[PATCH] eng/coding-doxygen: Convert wiki page to Rest
Marçal mcomajoancara at gmail.com
Tue Dec 4 21:21:53 UTC 2018
Sure!
On Tue, Dec 4, 2018 at 10:18 PM Joel Sherrill <joel at rtems.org> wrote:
> How about a new task to fix them and submit a patch? :)
> https://codein.withgoogle.com/dashboard/tasks/6126294447161344/
> --joel
> On Tue, Dec 4, 2018 at 2:01 PM Marçal <mcomajoancara at gmail.com> wrote:
>> Hi, it's weird because the task to do the eng/coding-doxygen was claimed
>> but me but apparently another student did the conversion before.
>> However, I see some things wrong that I think were correct in my
>> conversion, for example, the TBDs are not turned into comments, the links
>> on Header File Example point to the old locations (so it shows a not found
>> error) and should link to the new ones that you told me, the link to
>> Boilerplate File Header could be changed to link the Handbook section
>> instead of the wiki, and also some things are not correctly formatted so
>> they are displayed wrong. Looking at the code I also see that some lines
>> are longer than 80 characters. In my conversion I also had formatted some
>> Doxygen keywords to look nicer and more understandable and changed the
>> Script Example with a newer version showing a link
>> https://devel.rtems.org/newticket instead of
>> http://www.rtems.org/bugzilla which might generate confusion because
>> it's the old system.
>> I think it would be nice to fix the above things. What should I do to
>> help with it?
>> Marçal
>> On Tue, Dec 4, 2018 at 8:34 PM Joel Sherrill <joel at rtems.org> wrote:
>>> Part of this is pushed.
>>> I made a sweep at coding-doxygen.rst before this arrived. Please see if
>>> I missed anything. If so, send a new patch.
>>> THanks.
>>> On Tue, Dec 4, 2018 at 11:30 AM Marçal Comajoan Cara <
>>>> Converted https://devel.rtems.org/wiki/Developer/Coding/Doxygen
>>>> to Rest, and TBDs and wiki TODOs into comments. Also added formattings,
>>>> updated
>>>> links to Header File Examples and updated the Script Example to include
>>>> http://www.rtems.org/bugzilla,
>>>> which is the old RTEMS Ticket System which may generate confusion.
>>>> Added a label at the beginning of eng/coding-file-hdr.rst to be able to
>>>> link the page from eng/coding-doxygen.rst.
>>>> This work was part of GCI 2018.
>>>>  eng/coding-doxygen.rst  | 475 +++++++++++++++++++++++++++++++++++++++-
>>>>  eng/coding-file-hdr.rst |   1 +
>>>>  2 files changed, 474 insertions(+), 2 deletions(-)
>>>> diff --git a/eng/coding-doxygen.rst b/eng/coding-doxygen.rst
>>>> index 5aafde0..6f98eed 100644
>>>> --- a/eng/coding-doxygen.rst
>>>> +++ b/eng/coding-doxygen.rst
>>>> @@ -6,5 +6,476 @@
>>>>  General Doxygen Recommentations
>>>> -TBD - Convert the following to Rest and insert into this file
>>>> -TBD - https://devel.rtems.org/wiki/Developer/Coding/Doxygen
>>>> +.. COMMENT: TBD - Convert the following to Rest and insert into this
>>>> file
>>>> +.. COMMENT: TBD -
>>>> +Doxygen Best Practices
>>>> +* Do not use ``@a``. Instead use ``@param`` to document function
>>>> parameters.
>>>> +* Do not use ``@return``. Instead use ``@retval`` to document return
>>>> status
>>>> +  codes.
>>>> +* Do not write documentation for trivial functions.
>>>> +* Do not repeat documentation, use ``@see`` for example.
>>>> +* Do not use ``@note``.
>>>> +* Use groups and arrange them in a hierarchy. Put every file into at
>>>> least
>>>> +  one group.
>>>> +* Use dot comments for state diagrams.
>>>> +* Use one whitespace character after an asterisk.
>>>> +Special Notes for Google Code-in Students
>>>> +Follow the directions given by the `Google Code-in
>>>> +<https://devel.rtems.org/wiki/GCI>`_ task and this should take
>>>> +care of itself if in doubt ask a mentor and/or tell a mentor the
>>>> decision you
>>>> +made.
>>>> +Header File Example
>>>> +`thread.h
>>>> +<https://git.rtems.org/rtems/tree/cpukit/include/rtems/score/thread.h>`_
>>>> and
>>>> +`threadimpl.h
>>>> https://git.rtems.org/rtems/tree/cpukit/include/rtems/score/threadimpl.h
>>>> >`_
>>>> +should be a good example of how a header file shouldbe written. The
>>>> following
>>>> +gives details in bits and pieces.
>>>> +Header blocks
>>>> +Header files should contain the similar comment blocks as other source
>>>> files,
>>>> +described at :ref:`coding-file-hdr`.
>>>> +.. code-block:: c
>>>> +  * @file
>>>> +  * @ingroup FlipFlop
>>>> +  * @brief Flip-Flop API
>>>> +  * Copyright (c) YYYY Author.
>>>> +  * The license and distribution terms for this file may be
>>>> +  * found in the file LICENSE in this distribution or at
>>>> +  * http://www.rtems.com/license/LICENSE.
>>>> +Header guard
>>>> +After the comment blocks, use a header guard that assembles at least
>>>> the
>>>> +include path of the file. For example, if ``flipflop.h`` is in
>>>> +``<rtems/lib/flipflop.h>`` then
>>>> +.. code-block:: c
>>>> +  #ifndef RTEMS_LIB_FLIP_FLOP_H
>>>> +  #define RTEMS_LIB_FLIP_FLOP_H
>>>> +Includes
>>>> +Then add your include files before protecting C declarations from C++.
>>>> +.. code-block:: c
>>>> +  #include <rtems.h>
>>>> +  #ifdef __cplusplus
>>>> +  extern "C" {
>>>> +  #endif /* __cplusplus */
>>>> +Using @defgroup for group definitions
>>>> +Add any group definitions surrounding the function declarations that
>>>> belong
>>>> +in that group. Rarely, a header may define more than one group. Here
>>>> we use
>>>> +a dot diagram.
>>>> +.. code-block:: c
>>>> +  * @defgroup FlipFlop Flip-Flop
>>>> +  * @brief Simple Flip-Flop state machine.
>>>> +  * @dot
>>>> +  *   digraph {
>>>> +  *     start [label="START"];
>>>> +  *     flip [label="FLIP"];
>>>> +  *     flop [label="FLOP"];
>>>> +  *     flip -> flop [label="flop()", URL="\ref flop"];
>>>> +  *     flop -> flip [label="flip()", URL="\ref flip"];
>>>> +  *     start -> flip
>>>> +  *       [label="flip_flop_initialize(FLIP)", URL="\ref
>>>> flip_flop_initialize"];
>>>> +  *     start -> flop
>>>> +  *       [label="flip_flop_initialize(FLOP)", URL="\ref
>>>> +  *     flip -> start
>>>> +  *       [label="flip_flop_restart()", URL="\ref flip_flop_restart"];
>>>> +  * @enddot
>>>> +enum and struct
>>>> +Provide documentation for declarations of enumerated types and structs.
>>>> +Use typedefs for structs, and do not use ``_t`` as a typename suffix.
>>>> +.. code-block:: c
>>>> +  * @brief The set of possible flip-flop states.
>>>> +  * Enumerated type to define the set of states for a flip-flop.
>>>> +  typedef enum {
>>>> +    START = 0,
>>>> +    FLIP,
>>>> +    FLOP
>>>> +  } flip_flop_state;
>>>> +  * @brief Object containing multiple flip-flops.
>>>> +  * Encapsulates multiple flip-flops.
>>>> +  typedef struct {
>>>> +    * @brief Primary flip-flop.
>>>> +    flip_flop_state primary;
>>>> +    * @brief Secondary flip-flop.
>>>> +    flip_flop_state secondary;
>>>> +  } flip_flop_multiple;
>>>> +Using @name for organization
>>>> +Complicated groups can be given additional organization by using
>>>> ``@name``, or
>>>> +by declaring additional groups within the hierarchy of the header
>>>> file's
>>>> +top-level group.
>>>> +.. code-block:: c
>>>> +  * @name Flip-Flop Maintenance
>>>> +Declaring functions
>>>> +Function declarations should have an @brief that states what the
>>>> function does
>>>> +in a single topic sentence starting with a descriptive verb in the
>>>> present
>>>> +tense.
>>>> +.. code-block:: c
>>>> +  * @brief Initializes the flip-flop state.
>>>> +  * @param[in] state The initial state to set the flip-flop.
>>>> +  * @retval RTEMS_SUCCESSFUL Successfully initialized.
>>>> +  * @retval RTEMS_INCORRECT_STATE Flip-flop state is not valid.
>>>> +  rtems_status_code flip_flop_initialize(flip_flop_state state);
>>>> +  * @brief Restarts the flip-flop.
>>>> +  * @retval RTEMS_SUCCESSFUL Successfully restarted.
>>>> +  * @retval RTEMS_INCORRECT_STATE Flip-flop not in flip state.
>>>> +  rtems_status_code flip_flop_restart(void);
>>>> +Do not document trivial functions, such as getter/setter methods.
>>>> +.. code-block:: c
>>>> +  flip_flop_state flip_flop_current_state(void);
>>>> +Close the documentation name definition and open a new name
>>>> definition.
>>>> +.. code-block:: c
>>>> +  * @name Flip-Flop Usage
>>>> +  * @brief Flip operation.
>>>> +  * @retval RTEMS_SUCCESSFUL Flipped successfully.
>>>> +  * @retval RTEMS_INCORRECT_STATE Incorrect state for flip operation.
>>>> +  rtems_status_code flip( void );
>>>> +  * @brief Flop operation.
>>>> +  * @retval RTEMS_SUCCESSFUL Flopped successfully.
>>>> +  * @retval RTEMS_INCORRECT_STATE Incorrect state for flop operation.
>>>> +  rtems_status_code flop( void );
>>>> +Ending the file
>>>> +Close the documentation group definition, then the extern C
>>>> declarations,
>>>> +then the header guard.
>>>> +.. code-block:: c
>>>> +  #endif /* RTEMS_LIB_FLIP_FLOP_H */
>>>> + No newline at the end of the file.
>>>> +Source File Example
>>>> +.. code-block:: c
>>>> +  * @file
>>>> +  * @brief Flip-Flop implementation.
>>>> +  #include <rtems/lib/flipflop.h>
>>>> +  static flip_flop_state current_state;
>>>> +    if (current_state == START) {
>>>> +      current_state = state;
>>>> +      return RTEMS_SUCCESSFUL;
>>>> +    } else {
>>>> +      return RTEMS_INCORRECT_STATE;
>>>> +    if (current_state == FLIP) {
>>>> +      current_state = START;
>>>> +    } else {
>>>> +    return current_state;
>>>> +  rtems_status_code flip(void)
>>>> +    if (current_state == FLOP) {
>>>> +      current_state = FLIP;
>>>> +    } else {
>>>> +  rtems_status_code flop(void)
>>>> +      current_state = FLOP;
>>>> +    } else {
>>>> +Files
>>>> +Document files with the ``@file`` directive omitting the optional
>>>> filename
>>>> +argument. Doxygen will infer the filename from the actual name of the
>>>> file.
>>>> +Within one Doxygen run all files are unique and specified by the
>>>> current
>>>> +Doxyfile. We can define how the generated output of path and filenames
>>>> looks
>>>> +like in the Doxyfile via the ``FULL_PATH_NAMES``, ``STRIP_FROM_PATH``
>>>> and
>>>> +``STRIP_FROM_INC_PATH`` options.
>>>> +Functions
>>>> +For documentation of function arguments there are basically to ways:
>>>> +The first one uses ``@param``:
>>>> +.. code-block:: c
>>>> +  * @brief Copies from a source to a destination memory area.
>>>> +  * The source and destination areas may not overlap.
>>>> +  * @param[out] dest The destination memory area to copy to.
>>>> +  * @param[in] src The source memory area to copy from.
>>>> +  * @param[in] n The number of bytes to copy.
>>>> +The second is to use ``@a`` param in descriptive text, for example:
>>>> +.. code-block:: c
>>>> +  * Copies @a n bytes from a source memory area @a src to a
>>>> destination memory
>>>> +  * area @a dest, where both areas may not overlap.
>>>> +The ``@a`` indicates that the next word is a function argument and
>>>> deserves
>>>> +some kind of highlighting. However, we feel that ``@a`` buries the
>>>> usage of
>>>> +function arguments within description text. In RTEMS sources, we
>>>> prefer to
>>>> +use ``@param`` instead of ``@a``.
>>>> +.. COMMENT: TBD - Add Doxyfile Hints
>>>> +Header Files
>>>> +It is an RTEMS build feature that header files need to be installed in
>>>> order to
>>>> +be useful. One workaround to generate documentation which allows
>>>> automatic
>>>> +link generation is to use the installed header files as documentation
>>>> input.
>>>> +Assume that we have the RTEMS sources in the rtems directory and the
>>>> build of
>>>> +our BSP in build/powerpc-rtems5/mybsp relative to a common top-level
>>>> directory.
>>>> +Then you can configure Doxygen like:
>>>> +.. code-block::
>>>> +  INPUT           = rtems/bsps/powerpc/mybsp \
>>>> +                    rtems/c/src/lib/libcpu/powerpc/mycpu \
>>>> +                    rtems/make/custom/mybsp.cfg \
>>>> +                    build/powerpc-rtems5/mybsp/lib/include/myincludes
>>>> +  RECURSIVE       = YES
>>>> +  EXCLUDE         = rtems/bsps/powerpc/mybsp/include \
>>>> +                    rtems/c/src/lib/libcpu/powerpc/mycpu/include
>>>> +  FULL_PATH_NAMES = YES
>>>> +  STRIP_FROM_PATH = build/powerpc-rtems5/mybsp/lib/include \
>>>> +                    rtems
>>>> +Script and Assembly Files
>>>> +Doxygen cannot cope with script (= files with #-like comments) or
>>>> assembly files.
>>>> +But you can add filter programs for them
>>>> +.. COMMENT: TBD - Add source code for filter programs somewhere
>>>> +.. code-block::
>>>> +  FILTER_PATTERNS = *.S=c-comments-only \
>>>> +                    *.s=c-comments-only \
>>>> +                    *.cfg=script-comments-only \
>>>> +                    *.am=script-comments-only \
>>>> +                    *.ac=script-comments-only
>>>> +Assembly Example
>>>> +.. code-block:: c
>>>> +  * @fn void mpc55xx_fmpll_reset_config()
>>>> +  * @brief Configure FMPLL after reset.
>>>> +  * Sets the system clock from 12 MHz in two steps up to 128 MHz.
>>>> +  GLOBAL_FUNCTION mpc55xx_fmpll_reset_config
>>>> +      /* Save link register */
>>>> +      mflr r3
>>>> +      LA r4, FMPLL_SYNCR
>>>> +You have to put a declaration of this function somewhere in a header
>>>> file.
>>>> +Script Example
>>>> +.. code-block:: python
>>>> +  # @file
>>>> +  # @ingroup mpc55xx_config
>>>> +  # @brief Configure script of LibBSP for the MPC55xx evaluation
>>>> boards.
>>>> +  AC_PREREQ([2.69])
>>>> AC_INIT([rtems-c-src-lib-libbsp-powerpc-mpc55xxevb],[_RTEMS_VERSION],[
>>>> https://devel.rtems.org/newticket])
>>>> +GCC Attributes
>>>> +The Doxygen C/C++ parser cannot cope with the GCC
>>>> ``attribute((something))`` stuff.
>>>> +But you can discard such features with pre-defined preprocessor macros
>>>> +.. code-block:: none
>>>> +  ENABLE_PREPROCESSING = YES
>>>> +  MACRO_EXPANSION      = YES
>>>> +  EXPAND_ONLY_PREDEF   = YES
>>>> +  PREDEFINED           = __attribute__(x)=
>>>> +History
>>>> +RTEMS is much older than `Doxygen <http://www.doxygen.org/>`_ and the
>>>> +documentation in the .h and .inl files was obviously not written with
>>>> +`Doxygen markup <http://www.stack.nl/~dimitri/doxygen/manual.html>`_.
>>>> In
>>>> +2007, Joel Sherrill undertook to convert the documentation in the .h
>>>> and .inl
>>>> +files in the RTEMS SuperCore to Doxygen format. As a result of this
>>>> effort,
>>>> +the Doxygen for the development version of the RTEMS SuperCore is now
>>>> built automatically
>>>> +multiple times per day and made available on the RTEMS Website. In
>>>> April 2008,
>>>> +Joel Sherrill began to update the Classic API (e.g. cpukit/rtems) .h
>>>> and .inl
>>>> +files to include Doxygen markup.
>>>> diff --git a/eng/coding-file-hdr.rst b/eng/coding-file-hdr.rst
>>>> index 1ff16b8..f273e03 100644
>>>> --- a/eng/coding-file-hdr.rst
>>>> +++ b/eng/coding-file-hdr.rst
>>>> @@ -7,6 +7,7 @@
>>>>  .. COMMENT:TBD  - Convert the following to Rest and insert into this
>>>> file
>>>>  .. COMMENT:TBD -
>>>> https://devel.rtems.org/wiki/Developer/Coding/Boilerplate_File_Header
>>>> +.. _coding-file-hdr:
>>>> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181204/652edab0/attachment-0002.html>
