POSIX Signature Test for sys/shm.h (GCI2018)
Joel Sherrill
joel at rtems.org
Thu Dec 13 15:26:01 UTC 2018
This is another one not currently supported by RTEMS. I filed a ticket.
You need to provide a patch that updates the license in all your
submissions.
Merged.
Thanks.
On Wed, Dec 12, 2018 at 9:35 AM Abhimanyu Raghuvanshi <
abhimanyuraghuvanshi29 at gmail.com> wrote:
> Patch attached
> From 6555f778ab98ed138f5b3794ba81766506035a40 Mon Sep 17 00:00:00 2001
> From: ABR290B <abhimanyuraghuvanshi29 at gmail.com>
> Date: Wed, 12 Dec 2018 21:03:22 +0530
> Subject: [PATCH] POSIX Signature Test for sys/shm.h (GCI2018)
> testsuites/psxtests/Makefile.am | 6 ++-
> testsuites/psxtests/psxhdrs/sys/shm/shmat.c | 39 +++++++++++++++++++
> testsuites/psxtests/psxhdrs/sys/shm/shmctl.c | 40 ++++++++++++++++++++
> testsuites/psxtests/psxhdrs/sys/shm/shmdt.c | 33 ++++++++++++++++
> testsuites/psxtests/psxhdrs/sys/shm/shmget.c | 37 ++++++++++++++++++
> 5 files changed, 154 insertions(+), 1 deletion(-)
> create mode 100644 testsuites/psxtests/psxhdrs/sys/shm/shmat.c
> create mode 100644 testsuites/psxtests/psxhdrs/sys/shm/shmctl.c
> create mode 100644 testsuites/psxtests/psxhdrs/sys/shm/shmdt.c
> create mode 100644 testsuites/psxtests/psxhdrs/sys/shm/shmget.c
> diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> index 3dd8fe0139..c84ca295af 100644
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -1815,7 +1815,11 @@ lib_a_SOURCES = psxhdrs/devctl/posix_devctl.c \
> psxhdrs/setjmp/longjmp.c \
> psxhdrs/setjmp/setjmp.c \
> psxhdrs/setjmp/siglongjmp.c \
> - psxhdrs/setjmp/sigsetjmp.c
> + psxhdrs/setjmp/sigsetjmp.c \
> + psxhdrs/sys/shm/shmat.c \
> + psxhdrs/sys/shm/shmctl.c \
> + psxhdrs/sys/shm/shmdt.c \
> + psxhdrs/sys/shm/shmget.c
> ## Not supported by RTEMS, but POSIX API Compliance tests exist.
> ## lib_a_SOURCES += psxhdrs/ulimit/ulimit.c
> diff --git a/testsuites/psxtests/psxhdrs/sys/shm/shmat.c
> b/testsuites/psxtests/psxhdrs/sys/shm/shmat.c
> new file mode 100644
> index 0000000000..d84a7c19b9
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/sys/shm/shmat.c
> @@ -0,0 +1,39 @@
> + * @file
> + * @brief shmat() API Conformance Test
> + * COPYRIGHT (c) 2018.
> + * Abhimanyu Raghuvanshi
> + * Permission to use, copy, modify, and/or distribute this software
> + * for any purpose with or without fee is hereby granted.
> + * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
> + * WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
> + * WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE
> AUTHOR
> + * BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
> + * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
> + * WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
> + * ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
> SOFTWARE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <sys/shm.h>
> +int test(void);
> +int test(void)
> + int shmid = 0;
> + int shmflg = 1;
> + shmat(shmid, '\0', shmflg);
> + return (0);
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxhdrs/sys/shm/shmctl.c
> b/testsuites/psxtests/psxhdrs/sys/shm/shmctl.c
> index 0000000000..d5caf9e150
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/sys/shm/shmctl.c
> @@ -0,0 +1,40 @@
> + * @file
> + * @brief shmctl() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +int test(void);
> +int test(void)
> + int shmid = 0;
> + int shmflg = 1;
> + struct shmid_ds a = {0};
> + return shmctl(shmid, shmflg, &a);
> diff --git a/testsuites/psxtests/psxhdrs/sys/shm/shmdt.c
> b/testsuites/psxtests/psxhdrs/sys/shm/shmdt.c
> index 0000000000..40af17ff89
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/sys/shm/shmdt.c
> @@ -0,0 +1,33 @@
> + * @file
> + * @brief shmdt() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +int test(void);
> +int test(void)
> + return shmdt('\0');
> diff --git a/testsuites/psxtests/psxhdrs/sys/shm/shmget.c
> b/testsuites/psxtests/psxhdrs/sys/shm/shmget.c
> index 0000000000..7eff72b606
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/sys/shm/shmget.c
> @@ -0,0 +1,37 @@
> + * @file
> + * @brief shmget() API Conformance Test
> AUTHOR
> SOFTWARE.
> +#endif
> +int test(void);
> +int test(void)
> + key_t a = 1;
> + size_t b = 2;
> + int c = 3;
> + return shmget(a, b, c);
> 2.19.1.windows.1
> ABR
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181213/f5d75b87/attachment-0002.html>
