[PATCH] Spelling and grammar fixes in source code comments
Marçal Comajoan Cara
mcomajoancara at gmail.com
Tue Dec 4 20:10:30 UTC 2018
This work was part of GCI 2018.
bsps/i386/pc386/start/README-SMP | 2 +-
bsps/powerpc/shared/exceptions/ppc_exc_address.c | 2 +-
bsps/sparc/leon3/start/bspclean.c | 2 +-
cpukit/include/rtems/confdefs.h | 4 ++--
cpukit/include/rtems/rtems/mainpage.h | 4 ++--
cpukit/include/rtems/rtl/rtl.h | 4 ++--
cpukit/libfs/src/defaults/default_rename.c | 2 +-
cpukit/libfs/src/dosfs/msdos_format.c | 2 +-
cpukit/libi2c/README_libi2c | 2 +-
cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h | 2 +-
testsuites/smptests/smpmutex01/init.c | 2 +-
11 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/bsps/i386/pc386/start/README-SMP b/bsps/i386/pc386/start/README-SMP
index df2e729456..dd6de52b0d 100644
--- a/bsps/i386/pc386/start/README-SMP
+++ b/bsps/i386/pc386/start/README-SMP
@@ -1,7 +1,7 @@
The following files were developed by Erich Boleyn <erich at uruk.org>.
The original files were copied from http://www.uruk.org/mps/ and committed
into cvs as is. These files will be modified for RTEMS smp support,
-but the original files are being commited in order to track any file
+but the original files are being committed in order to track any file
changes that occur. We are attempting to keep these changes as minimal
and conainted as possible.
diff --git a/bsps/powerpc/shared/exceptions/ppc_exc_address.c b/bsps/powerpc/shared/exceptions/ppc_exc_address.c
index fc944177a8..08a5433641 100644
--- a/bsps/powerpc/shared/exceptions/ppc_exc_address.c
+++ b/bsps/powerpc/shared/exceptions/ppc_exc_address.c
@@ -31,7 +31,7 @@
#include <bsp/vectors.h>
- * XXX: These values are choosen to directly generate the vector offsets for an
+ * XXX: These values are chosen to directly generate the vector offsets for an
* e200z1 which has hard wired IVORs (IVOR0=0x00, IVOR1=0x10, IVOR2=0x20, ...).
static const uint8_t ivor_values [] = {
diff --git a/bsps/sparc/leon3/start/bspclean.c b/bsps/sparc/leon3/start/bspclean.c
index eff9c8635b..7d5448fdb3 100644
--- a/bsps/sparc/leon3/start/bspclean.c
+++ b/bsps/sparc/leon3/start/bspclean.c
@@ -44,7 +44,7 @@ void bsp_fatal_extension(
if (irqmp != NULL) {
- * Value was choosen to get something in the magnitude of 1ms on a 200MHz
+ * Value was chosen to get something in the magnitude of 1ms on a 200MHz
* processor.
uint32_t max_wait = 1234567;
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index e884289e2c..d66e23e0ab 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1129,7 +1129,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* @addtogroup Configuration
- * This module contains parameters related to thread aand interrupt stacks.
+ * This module contains parameters related to thread and interrupt stacks.
@@ -1523,7 +1523,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* Table.
* Default Device Driver Table. Each driver needed by the test is explicitly
- * choosen by the application. There is always a null driver entry.
+ * chosen by the application. There is always a null driver entry.
diff --git a/cpukit/include/rtems/rtems/mainpage.h b/cpukit/include/rtems/rtems/mainpage.h
index e2d51328cf..8a6ddbb8ad 100644
--- a/cpukit/include/rtems/rtems/mainpage.h
+++ b/cpukit/include/rtems/rtems/mainpage.h
@@ -359,7 +359,7 @@
* Since memory is a critical resource in many real-time embedded systems,
* RTEMS was specifically designed to automatically leave out all services that
* are not required from the run-time environment. Features such as networking,
- * various fileystems, and many other features are completely optional. This
+ * various filesystems, and many other features are completely optional. This
* allows the application designer the flexibility to tailor RTEMS to most
* efficiently meet system requirements while still satisfying even the most
* stringent memory constraints. As a result, the size of the RTEMS executive
@@ -502,7 +502,7 @@
* </table>
* The 16-bit format is designed to be as similar as possible to the 32-bit
- * format. The differences are limited to the eliminatation of the node field
+ * format. The differences are limited to the elimination of the node field
* and reduction of the index field from 16-bits to 8-bits. Thus the 16-bit
* format only supports up to 255 object instances per API/Class combination
* and single processor systems. As this format is typically utilized by 16-bit
diff --git a/cpukit/include/rtems/rtl/rtl.h b/cpukit/include/rtems/rtl/rtl.h
index 398ac2cd3f..41cb010ef4 100644
--- a/cpukit/include/rtems/rtl/rtl.h
+++ b/cpukit/include/rtems/rtl/rtl.h
@@ -42,12 +42,12 @@ extern "C" {
* dlclose family of functions.
* The runtime link editor is different to that found on Unix type systems. The
- * object modules are compiled for PIC or position indepentent code and
+ * object modules are compiled for PIC or position independent code and
* therefore require relocating when loaded.
* The object file format is currently ELF and object files can be separate
* files or in an archive. Object files in an archive are referenced by
- * specifing 'archive:object' format. For example 'libfoo.a:bar.o'.
+ * specifying 'archive:object' format. For example 'libfoo.a:bar.o'.
diff --git a/cpukit/libfs/src/defaults/default_rename.c b/cpukit/libfs/src/defaults/default_rename.c
index e4be4637ec..edaef54e58 100644
--- a/cpukit/libfs/src/defaults/default_rename.c
+++ b/cpukit/libfs/src/defaults/default_rename.c
@@ -1,7 +1,7 @@
* @file
- * @brief RTESM Default File System Rename Files
+ * @brief RTEMS Default File System Rename Files
* @ingroup LibIOFSOps File System Operations
diff --git a/cpukit/libfs/src/dosfs/msdos_format.c b/cpukit/libfs/src/dosfs/msdos_format.c
index 2643e16bd0..42f1d74575 100644
--- a/cpukit/libfs/src/dosfs/msdos_format.c
+++ b/cpukit/libfs/src/dosfs/msdos_format.c
@@ -574,7 +574,7 @@ static int msdos_format_determine_fmt_params
fmt_params->sectors_per_cluster = 1;
* limiting values for disk size, fat type, sectors per cluster
- * NOTE: maximum sect_per_clust is arbitrarily choosen with values that
+ * NOTE: maximum sect_per_clust is arbitrarily chosen with values that
* are a compromise concerning capacity and efficency
uint32_t fat12_sect_per_clust = 8;
diff --git a/cpukit/libi2c/README_libi2c b/cpukit/libi2c/README_libi2c
index 18de89da2a..e2b4013ed7 100644
--- a/cpukit/libi2c/README_libi2c
+++ b/cpukit/libi2c/README_libi2c
@@ -224,7 +224,7 @@ rtems_libi2c_drv_t data structure passed the libi2c when the device is
registered (see "Device registration" above). These function directly match
the RTEMS I/O Mangers calls "open", "close", "read", "write",
"control", and they are passed the same arguments. Functions not
-needed may be ommited (and replaced by a NULL pointer in
+needed may be omited (and replaced by a NULL pointer in
rtems_libi2c_drv_t).
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
index a9294d02a2..7ab09d990e 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
@@ -437,7 +437,7 @@ extern Context_Control_fp _CPU_Null_fp_context;
* by hardware or the interrupt processing code. These variables contain
* pointers to the lowest and highest addresses in the chunk of memory
* allocated for the interrupt stack. Since it is unknown whether the stack
- * grows up or down (in general), this give the CPU dependent code the option
+ * grows up or down (in general), this gives the CPU dependent code the option
* of picking the version it wants to use.
* Port Specific Information:
diff --git a/testsuites/smptests/smpmutex01/init.c b/testsuites/smptests/smpmutex01/init.c
index 91c0014a63..37f3bf1e50 100644
--- a/testsuites/smptests/smpmutex01/init.c
+++ b/testsuites/smptests/smpmutex01/init.c
@@ -30,7 +30,7 @@ const char rtems_test_name[] = "SMPMUTEX 1";
#define PRIO_NONE 0
-/* Value choosen for Qemu, 2 would be sufficient for real targets */
+/* Value chosen for Qemu, 2 would be sufficient for real targets */
#define TIMEOUT_IN_TICKS 10
typedef enum {
2.17.1
