[PATCH] Fix wrong command hint in case of error
kaidoho kho237115 at gmail.com
Sun Dec 2 14:36:39 UTC 2018
 aclocal/enable-rtemsbsp.m4 | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/aclocal/enable-rtemsbsp.m4 b/aclocal/enable-rtemsbsp.m4
index 91ab607751..f0b391bbb8 100644
--- a/aclocal/enable-rtemsbsp.m4
+++ b/aclocal/enable-rtemsbsp.m4
@@ -38,7 +38,7 @@ AC_ARG_ENABLE(rtemsbsp,
              ${cfg_arch}* )
-               AC_MSG_ERROR([BSP '$bsp' architecture does not match the --target architecture, run 'rtems-bsp' (in the top of the source tree) for a valid BSP list])
+               AC_MSG_ERROR([BSP '$bsp' architecture does not match the --target architecture, run 'rtems-bsps' (in the top of the source tree) for a valid BSP list])
            esac
            found=yes
@@ -46,7 +46,7 @@ AC_ARG_ENABLE(rtemsbsp,
          fi
        done
        if test $found = no; then
-         AC_MSG_ERROR([BSP '$bsp' not found, run 'rtems-bsp' (in the top of the source tree) for a valid BSP list])
+         AC_MSG_ERROR([BSP '$bsp' not found, run 'rtems-bsps' (in the top of the source tree) for a valid BSP list])
        fi
      done
2.16.2.windows.1
