Implement POSIX API Signature Compliance Tests for arpa/inet.h File
Joel Sherrill
joel at rtems.org
Sat Dec 1 15:46:44 UTC 2018
Yes. The structure of the psxhdrs directory is intended to mirror that of
the header files themselves.
So the directory should be arpa/inet.
This .h file for RTEMS is part of the tools, not part of RTEMS. This is
true for most POSIX .h file.
--joel
On Sat, Dec 1, 2018 at 8:43 AM Abhimanyu Raghuvanshi <
abhimanyuraghuvanshi29 at gmail.com> wrote:
> Ah thanks again, I will make sure to look at it again
> 送られた ABR2908
> On Sat, Dec 1, 2018 at 8:02 PM Shashvat Jain <shashvatjain2002 at gmail.com>
> wrote:
>> Hello Abhimanyu,
>> I think we will have to create a directory arpa/inet inside the psxhdrs
>> directory
>> The inet.h file is very much present there , please run the command "man
>> inet" or "man inet.h" inside your rtems source tree ,
>> you will get a synopsis about the functions related to this header file.
>> This is the development mailing list for rtems , here you may ask about
>> speculated bugs or bugfixes and development patches
>> , I would suggest you to ask questions on the gci at rtems.org .
>> Actually i am doing the same task :)
>> PS: Mentors , the instructions of this type of tasks need to be updated
>> , they are unclear.
>> Thank you
>> Regards
>> --Shashvat
>> On Sat, Dec 1, 2018 at 6:54 PM Abhimanyu Raghuvanshi <
>>> I cant find inet.h file in the Directory, if someone else could, let me
>>> know the location please
>>> 送られた ABR2908
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181201/a022dadc/attachment.html>
