[PATCH 00/17] Warning Fix Series
Joel Sherrill
joel at rtems.org
Wed Aug 29 20:15:13 UTC 2018
Hi
This is a series of warnings spotted using GCC 8 and
a build of GCC from the master which turned some of
these as errors.
We are down to 88 unique warnings after this round of
fixes.
Joel Sherrill (17):
bsps/m68k/shared/cache/cache.h: Fix warnings and clean up
cpukit/telnetd/pty.c: Fix format overflow warning on sprintf()
gdbarmsim/include/bsp.h: Fix warnings
bsps/i386/shared/cache/cache.c: Fix warnings
gen5200/include/bsp/bestcomm.h: Fix unused variable warning
mpc55xxevb/clock/clock-config.c: Remove unused mpc55xx_clock_cleanup()
method
gen5200/include/tm27.h: Fix warnings
qoriq/include/tm27.h: Fix warnings
monlib.[ch]: Fix warnings for external vs internal use of .h
lpc32xx/include/bsp.h: Resolve set but not used warning
gen68340/include/m340timer.h: Fix not a prototype warnings
uC5282/clock/clock.c: Correct bsp_idle_thread() prototype
mvme5500/include/tm27.h: Fix not a prototype warnings
psim/include/tm27.h: Fix not a prototype warnings
score/cpu/bfin/cpu.c: Fix _CPU_Thread_Idle_body() prototype
rtems/score/epiphany-utility.h: Fix not a prototype warning
Remove bsps/sparc64/shared/helenos/boot/generic/string.c
bsps/arm/csb337/umon/monlib.c | 1 +
bsps/arm/gdbarmsim/include/bsp.h | 6 +-
bsps/arm/lpc32xx/include/bsp.h | 1 +
bsps/i386/shared/cache/cache.c | 22 +--
bsps/include/umon/monlib.h | 12 +-
bsps/m68k/gen68340/include/m340timer.h | 8 +-
bsps/m68k/shared/cache/cache.h | 81 ++++----
bsps/m68k/uC5282/clock/clock.c | 2 +-
bsps/powerpc/gen5200/include/bsp/bestcomm.h | 3 +
bsps/powerpc/gen5200/include/tm27.h | 9 +-
bsps/powerpc/mpc55xxevb/clock/clock-config.c | 10 -
bsps/powerpc/mvme5500/include/tm27.h | 4 +-
bsps/powerpc/psim/include/tm27.h | 8 +-
bsps/powerpc/qoriq/include/tm27.h | 10 +-
bsps/sparc64/shared/helenos/boot/generic/string.c | 211 ---------------------
c/src/lib/libbsp/sparc64/niagara/Makefile.am | 1 -
c/src/lib/libbsp/sparc64/usiii/Makefile.am | 1 -
cpukit/score/cpu/bfin/cpu.c | 2 +-
.../include/rtems/score/epiphany-utility.h | 2 +-
cpukit/telnetd/pty.c | 11 +-
20 files changed, 88 insertions(+), 317 deletions(-)
delete mode 100644 bsps/sparc64/shared/helenos/boot/generic/string.c
1.8.3.1
