[PATCH] psxhdrs: Implement POSIX API Signature Compliance Tests for poll.h
Marçal Comajoan Cara mcomajoancara at gmail.com
Tue Dec 11 16:41:35 UTC 2018
poll.h implements poll() which is not supported by RTEMS according
to the RTEMS POSIX 1003.1 Compliance Guide. See #3657.
This work was part of GCI 2018.
 testsuites/psxtests/Makefile.am         |  1 +
 testsuites/psxtests/psxhdrs/poll/poll.c | 50 +++++++++++++++++++++++++
 2 files changed, 51 insertions(+)
 create mode 100644 testsuites/psxtests/psxhdrs/poll/poll.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index a2b04caf33..5948998ce0 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1858,6 +1858,7 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
 ## lib_a_SOURCES += psxhdrs/sys/resource/getrlimit.c     See ticket #3653
 ## lib_a_SOURCES += psxhdrs/sys/resource/setpriority.c   See ticket #3654
 ## lib_a_SOURCES += psxhdrs/sys/resource/setrlimit.c     See ticket #3655
+## lib_a_SOURCES += psxhdrs/poll/poll.c                  See ticket #3657
 endif
 rtems_tests_PROGRAMS = $(psx_tests)
diff --git a/testsuites/psxtests/psxhdrs/poll/poll.c b/testsuites/psxtests/psxhdrs/poll/poll.c
new file mode 100644
index 0000000000..368fe248dd
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/poll/poll.c
@@ -0,0 +1,50 @@
+ *  @file
+ *  @brief poll() API Conformance Test
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2018 Marçal Comajoan Cara
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <poll.h>
+int test( void );
+int test( void )
+  struct pollfd fds[2];
+  int timeout_msecs = 0;
+  int result;
+  result = poll( fds, 2, timeout_msecs );
+  return result;
2.19.2
