Unstable RTEMS 6 tool chain?
Wed Dec 5 10:55:33 UTC 2018
On 04/12/2018 04:37, Chris Johns wrote:
> On 03/12/2018 17:45, Sebastian Huber wrote:
>> what about adding an unstable RTEMS 6 tool chain to the RSB which is
>> automatically updated weekly? I would like to test the Newlib, Binutils, GCC and
>> GDB head regularly. I could set up a cron job to check out the Git master each
>> Sunday (RTEMS, Newlib, Binutils, GCC and GDB), update the RSB, build the tools,
>> run the tests on erc32. If everything goes well push the change to RSB,
>> otherwise report the problem.
> This sounds fantastic. If you want to place the scripts in
> https://git.rtems.org/chrisj/rtems-admin.git/ please let me know and I can make
> sure the perms are ok.
Should I create new files in rtems/config/tools for each tool snapshot
or should I create in rtems/config/tools something like this
rtems-gdb-latest.cfg
rtems-binutils-latest.cfg
rtems-gcc-latest-newlib-latest.cfg
which are updated?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
