[PATCH] user: Update x86-64 chapter with end-of-GSoC status
Joel Sherrill
joel at rtems.org
Mon Aug 20 22:05:47 UTC 2018
This should be committed now.
Thanks.
On Mon, Aug 20, 2018 at 9:27 AM, Amaan Cheval <amaan.cheval at gmail.com>
wrote:
> user/bsps/bsps-x86_64.rst | 52 ++++++++++++++++++++++++++++++++++++++-
> 1 file changed, 51 insertions(+), 1 deletion(-)
> diff --git a/user/bsps/bsps-x86_64.rst b/user/bsps/bsps-x86_64.rst
> index 19c4461..c13f369 100644
> --- a/user/bsps/bsps-x86_64.rst
> +++ b/user/bsps/bsps-x86_64.rst
> @@ -136,10 +136,60 @@ After rebooting, the RTEMS kernel should run after
> the UEFI firmware and
> FreeBSD's bootloader. The ``-serial stdio`` QEMU flag will let the RTEMS
> console
> send its output to the host's ``stdio`` stream.
> +Paging
> +During the BSP's initialization, the paging tables are setup to
> identity-map the
> +first 512GiB, i.e. virtual addresses are the same as physical addresses
> for the
> +first 512GiB.
> +The page structures are set up statically with 1GiB super-pages.
> +.. note::
> + Page-faults are not handled.
> +.. warning::
> + RAM size is not detected dynamically and defaults to 1GiB, if the
> + configuration-time ``RamSize`` parameter is not used.
> +Interrupt Setup
> +Interrupt vectors ``0`` through ``32`` (i.e. 33 interrupt vectors in
> total) are
> +setup as "RTEMS interrupts", which can be hooked through
> +``rtems_interrupt_handler_install``.
> +The Interrupt Descriptor Table supports a total of 256 possible vectors (0
> +through 255), which leaves a lot of room for "raw interrupts", which can
> be
> +hooked through ``_CPU_ISR_install_raw_handler``.
> +Since the APIC needs to be used for the clock driver, the PIC is remapped
> (IRQ0
> +of the PIC is redirected to vector 32, and so on), and then all
> interrupts are
> +masked to disable the PIC. In this state, the PIC may _still_ produce
> spurious
> +interrupts (IRQ7 and IRQ15, redirected to vector 39 and vector 47
> respectively).
> +The clock driver triggers the initialization of the APIC and then the APIC
> +timer.
> +The I/O APIC is not supported at the moment.
> +.. note::
> + IRQ32 is reserved by default for the APIC timer (see following section).
> + IRQ255 is reserved by default for the APIC's spurious vector.
> +.. warning::
> + Besides the first 33 vectors (0 through 32), and vector 255 (the APIC
> spurious
> + vector), no other handlers are attached by default.
> Clock Driver
> -The clock driver currently uses the idle thread clock driver.
> +The clock driver currently uses the APIC timer. Since the APIC timer runs
> at the
> +CPU bus frequency, which can't be detected easily, the PIT is used to
> calibrate
> +the APIC timer, and then the APIC timer is enabled in periodic mode, with
> the
> +initial counter setup such that interrupts fire at the same frequency as
> the
> +clock tick frequency, as requested by ``CONFIGURE_MICROSECONDS_PER_
> TICK``.
> Console Driver
> 2.18.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180820/9650cc71/attachment-0002.html>
