POSIX Signature Test for sys/uio.h (GCI2018)
Abhimanyu Raghuvanshi abhimanyuraghuvanshi29 at gmail.com
Wed Dec 12 16:03:10 UTC 2018
Patch attached
>From 145613daf5bea789337540e488b626077ce03bef Mon Sep 17 00:00:00 2001
From: ABR290B <abhimanyuraghuvanshi29 at gmail.com>
Date: Wed, 12 Dec 2018 21:31:27 +0530
Subject: [PATCH] POSIX Signature Test for sys/uio.h (GCI2018)
 testsuites/psxtests/Makefile.am              |  4 ++-
 testsuites/psxtests/psxhdrs/sys/uio/readv.c  | 38 ++++++++++++++++++++
 testsuites/psxtests/psxhdrs/sys/uio/writev.c | 38 ++++++++++++++++++++
 3 files changed, 79 insertions(+), 1 deletion(-)
 create mode 100644 testsuites/psxtests/psxhdrs/sys/uio/readv.c
 create mode 100644 testsuites/psxtests/psxhdrs/sys/uio/writev.c
diff --git a/testsuites/psxtests/Makefile.am
b/testsuites/psxtests/Makefile.am
index 3dd8fe0139..7c7a94f968 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1815,7 +1815,9 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
  psxhdrs/setjmp/longjmp.c \
  psxhdrs/setjmp/setjmp.c \
  psxhdrs/setjmp/siglongjmp.c \
- psxhdrs/setjmp/sigsetjmp.c
+ psxhdrs/setjmp/sigsetjmp.c \
+ psxhdrs/sys/uio/readv.c \
+ psxhdrs/sys/uio/writev.c
 ## Not supported by RTEMS, but POSIX API Compliance tests exist.
 ## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
diff --git a/testsuites/psxtests/psxhdrs/sys/uio/readv.c
b/testsuites/psxtests/psxhdrs/sys/uio/readv.c
new file mode 100644
index 0000000000..8f6f3aa9f5
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/uio/readv.c
@@ -0,0 +1,38 @@
+ *  @file
+ *  @brief readv() API Conformance Test
+ *  COPYRIGHT (c) 2018.
+ *  Abhimanyu Raghuvanshi
+ *  Permission to use, copy, modify, and/or distribute this software
+ *  for any purpose with or without fee is hereby granted.
+ *  THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
+ *  WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
+ *  WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
+ *  BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
+ *  OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
+ *  WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
+ *  ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
SOFTWARE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/uio.h>
+#include <sys/types.h>
+int test(void);
+int test(void)
+  int a = 0;
+  const struct iovec b = {0,0};
+  int c = 1;
+  ssize_t ret = readv(a, &b, c);
+  return ret!='\0';
\ No newline at end of file
diff --git a/testsuites/psxtests/psxhdrs/sys/uio/writev.c
b/testsuites/psxtests/psxhdrs/sys/uio/writev.c
index 0000000000..0e53e21815
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/sys/uio/writev.c
@@ -0,0 +1,38 @@
+ *  @file
+ *  @brief writev() API Conformance Test
SOFTWARE.
+#endif
+int test(void);
+int test(void)
+  int a = 0;
+  int c = 1;
+  ssize_t ret = writev(a, &b, c);
+  return ret!='\0';
2.19.1.windows.1
ABR
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181212/d0dbe6a7/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181212/d0dbe6a7/attachment.obj>
