Status of smptests ...?
Joel Sherrill
joel at rtems.org
Tue Dec 11 14:33:09 UTC 2018
The order in which threads are assigned to cores has changed since the
first smp work. It used to be from 0 up, now from the highest core
associated with a scheduler down. If that's the only difference, the screen
is out of date.
Even if the screen is a guide of what to expect in some cases.
How does the smp support in sis switch back and forth between the cores?
Per cycle, instruction, etc. Qemu switches per instruction translation
block as I recall.
--joel
On Tue, Dec 11, 2018, 9:24 AM Sebastian Huber <
sebastian.huber at embedded-brains.de wrote:
> Hello Jiri,
> On 11/12/2018 15:15, Jiri Gaisler wrote:
> > What is the status of the smptests of RTEMS 5 ?
> > I have added SMP capability to the sis simulator, and have tested it
> > with the smptests from rtems git. I have noticed that the reference
> > output (*.scn) are not equivalent to what the simulator or real hardware
> > outputs. It seems that the cpus are numbered backwards compared to the
> > .scn files.
> the .scn files are not up to date. Also the test output is quite test
> dependent and repeated test runs my produce different output.
> The best method to check if a test passed is to check if the
> *** END OF TEST XYZ ***
> message is printed. Which real target did you use to run the tests? I
> will do a test run tomorrow on a N2X.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181211/d2016c88/attachment.html>
