[PATCH] psxhdrs: Implement POSIX API Signature Compliance Tests for poll.h
Tue Dec 11 19:25:28 UTC 2018
Thanks. I have pushed this!
I need to figure out how much you guys left to do for psxhdrs. :)
--joel
On Tue, Dec 11, 2018 at 10:41 AM Marçal Comajoan Cara <
mcomajoancara at gmail.com> wrote:
> poll.h implements poll() which is not supported by RTEMS according
> to the RTEMS POSIX 1003.1 Compliance Guide. See #3657.
> This work was part of GCI 2018.
>  testsuites/psxtests/Makefile.am         |  1 +
>  testsuites/psxtests/psxhdrs/poll/poll.c | 50 +++++++++++++++++++++++++
>  2 files changed, 51 insertions(+)
>  create mode 100644 testsuites/psxtests/psxhdrs/poll/poll.c
> diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> index a2b04caf33..5948998ce0 100644
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -1858,6 +1858,7 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
>  ## lib_a_SOURCES += psxhdrs/sys/resource/getrlimit.c     See ticket #3653
>  ## lib_a_SOURCES += psxhdrs/sys/resource/setpriority.c   See ticket #3654
>  ## lib_a_SOURCES += psxhdrs/sys/resource/setrlimit.c     See ticket #3655
> +## lib_a_SOURCES += psxhdrs/poll/poll.c                  See ticket #3657
>  endif
>  rtems_tests_PROGRAMS = $(psx_tests)
> diff --git a/testsuites/psxtests/psxhdrs/poll/poll.c
> b/testsuites/psxtests/psxhdrs/poll/poll.c
> new file mode 100644
> index 0000000000..368fe248dd
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/poll/poll.c
> @@ -0,0 +1,50 @@
> + *  @file
> + *  @brief poll() API Conformance Test
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2018 Marçal Comajoan Cara
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <poll.h>
> +int test( void );
> +int test( void )
> +  struct pollfd fds[2];
> +  int timeout_msecs = 0;
> +  int result;
> +  result = poll( fds, 2, timeout_msecs );
> +  return result;
> 2.19.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181211/029b324d/attachment-0002.html>
