Disable libnetwork on Epiphany?
Chris Johns
chrisj at rtems.org
Thu Aug 16 03:24:35 UTC 2018
> On 16 Aug 2018, at 3:31 am, Joel Sherrill <joel at rtems.org> wrote:
>> On Tue, Aug 14, 2018 at 4:26 AM, Hesham Almatary <heshamelmatary at gmail.com> wrote:
>> On Tue, Aug 14, 2018 at 10:17 AM, Joel Sherrill <joel at rtems.org> wrote:
>> > On Tue, Aug 14, 2018, 2:51 AM Hesham Almatary <heshamelmatary at gmail.com>
>> > wrote:
>> >> AFAIR, I've never tried epiphany with networking. The cores are
>> >> supposed to be accelerators, so the ARM core can offload some
>> >> processing to it.
>> >> P.S. aren't we gonna make Epiphany obsolete? The discussion was
>> >> raised by Sebastian before to remove Epiphany support.
>> > I recalled or1k and not epiphany.
>> Yes you're right
> And FWIW the epiphany bsp builder configuration is building networking
> and I don't think it should. I couldn't find the magic syntax to tell it not to
> try since it already is noted as excluding smp.
> Any ideas on that? I am hoping it doesn't take Chris to step in. :)
I think there is a ticket.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180816/09fe4503/attachment-0002.html>
