[PATCH] Implement POSIX API Signature Compliance Tests for inttypes.h
Marçal Comajoan Cara
mcomajoancara at gmail.com
Thu Dec 6 21:26:42 UTC 2018
This work was part of GCI 2018
testsuites/psxtests/Makefile.am | 9 ++++-
.../psxtests/psxhdrs/inttypes/imaxabs.c | 38 ++++++++++++++++++
.../psxtests/psxhdrs/inttypes/imaxdiv.c | 39 ++++++++++++++++++
.../psxtests/psxhdrs/inttypes/strtoimax.c | 39 ++++++++++++++++++
.../psxtests/psxhdrs/inttypes/strtoumax.c | 39 ++++++++++++++++++
.../psxtests/psxhdrs/inttypes/wcstoimax.c | 40 +++++++++++++++++++
.../psxtests/psxhdrs/inttypes/wcstoumax.c | 40 +++++++++++++++++++
7 files changed, 243 insertions(+), 1 deletion(-)
create mode 100644 testsuites/psxtests/psxhdrs/inttypes/imaxabs.c
create mode 100644 testsuites/psxtests/psxhdrs/inttypes/imaxdiv.c
create mode 100644 testsuites/psxtests/psxhdrs/inttypes/strtoimax.c
create mode 100644 testsuites/psxtests/psxhdrs/inttypes/strtoumax.c
create mode 100644 testsuites/psxtests/psxhdrs/inttypes/wcstoimax.c
create mode 100644 testsuites/psxtests/psxhdrs/inttypes/wcstoumax.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 4feaa8d68a..f5359d8b19 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1573,7 +1573,14 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
psxhdrs/wctype/wctrans.c \
psxhdrs/wctype/wctrans_l.c \
psxhdrs/wctype/wctype.c \
- psxhdrs/wctype/wctype_l.c
+ psxhdrs/wctype/wctype_l.c \
+ psxhdrs/inttypes/imaxabs.c \
+ psxhdrs/inttypes/imaxdiv.c \
+ psxhdrs/inttypes/strtoimax.c \
+ psxhdrs/inttypes/strtoumax.c \
+ psxhdrs/inttypes/wcstoimax.c \
+ psxhdrs/inttypes/wcstoumax.c
## Not supported by RTEMS, but POSIX API Compliance tests exist.
## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
diff --git a/testsuites/psxtests/psxhdrs/inttypes/imaxabs.c b/testsuites/psxtests/psxhdrs/inttypes/imaxabs.c
new file mode 100644
index 0000000000..df5c244034
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/inttypes/imaxabs.c
@@ -0,0 +1,38 @@
+ * @file
+ * @brief imaxabs() API Conformance Test
+ * COPYRIGHT (c) 2018.
+ * Marçal Comajoan Cara
+ * Permission to use, copy, modify, and/or distribute this software
+ * for any purpose with or without fee is hereby granted.
+ * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
+ * WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
+ * BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
+ * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
+ * WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
+ * ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <inttypes.h>
+int test( void );
+int test( void )
+ intmax_t n = -42;
+ intmax_t result;
+ result = imaxabs( n );
+ return ( result == 42 );
diff --git a/testsuites/psxtests/psxhdrs/inttypes/imaxdiv.c b/testsuites/psxtests/psxhdrs/inttypes/imaxdiv.c
index 0000000000..3538fef12b
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/inttypes/imaxdiv.c
@@ -0,0 +1,39 @@
+ * @file
+ * @brief imaxdiv() API Conformance Test
+#endif
+int test( void );
+int test( void )
+ intmax_t n = 42;
+ intmax_t denom = 5;
+ imaxdiv_t result;
+ result = imaxdiv( n, denom );
+ return ( result.quot == 8 && result.rem == 2 );
diff --git a/testsuites/psxtests/psxhdrs/inttypes/strtoimax.c b/testsuites/psxtests/psxhdrs/inttypes/strtoimax.c
index 0000000000..1544bdcb29
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/inttypes/strtoimax.c
@@ -0,0 +1,39 @@
+ * @file
+ * @brief strtoimax() API Conformance Test
+#endif
+int test( void );
+int test( void )
+ char *n = "-42";
+ intmax_t result;
+ char *endptr;
+ result = strtoimax( n, &endptr, 10 );
+ return ( result == -42 );
diff --git a/testsuites/psxtests/psxhdrs/inttypes/strtoumax.c b/testsuites/psxtests/psxhdrs/inttypes/strtoumax.c
index 0000000000..a8cd3137c8
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/inttypes/strtoumax.c
@@ -0,0 +1,39 @@
+ * @file
+ * @brief strtoumax() API Conformance Test
+#endif
+int test( void );
+int test( void )
+ char *n = "42";
+ uintmax_t result;
+ char *endptr;
+ result = strtoumax( n, &endptr, 10 );
diff --git a/testsuites/psxtests/psxhdrs/inttypes/wcstoimax.c b/testsuites/psxtests/psxhdrs/inttypes/wcstoimax.c
index 0000000000..e7af7ba9a2
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/inttypes/wcstoimax.c
@@ -0,0 +1,40 @@
+ * @file
+ * @brief wcstoimax() API Conformance Test
+#endif
+#include <stddef.h>
+int test( void );
+int test( void )
+ wchar_t *n = L"-42";
+ intmax_t result;
+ wchar_t *endptr;
+ result = wcstoimax( n, &endptr, 10 );
diff --git a/testsuites/psxtests/psxhdrs/inttypes/wcstoumax.c b/testsuites/psxtests/psxhdrs/inttypes/wcstoumax.c
index 0000000000..763cd9bfc5
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/inttypes/wcstoumax.c
@@ -0,0 +1,40 @@
+ * @file
+ * @brief wcstoumax() API Conformance Test
+#endif
+int test( void );
+int test( void )
+ wchar_t *n = L"42";
+ uintmax_t result;
+ wchar_t *endptr;
+ result = wcstoumax( n, &endptr, 10 );
2.19.2
