[PATCH] Fix typo in configure switch
kaidoho kho237115 at gmail.com
Sun Dec 9 19:28:57 UTC 2018
 eclipse/rtems.rst | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/eclipse/rtems.rst b/eclipse/rtems.rst
index ff3c421..a82f319 100644
--- a/eclipse/rtems.rst
+++ b/eclipse/rtems.rst
@@ -215,7 +215,7 @@ directory (--prefix)** to the RTEMS Kernel prefix of
 We disable networking to use the external LibBSD package and set the BSP to
 ``pc686``. Select the **Advanced** and in the **Additional command-line
-options** enter ``--disable-networking`` and ``--enable-rtemsbsps=pc686``. You
+options** enter ``--disable-networking`` and ``--enable-rtemsbsp=pc686``. You
 can add extra options you may need:
 .. figure:: ../images/eclipse/eclipse-rtems-git-prop-at-add-opts.png
2.17.1
