Version of FreeBSD for libbsd
Joel Sherrill
joel at rtems.org
Sun Aug 5 17:21:40 UTC 2018
On Sun, Aug 5, 2018, 8:59 AM Christian Mauderer <list at c-mauderer.de> wrote:
> Am 03.08.2018 um 19:30 schrieb Joel Sherrill:
> > Hi
> > libbsd.txt says this is based on FreeBSD 9.2 but I thought it
> > had been updated past that.
> > Also how could I have figured this out otherwise?
> > If it matters, there are also man pages references to FreeBSD 9.2.
> > And is the Changes up to date? It has a date of 2017?
> > Thanks.
> > --joel
> Hello Joel,
> since we have a single release for all sources since about one year, the
> simplest method to find out which release is used is to take a look at
> the freebsd-org submodule. Currently that's revision 642b174da of the
> FreeBSD git mirror which is from 2017-04-04.
> So it should be something between 11 and 12.
Then what do you recommend the phrase be in the libbsd.txt since it says 9
right now.
And should the man page links be updated? I know they rarely change but...
Thanks.
> Best regards
> Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180805/372ec36b/attachment-0002.html>
