains GmbH.
@@ -37,6 +37,49 @@ Thread_Control *_Thread_Allocated_fp;
 CHAIN_DEFINE_EMPTY( _User_extensions_Switches_list );
+static ISR_Level _Thread_Check_pinning(
+  Per_CPU_Control *cpu_self,
+  ISR_Level        level
+  if (
+    RTEMS_PREDICT_FALSE( pin_level != 0 )
+      && ( pin_level & THREAD_PIN_PREEMPTION ) == 0
+    ISR_lock_Context         lock_context;
+    ISR_lock_Context         lock_context_2;
+    const Scheduler_Control *scheduler;
+    Scheduler_Node          *node;
+    _ISR_Local_enable( level );
+    executing->Scheduler.pin_level = pin_level | THREAD_PIN_PREEMPTION;
+    scheduler = _Scheduler_Get_by_CPU( cpu_self );
+    node = _Thread_Scheduler_get_node_by_index(
+      executing,
+      _Scheduler_Get_index( scheduler )
+    _Thread_State_acquire( executing, &lock_context );
+    _Scheduler_Acquire_critical( scheduler, &lock_context_2 );
+    ( *scheduler->Operations.pin )( scheduler, executing, node, cpu_self );
+    _Scheduler_Release_critical( scheduler, &lock_context_2 );
+    _Thread_State_release( executing, &lock_context );
+    _ISR_Local_disable( level );
+  return level;
 static void _Thread_Ask_for_help( Thread_Control *the_thread )
   Chain_Node       *node;
@@ -77,9 +120,15 @@ static bool _Thread_Can_ask_for_help( const Thread_Control *executing )
 #endif
-static void _Thread_Preemption_intervention( Per_CPU_Control *cpu_self )
+static ISR_Level _Thread_Preemption_intervention(
+  ISR_Level        level
+  level = _Thread_Check_pinning( executing, cpu_self, level );
   _Per_CPU_Acquire( cpu_self );
   while ( !_Chain_Is_empty( &cpu_self->Threads_in_need_for_help ) ) {
@@ -102,6 +151,8 @@ static void _Thread_Preemption_intervention( Per_CPU_Control *cpu_self )
 #else
   (void) cpu_self;
 #endif
+  return level;
 static void _Thread_Post_switch_cleanup( Thread_Control *executing )
@@ -192,7 +243,7 @@ void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
   do {
     Thread_Control *heir;
-    _Thread_Preemption_intervention( cpu_self );
+    level = _Thread_Preemption_intervention( executing, cpu_self, level );
     heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
diff --git a/cpukit/score/src/threadunpin.c b/cpukit/score/src/threadunpin.c
index 0000000000..21b52824bd
--- /dev/null
+++ b/cpukit/score/src/threadunpin.c
@@ -0,0 +1,40 @@
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/score/schedulerimpl.h>
+  executing->Scheduler.pin_level = 0;
+    executing,
+  _Thread_State_acquire_critical( executing, &lock_context );
+  ( *scheduler->Operations.unpin )( scheduler, executing, node, cpu_self );
+  _Thread_State_release_critical( executing, &lock_context );
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index f0096b8eba..246e399c20 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -633,6 +633,17 @@ endif
 endif
 if HAS_SMP
+if TEST_smpthreadpin01
+smp_tests += smpthreadpin01
+smp_screens += smpthreadpin01/smpthreadpin01.scn
+smp_docs += smpthreadpin01/smpthreadpin01.doc
+smpthreadpin01_SOURCES = smpthreadpin01/init.c
+smpthreadpin01_CPPFLAGS = $(AM_CPPFLAGS) \
+	$(TEST_FLAGS_smpthreadpin01) $(support_includes)
+endif
+endif
+if HAS_SMP
 if TEST_smpunsupported01
 smp_tests += smpunsupported01
 smp_screens += smpunsupported01/smpunsupported01.scn
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index e14149be5e..873e4b6c13 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -88,6 +88,7 @@ RTEMS_TEST_CHECK([smpsignal01])
 RTEMS_TEST_CHECK([smpstrongapa01])
 RTEMS_TEST_CHECK([smpswitchextension01])
 RTEMS_TEST_CHECK([smpthreadlife01])
+RTEMS_TEST_CHECK([smpthreadpin01])
 RTEMS_TEST_CHECK([smpunsupported01])
 RTEMS_TEST_CHECK([smpwakeafter01])
diff --git a/testsuites/smptests/smpthreadpin01/init.c b/testsuites/smptests/smpthreadpin01/init.c
index 0000000000..7ec996b4e2
--- /dev/null
+++ b/testsuites/smptests/smpthreadpin01/init.c
@@ -0,0 +1,323 @@
+ * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+#endif
+#include <rtems.h>
+#include <rtems/score/threadimpl.h>
+#include <tmacros.h>
+const char rtems_test_name[] = "SMPTHREADPIN 1";
+typedef struct {
+  rtems_id master;
+  rtems_id event;
+  rtems_id help;
+  rtems_id busy;
+  int counter;
+} test_context;
+static test_context test_instance;
+static void set_affinity(rtems_id task, uint32_t cpu_index)
+  rtems_status_code sc;
+  cpu_set_t set;
+  CPU_ZERO(&set);
+  CPU_SET((int) cpu_index, &set);
+  sc = rtems_task_set_affinity(task, sizeof(set), &set);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+static void suspend(rtems_id task)
+  sc = rtems_task_suspend(task);
+static rtems_task_priority set_prio(rtems_id id, rtems_task_priority prio)
+  rtems_task_priority old_prio;
+  old_prio = 0xffffffff;
+  sc = rtems_task_set_priority(id, prio, &old_prio);
+  return old_prio;
+static void send_event(rtems_id task, rtems_event_set event)
+  sc = rtems_event_send(task, event);
+static rtems_event_set wait_for_events(void)
+  rtems_event_set events;
+  sc = rtems_event_receive(
+    RTEMS_ALL_EVENTS,
+    RTEMS_EVENT_ANY | RTEMS_WAIT,
+    RTEMS_NO_TIMEOUT,
+    &events
+  return events;
+static void checkpoint(test_context *ctx, int expected_counter)
+  rtems_test_assert(ctx->counter == expected_counter);
+  ctx->counter = expected_counter + 1;
+static void event_task(rtems_task_argument arg)
+  test_context *ctx;
+  ctx = (test_context *) arg;
+  while (true) {
+    events = wait_for_events();
+    if ((events & RTEMS_EVENT_0) != 0) {
+      send_event(ctx->master, RTEMS_EVENT_0);
+    if ((events & RTEMS_EVENT_1) != 0) {
+      send_event(ctx->help, RTEMS_EVENT_1);
+static void help_task(rtems_task_argument arg)
+  rtems_task_priority prio;
+  checkpoint(ctx, 0);
+  prio = set_prio(ctx->master, 3);
+  rtems_test_assert(prio == 5);
+  wait_for_events();
+  checkpoint(ctx, 2);
+  prio = set_prio(ctx->busy, 6);
+  rtems_test_assert(prio == 2);
+  set_affinity(ctx->busy, 1);
+  set_affinity(ctx->event, 0);
+  send_event(ctx->event, RTEMS_EVENT_1);
+  prio = set_prio(ctx->busy, 8);
+  rtems_test_assert(prio == 6);
+  set_affinity(ctx->busy, 0);
+  set_affinity(ctx->master, 0);
+  checkpoint(ctx, 4);
+  suspend(RTEMS_SELF);
+static void busy_task(rtems_task_argument arg)
+  (void) arg;
+#if CPU_PROVIDES_IDLE_THREAD_BODY == TRUE
+  _CPU_Thread_Idle_body(0);
+#else
+  while (true) {
+    /* Do nothing */
+#endif
+static void simple_pin_unpin(void)
+  Per_CPU_Control *cpu_self;
+  Thread_Control *executing;
+  rtems_test_assert(rtems_get_current_processor() == 1);
+  cpu_self = _Thread_Dispatch_disable();
+  executing = _Per_CPU_Get_executing(cpu_self);
+  _Thread_Pin(executing);
+  _Thread_Unpin(executing, cpu_self);
+  _Thread_Dispatch_enable(cpu_self);
+static void pin_wait_unpin(test_context *ctx)
+  send_event(ctx->help, RTEMS_EVENT_0);
+  checkpoint(ctx, 3);
+static void pin_preempt_unpin(test_context *ctx)
+  prio = set_prio(RTEMS_SELF, 7);
+  rtems_test_assert(prio == 3);
+  checkpoint(ctx, 5);
+  rtems_test_assert(rtems_get_current_processor() == 0);
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  ctx = &test_instance;
+  ctx->master = rtems_task_self();
+  sc = rtems_task_create(
+    rtems_build_name('B', 'U', 'S', 'Y'),
+    2,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &ctx->busy
+  sc = rtems_task_start(ctx->busy, busy_task, (rtems_task_argument) ctx);
+    rtems_build_name('E', 'V', 'N', 'T'),
+    6,
+    &ctx->event
+  set_affinity(ctx->event, 1);
+  sc = rtems_task_start(ctx->event, event_task, (rtems_task_argument) ctx);
+  send_event(ctx->event, RTEMS_EVENT_0);
+    rtems_build_name('H', 'E', 'L', 'P'),
+    4,
+    &ctx->help
+  set_affinity(ctx->help, 1);
+  sc = rtems_task_start(ctx->help, help_task, (rtems_task_argument) ctx);
+  prio = set_prio(RTEMS_SELF, 5);
+  checkpoint(ctx, 1);
+  simple_pin_unpin();
+  pin_wait_unpin(ctx);
+  pin_preempt_unpin(ctx);
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_PROCESSORS 2
+#define CONFIGURE_MAXIMUM_TASKS 4
+#define CONFIGURE_INIT_TASK_PRIORITY 3
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpthreadpin01/smpthreadpin01.doc b/testsuites/smptests/smpthreadpin01/smpthreadpin01.doc
index 0000000000..23d2f165ea
--- /dev/null
+++ b/testsuites/smptests/smpthreadpin01/smpthreadpin01.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpthreadpin01
+directives:
+  - _Thread_Pin()
+  - _Thread_Unpin()
+concepts:
+  - Ensure that the thread to processor pinning works.
diff --git a/testsuites/smptests/smpthreadpin01/smpthreadpin01.scn b/testsuites/smptests/smpthreadpin01/smpthreadpin01.scn
index 0000000000..c76bfb1f1a
--- /dev/null
+++ b/testsuites/smptests/smpthreadpin01/smpthreadpin01.scn
@@ -0,0 +1,7 @@
+*** BEGIN OF TEST SMPTHREADPIN 1 ***
+*** TEST VERSION: 5.0.0.df0321fdc51b7488b03584abcb72d1883c8cbbcb
+*** TEST STATE: EXPECTED-PASS
+*** TEST BUILD: RTEMS_SMP
+*** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB 9670d7541e0621915e521fe76e7bb33de8cee661, Newlib d13c84eb07e35984bf7a974cd786a6cdac29e6b9)
+*** END OF TEST SMPTHREADPIN 1 ***
2.13.7
