[PATCH] psxhdrs: Implement POSIX API Signature Compliance Tests for times.h
Marçal Comajoan Cara
mcomajoancara at gmail.com
Sun Dec 9 21:41:45 UTC 2018
This work was part of GCI 2018.
testsuites/psxtests/Makefile.am | 3 +-
testsuites/psxtests/psxhdrs/sys/times/times.c | 37 +++++++++++++++++++
2 files changed, 39 insertions(+), 1 deletion(-)
create mode 100644 testsuites/psxtests/psxhdrs/sys/times/times.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 01fd04a52e..594586ed0e 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1780,7 +1780,8 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
psxhdrs/stdlib/system.c \
psxhdrs/stdlib/unsetenv.c \
psxhdrs/stdlib/wcstombs.c \
- psxhdrs/stdlib/wctomb.c
+ psxhdrs/stdlib/wctomb.c \
+ psxhdrs/sys/times/times.c
## Not supported by RTEMS, but POSIX API Compliance tests exist.
diff --git a/testsuites/psxtests/psxhdrs/sys/times/times.c b/testsuites/psxtests/psxhdrs/sys/times/times.c
new file mode 100644
index 0000000000..420f2556c0
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/times/times.c
@@ -0,0 +1,37 @@
+ * @file
+ * @brief times() API Conformance Test
+ * COPYRIGHT (c) 2018.
+ * Marçal Comajoan Cara
+ * Permission to use, copy, modify, and/or distribute this software
+ * for any purpose with or without fee is hereby granted.
+ * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
+ * WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
+ * BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
+ * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
+ * WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
+ * ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/times.h>
+int test( void );
+int test( void )
+ struct tms buffer;
+ clock_t tm = times( &buffer );
+ return (tm == (clock_t)-1);
2.19.2
