Status of smptests ...?
Tue Dec 11 14:24:23 UTC 2018
Hello Jiri,
On 11/12/2018 15:15, Jiri Gaisler wrote:
> What is the status of the smptests of RTEMS 5 ?
> I have added SMP capability to the sis simulator, and have tested it
> with the smptests from rtems git. I have noticed that the reference
> output (*.scn) are not equivalent to what the simulator or real hardware
> outputs. It seems that the cpus are numbered backwards compared to the
> .scn files.
the .scn files are not up to date. Also the test output is quite test
dependent and repeated test runs my produce different output.
The best method to check if a test passed is to check if the
*** END OF TEST XYZ ***
message is printed. Which real target did you use to run the tests? I
will do a test run tomorrow on a N2X.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
