POSIX Header File Signature Test for fenv.h (GCI 2018) (PATCH)
Abhimanyu Raghuvanshi
abhimanyuraghuvanshi29 at gmail.com
Tue Dec 4 09:17:50 UTC 2018
>From f2f64afbf8933adbec22ad6b4991fbcbe5461a53 Mon Sep 17 00:00:00 2001
From: ABR290B <abhimanyuraghuvanshi29 at gmail.com>
Date: Tue, 4 Dec 2018 14:45:33 +0530
Subject: [PATCH] Implement POSIX API Signature Compliance Tests for
arpa/inet.h (GCI2018)
testsuites/psxtests/Makefile.am | 13 ++++++-
.../psxtests/psxhdrs/fenv/feclearexcept.c | 34 ++++++++++++++++++
testsuites/psxtests/psxhdrs/fenv/fegetenv.c | 34 ++++++++++++++++++
.../psxtests/psxhdrs/fenv/fegetexceptflag.c | 35 +++++++++++++++++++
testsuites/psxtests/psxhdrs/fenv/fegetround.c | 34 ++++++++++++++++++
.../psxtests/psxhdrs/fenv/feholdexcept.c | 34 ++++++++++++++++++
.../psxtests/psxhdrs/fenv/feraiseexcept.c | 34 ++++++++++++++++++
testsuites/psxtests/psxhdrs/fenv/fesetenv.c | 34 ++++++++++++++++++
.../psxtests/psxhdrs/fenv/fesetexceptflag.c | 35 +++++++++++++++++++
testsuites/psxtests/psxhdrs/fenv/fesetround.c | 34 ++++++++++++++++++
.../psxtests/psxhdrs/fenv/fetestexcept.c | 34 ++++++++++++++++++
.../psxtests/psxhdrs/fenv/feupdateenv.c | 34 ++++++++++++++++++
12 files changed, 388 insertions(+), 1 deletion(-)
create mode 100644 testsuites/psxtests/psxhdrs/fenv/feclearexcept.c
create mode 100644 testsuites/psxtests/psxhdrs/fenv/fegetenv.c
create mode 100644 testsuites/psxtests/psxhdrs/fenv/fegetexceptflag.c
create mode 100644 testsuites/psxtests/psxhdrs/fenv/fegetround.c
create mode 100644 testsuites/psxtests/psxhdrs/fenv/feholdexcept.c
create mode 100644 testsuites/psxtests/psxhdrs/fenv/feraiseexcept.c
create mode 100644 testsuites/psxtests/psxhdrs/fenv/fesetenv.c
create mode 100644 testsuites/psxtests/psxhdrs/fenv/fesetexceptflag.c
create mode 100644 testsuites/psxtests/psxhdrs/fenv/fesetround.c
create mode 100644 testsuites/psxtests/psxhdrs/fenv/fetestexcept.c
create mode 100644 testsuites/psxtests/psxhdrs/fenv/feupdateenv.c
diff --git a/testsuites/psxtests/Makefile.am
b/testsuites/psxtests/Makefile.am
index c27f213959..633b2efab1 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1126,7 +1126,18 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
psxhdrs/arpa/inet/inet_addr.c \
psxhdrs/arpa/inet/inet_ntoa.c \
psxhdrs/arpa/inet/inet_pton.c \
- psxhdrs/arpa/inet/inet_ntop.c
+ psxhdrs/arpa/inet/inet_ntop.c \
+ psxhdrs/penv/feclearexcept.c \
+ psxhdrs/penv/fegetenv.c \
+ psxhdrs/penv/fegetexcept.c \
+ psxhdrs/penv/fegetround.c \
+ psxhdrs/penv/feholdexcept.c \
+ psxhdrs/penv/feraiseexcept.c \
+ psxhdrs/penv/fesetenv.c \
+ psxhdrs/penv/fesetexceptflag.c \
+ psxhdrs/penv/fesetround.c \
+ psxhdrs/penv/fesetexcept.c \
+ psxhdrs/penv/feupdateenv.c
endif
rtems_tests_PROGRAMS = $(psx_tests)
diff --git a/testsuites/psxtests/psxhdrs/fenv/feclearexcept.c
b/testsuites/psxtests/psxhdrs/fenv/feclearexcept.c
new file mode 100644
index 0000000000..1ecb53ab4a
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/fenv/feclearexcept.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief feclearexcept() API Conformance Test
+ * COPYRIGHT (c) 2018.
+ * Abhimanyu Raghuvanshi
+ * Permission to use, copy, modify, and/or distribute this software
+ * for any purpose with or without fee is hereby granted.
+ * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
+ * WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
+ * BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
+ * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
+ * WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
+ * ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
SOFTWARE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <fenv.h>
+int test(void);
+int test(void)
+ int b;
+ return feclearexcept(b);
\ No newline at end of file
diff --git a/testsuites/psxtests/psxhdrs/fenv/fegetenv.c
b/testsuites/psxtests/psxhdrs/fenv/fegetenv.c
index 0000000000..b01b06af6a
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/fenv/fegetenv.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief fegetenv() API Conformance Test
SOFTWARE.
+#endif
+#include <fenv.h>
+int test(void);
+int test(void)
+ fenv_t *a;
+ return fegetenv(a);
diff --git a/testsuites/psxtests/psxhdrs/fenv/fegetexceptflag.c
b/testsuites/psxtests/psxhdrs/fenv/fegetexceptflag.c
index 0000000000..5f18c95d7f
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/fenv/fegetexceptflag.c
@@ -0,0 +1,35 @@
+ * @file
+ * @brief fegetexceptflag() API Conformance Test
SOFTWARE.
+#endif
+#include <fenv.h>
+int test(void);
+int test(void)
+ int a;
+ fexcept_t *b;
+ return fegetexceptflag(b, a);
diff --git a/testsuites/psxtests/psxhdrs/fenv/fegetround.c
b/testsuites/psxtests/psxhdrs/fenv/fegetround.c
index 0000000000..dcf4274cba
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/fenv/fegetround.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief fegetround() API Conformance Test
SOFTWARE.
+#endif
+#include <fenv.h>
+int test(void);
+int test(void)
+ void a;
+ return fegetround(a);
diff --git a/testsuites/psxtests/psxhdrs/fenv/feholdexcept.c
b/testsuites/psxtests/psxhdrs/fenv/feholdexcept.c
index 0000000000..43cf2729bf
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/fenv/feholdexcept.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief feholfexcept() API Conformance Test
SOFTWARE.
+#endif
+#include <fenv.h>
+int test(void);
+int test(void)
+ fenv_t *a;
+ return feholfexcept(a);
diff --git a/testsuites/psxtests/psxhdrs/fenv/feraiseexcept.c
b/testsuites/psxtests/psxhdrs/fenv/feraiseexcept.c
index 0000000000..1d06d673e6
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/fenv/feraiseexcept.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief feraiseexcept() API Conformance Test
SOFTWARE.
+#endif
+#include <fenv.h>
+int test(void);
+int test(void)
+ int b;
+ return feraiseexcept(b);
diff --git a/testsuites/psxtests/psxhdrs/fenv/fesetenv.c
b/testsuites/psxtests/psxhdrs/fenv/fesetenv.c
index 0000000000..240dc31e6e
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/fenv/fesetenv.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief fesetenv() API Conformance Test
SOFTWARE.
+#endif
+#include <fenv.h>
+int test(void);
+int test(void)
+ const fenv_t *a;
+ return fesetenv(a);
diff --git a/testsuites/psxtests/psxhdrs/fenv/fesetexceptflag.c
b/testsuites/psxtests/psxhdrs/fenv/fesetexceptflag.c
index 0000000000..7d2e228e8c
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/fenv/fesetexceptflag.c
@@ -0,0 +1,35 @@
+ * @file
+ * @brief fesetexceptflag() API Conformance Test
SOFTWARE.
+#endif
+#include <fenv.h>
+int test(void);
+int test(void)
+ int a;
+ const fexcept_t *b;
+ return fesetexceptflag(b, a);
diff --git a/testsuites/psxtests/psxhdrs/fenv/fesetround.c
b/testsuites/psxtests/psxhdrs/fenv/fesetround.c
index 0000000000..51522f08b8
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/fenv/fesetround.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief fesetround() API Conformance Test
SOFTWARE.
+#endif
+#include <fenv.h>
+int test(void);
+int test(void)
+ int b;
+ return fesetround(b);
diff --git a/testsuites/psxtests/psxhdrs/fenv/fetestexcept.c
b/testsuites/psxtests/psxhdrs/fenv/fetestexcept.c
index 0000000000..c999357bf9
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/fenv/fetestexcept.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief fetestexcept() API Conformance Test
SOFTWARE.
+#endif
+#include <fenv.h>
+int test(void);
+int test(void)
+ int b;
+ return fetestexcept(b);
diff --git a/testsuites/psxtests/psxhdrs/fenv/feupdateenv.c
b/testsuites/psxtests/psxhdrs/fenv/feupdateenv.c
index 0000000000..d8340bb49a
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/fenv/feupdateenv.c
@@ -0,0 +1,34 @@
+ * @file
+ * @brief feupdateenv() API Conformance Test
SOFTWARE.
+#endif
+#include <fenv.h>
+int test(void);
+int test(void)
+ const fenv_t *a;
+ return feupdateenv(a);
送られた ABR2908
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181204/bfcead54/attachment-0001.html>
