[PATCH] Fix wrong command hint in case of error
    Joel Sherrill
    joel at rtems.org
    Sun Dec  2 22:51:03 UTC 2018
Nice catch! I pushed this.
Thanks.
--joel
On Sun, Dec 2, 2018 at 8:37 AM kaidoho <kho237115 at gmail.com> wrote:
>  aclocal/enable-rtemsbsp.m4 | 4 ++--
>  1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/aclocal/enable-rtemsbsp.m4 b/aclocal/enable-rtemsbsp.m4
> index 91ab607751..f0b391bbb8 100644
> --- a/aclocal/enable-rtemsbsp.m4
> +++ b/aclocal/enable-rtemsbsp.m4
> @@ -38,7 +38,7 @@ AC_ARG_ENABLE(rtemsbsp,
>               ${cfg_arch}* )
> -               AC_MSG_ERROR([BSP '$bsp' architecture does not match the
> --target architecture, run 'rtems-bsp' (in the top of the source tree) for
> a valid BSP list])
> +               AC_MSG_ERROR([BSP '$bsp' architecture does not match the
> --target architecture, run 'rtems-bsps' (in the top of the source tree) for
> a valid BSP list])
>             esac
>             found=yes
> @@ -46,7 +46,7 @@ AC_ARG_ENABLE(rtemsbsp,
>           fi
>         done
>         if test $found = no; then
> -         AC_MSG_ERROR([BSP '$bsp' not found, run 'rtems-bsp' (in the top
> of the source tree) for a valid BSP list])
> +         AC_MSG_ERROR([BSP '$bsp' not found, run 'rtems-bsps' (in the top
>         fi
>       done
> 2.16.2.windows.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181202/d089b2c4/attachment-0002.html>
