[PATCH] eng/license-requirements: Convert wiki page to Rest
Marçal Comajoan Cara
mcomajoancara at gmail.com
Sun Dec 2 14:48:06 UTC 2018
Converted https://devel.rtems.org/wiki/Developer/Coding/Deprecating
to Rest, and TBDs into comments.
I removed the line that said "The RTEMS License is the typical and
preferred license." because this information is already in the first
and second paragraphs. Also because it linked to a TBR wiki page.
This work was part of GCI 2018.
eng/license-requirements.rst | 13 +++++++++++--
1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/eng/license-requirements.rst b/eng/license-requirements.rst
index 90a5409..4ae7c1c 100644
--- a/eng/license-requirements.rst
+++ b/eng/license-requirements.rst
@@ -18,6 +18,15 @@ previously submitted code to RTEMS under a historical license, please
grant the project permission to relicense. See
https://devel.rtems.org/ticket/3053 for details.
-TBD - Convert the following to Rest and insert into this file
-TBD - https://devel.rtems.org/wiki/Developer/Coding/Conventions#Licenses
+.. COMMENT: TBD - Convert the following to Rest and insert into this file
+.. COMMENT: TBD - https://devel.rtems.org/wiki/Developer/Coding/Conventions#Licenses
+2- and 3-clause BSD, MIT, and other OSI-approved non-copyleft licenses that
+permit statically linking with the code of different licenses are acceptable.
+GPL licensed code is NOT acceptable, neither is LGPL. See `this blog post
+<https://gedare-csphd.blogspot.com/2013/05/software-licenses-with-rtems.html>`_
+explanation for more information.
+Advertising obligations are NOT acceptable, but restrictions are permissible.
2.17.1
