POSIX Header File Signature Test for fenv.h (GCI 2018) (PATCH)
Tue Dec 4 15:40:15 UTC 2018
Same comment about claiming the task as the other patch. Submit as part of
the GCI task so you get credit. I will merge from there
On this one, I am going to add that the code should build without warnings.
Just visually reviewing, I see some variables which look to be
uninitialized. Please ensure there are no warnings.
Also for methods which take constant/enumerated values for arguments, pick
one from the set, assign it to a variable, and pass that in.
--joel
On Tue, Dec 4, 2018 at 3:18 AM Abhimanyu Raghuvanshi <
abhimanyuraghuvanshi29 at gmail.com> wrote:
> From f2f64afbf8933adbec22ad6b4991fbcbe5461a53 Mon Sep 17 00:00:00 2001
> From: ABR290B <abhimanyuraghuvanshi29 at gmail.com>
> Date: Tue, 4 Dec 2018 14:45:33 +0530
> Subject: [PATCH] Implement POSIX API Signature Compliance Tests for
>  arpa/inet.h (GCI2018)
>  testsuites/psxtests/Makefile.am               | 13 ++++++-
>  .../psxtests/psxhdrs/fenv/feclearexcept.c     | 34 ++++++++++++++++++
>  testsuites/psxtests/psxhdrs/fenv/fegetenv.c   | 34 ++++++++++++++++++
>  .../psxtests/psxhdrs/fenv/fegetexceptflag.c   | 35 +++++++++++++++++++
>  testsuites/psxtests/psxhdrs/fenv/fegetround.c | 34 ++++++++++++++++++
>  .../psxtests/psxhdrs/fenv/feholdexcept.c      | 34 ++++++++++++++++++
>  .../psxtests/psxhdrs/fenv/feraiseexcept.c     | 34 ++++++++++++++++++
>  testsuites/psxtests/psxhdrs/fenv/fesetenv.c   | 34 ++++++++++++++++++
>  .../psxtests/psxhdrs/fenv/fesetexceptflag.c   | 35 +++++++++++++++++++
>  testsuites/psxtests/psxhdrs/fenv/fesetround.c | 34 ++++++++++++++++++
>  .../psxtests/psxhdrs/fenv/fetestexcept.c      | 34 ++++++++++++++++++
>  .../psxtests/psxhdrs/fenv/feupdateenv.c       | 34 ++++++++++++++++++
>  12 files changed, 388 insertions(+), 1 deletion(-)
>  create mode 100644 testsuites/psxtests/psxhdrs/fenv/feclearexcept.c
>  create mode 100644 testsuites/psxtests/psxhdrs/fenv/fegetenv.c
>  create mode 100644 testsuites/psxtests/psxhdrs/fenv/fegetexceptflag.c
>  create mode 100644 testsuites/psxtests/psxhdrs/fenv/fegetround.c
>  create mode 100644 testsuites/psxtests/psxhdrs/fenv/feholdexcept.c
>  create mode 100644 testsuites/psxtests/psxhdrs/fenv/feraiseexcept.c
>  create mode 100644 testsuites/psxtests/psxhdrs/fenv/fesetenv.c
>  create mode 100644 testsuites/psxtests/psxhdrs/fenv/fesetexceptflag.c
>  create mode 100644 testsuites/psxtests/psxhdrs/fenv/fesetround.c
>  create mode 100644 testsuites/psxtests/psxhdrs/fenv/fetestexcept.c
>  create mode 100644 testsuites/psxtests/psxhdrs/fenv/feupdateenv.c
> diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> index c27f213959..633b2efab1 100644
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -1126,7 +1126,18 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
>   psxhdrs/arpa/inet/inet_addr.c \
>      psxhdrs/arpa/inet/inet_ntoa.c \
>   psxhdrs/arpa/inet/inet_pton.c \
> - psxhdrs/arpa/inet/inet_ntop.c
> + psxhdrs/arpa/inet/inet_ntop.c \
> + psxhdrs/penv/feclearexcept.c \
> + psxhdrs/penv/fegetenv.c \
> + psxhdrs/penv/fegetexcept.c \
> + psxhdrs/penv/fegetround.c \
> + psxhdrs/penv/feholdexcept.c \
> + psxhdrs/penv/feraiseexcept.c \
> + psxhdrs/penv/fesetenv.c \
> + psxhdrs/penv/fesetexceptflag.c \
> + psxhdrs/penv/fesetround.c \
> + psxhdrs/penv/fesetexcept.c \
> + psxhdrs/penv/feupdateenv.c
>  endif
>  rtems_tests_PROGRAMS = $(psx_tests)
> diff --git a/testsuites/psxtests/psxhdrs/fenv/feclearexcept.c
> b/testsuites/psxtests/psxhdrs/fenv/feclearexcept.c
> new file mode 100644
> index 0000000000..1ecb53ab4a
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/fenv/feclearexcept.c
> @@ -0,0 +1,34 @@
> + *  @file
> + *  @brief feclearexcept() API Conformance Test
> + *  COPYRIGHT (c) 2018.
> + *  Abhimanyu Raghuvanshi
> + *  Permission to use, copy, modify, and/or distribute this software
> + *  for any purpose with or without fee is hereby granted.
> + *  THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
> + *  WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
> + *  WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE
> AUTHOR
> + *  BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
> + *  OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
> + *  WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
> + *  ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
> SOFTWARE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> +  int b;
> +  return feclearexcept(b);
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxhdrs/fenv/fegetenv.c
> b/testsuites/psxtests/psxhdrs/fenv/fegetenv.c
> index 0000000000..b01b06af6a
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/fenv/fegetenv.c
> @@ -0,0 +1,34 @@
> + *  @file
> + *  @brief fegetenv() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> +  fenv_t *a;
> +  return fegetenv(a);
> diff --git a/testsuites/psxtests/psxhdrs/fenv/fegetexceptflag.c
> b/testsuites/psxtests/psxhdrs/fenv/fegetexceptflag.c
> index 0000000000..5f18c95d7f
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/fenv/fegetexceptflag.c
> @@ -0,0 +1,35 @@
> + *  @file
> + *  @brief fegetexceptflag() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> +  int a;
> +  fexcept_t *b;
> +  return fegetexceptflag(b, a);
> diff --git a/testsuites/psxtests/psxhdrs/fenv/fegetround.c
> b/testsuites/psxtests/psxhdrs/fenv/fegetround.c
> index 0000000000..dcf4274cba
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/fenv/fegetround.c
> @@ -0,0 +1,34 @@
> + *  @file
> + *  @brief fegetround() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> +  void a;
> +  return fegetround(a);
> diff --git a/testsuites/psxtests/psxhdrs/fenv/feholdexcept.c
> b/testsuites/psxtests/psxhdrs/fenv/feholdexcept.c
> index 0000000000..43cf2729bf
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/fenv/feholdexcept.c
> @@ -0,0 +1,34 @@
> + *  @file
> + *  @brief feholfexcept() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> +  fenv_t *a;
> +  return feholfexcept(a);
> diff --git a/testsuites/psxtests/psxhdrs/fenv/feraiseexcept.c
> b/testsuites/psxtests/psxhdrs/fenv/feraiseexcept.c
> index 0000000000..1d06d673e6
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/fenv/feraiseexcept.c
> @@ -0,0 +1,34 @@
> + *  @file
> + *  @brief feraiseexcept() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> +  int b;
> +  return feraiseexcept(b);
> diff --git a/testsuites/psxtests/psxhdrs/fenv/fesetenv.c
> b/testsuites/psxtests/psxhdrs/fenv/fesetenv.c
> index 0000000000..240dc31e6e
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/fenv/fesetenv.c
> @@ -0,0 +1,34 @@
> + *  @file
> + *  @brief fesetenv() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> +  const fenv_t *a;
> +  return fesetenv(a);
> diff --git a/testsuites/psxtests/psxhdrs/fenv/fesetexceptflag.c
> b/testsuites/psxtests/psxhdrs/fenv/fesetexceptflag.c
> index 0000000000..7d2e228e8c
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/fenv/fesetexceptflag.c
> @@ -0,0 +1,35 @@
> + *  @file
> + *  @brief fesetexceptflag() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> +  int a;
> +  const fexcept_t *b;
> +  return fesetexceptflag(b, a);
> diff --git a/testsuites/psxtests/psxhdrs/fenv/fesetround.c
> b/testsuites/psxtests/psxhdrs/fenv/fesetround.c
> index 0000000000..51522f08b8
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/fenv/fesetround.c
> @@ -0,0 +1,34 @@
> + *  @file
> + *  @brief fesetround() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> +  int b;
> +  return fesetround(b);
> diff --git a/testsuites/psxtests/psxhdrs/fenv/fetestexcept.c
> b/testsuites/psxtests/psxhdrs/fenv/fetestexcept.c
> index 0000000000..c999357bf9
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/fenv/fetestexcept.c
> @@ -0,0 +1,34 @@
> + *  @file
> + *  @brief fetestexcept() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> +  int b;
> +  return fetestexcept(b);
> diff --git a/testsuites/psxtests/psxhdrs/fenv/feupdateenv.c
> b/testsuites/psxtests/psxhdrs/fenv/feupdateenv.c
> index 0000000000..d8340bb49a
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/fenv/feupdateenv.c
> @@ -0,0 +1,34 @@
> + *  @file
> + *  @brief feupdateenv() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +#include <fenv.h>
> +int test(void);
> +int test(void)
> +  const fenv_t *a;
> +  return feupdateenv(a);
> 送られた ABR2908
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181204/d665655b/attachment-0002.html>
