[PATCH] Add low level event recording support
Joel Sherrill
joel at rtems.org
Wed Dec 19 21:00:45 UTC 2018
How does this relate.to the existing infrastructure for the capture engine?
It seems duplicative.
On Wed, Dec 19, 2018, 7:21 AM Sebastian Huber <
sebastian.huber at embedded-brains.de wrote:
> Add low level event recording infrastructure for system and user
> defined events. The infrastructure is able to record high frequency
> events such as
> * SMP lock acquire/release,
> * interrupt entry/exit,
> * thread switches,
> * UMA zone allocate/free, and
> * Ethernet packet input/output, etc.
> It allows post-mortem analysis in fatal error handlers, e.g. the last
> events are in the record buffer, the newest event overwrites the oldest
> event. It is possible to detect record buffer overflows for consumers
> that expect a continuous stream of events, e.g. to display the system
> state in real-time.
> The implementation supports high-end SMP machines (more than 1GHz
> processor frequency, more than four processors).
> Add a new API instead. The implementation uses per-processor data
> structures and no atomic read-modify-write operations. It is uses
> per-processor ring buffers to record the events.
> The CPU counter is used to get the time of events. It is combined with
> periodic uptime events to synchronize it with CLOCK_REALTIME.
> The existing capture engine tries to solve this problem also, but its
> performance is not good enough for high-end production systems. The
> main issues are the variable-size buffers and the use of SMP locks for
> synchronization. To fix this, the API would change significantly.
> Update #3665.
> cpukit/Makefile.am | 6 +
> cpukit/headers.am | 3 +
> cpukit/include/rtems/confdefs.h | 31 ++
> cpukit/include/rtems/record.h | 333 ++++++++++++++
> cpukit/include/rtems/recordclient.h | 137 ++++++
> cpukit/include/rtems/recorddata.h | 293 ++++++++++++
> cpukit/include/rtems/score/percpu.h | 4 +
> cpukit/include/rtems/sysinit.h | 1 +
> cpukit/libmisc/record/record-client.c | 429 ++++++++++++++++++
> cpukit/libmisc/record/record-server.c | 286 ++++++++++++
> cpukit/libmisc/record/record-static.c | 131 ++++++
> cpukit/libmisc/record/record-text.c | 173 ++++++++
> cpukit/libmisc/record/record-userext.c | 125 ++++++
> cpukit/libmisc/record/record.c | 132 ++++++
> testsuites/libtests/Makefile.am | 18 +
> testsuites/libtests/configure.ac | 2 +
> testsuites/libtests/record01/init.c | 709
> testsuites/libtests/record01/record01.doc | 15 +
> testsuites/libtests/record01/record01.scn | 7 +
> testsuites/libtests/record02/init.c | 132 ++++++
> testsuites/libtests/record02/record02.doc | 12 +
> testsuites/libtests/record02/record02.scn | 81 ++++
> 22 files changed, 3060 insertions(+)
> create mode 100644 cpukit/include/rtems/record.h
> create mode 100644 cpukit/include/rtems/recordclient.h
> create mode 100644 cpukit/include/rtems/recorddata.h
> create mode 100644 cpukit/libmisc/record/record-client.c
> create mode 100644 cpukit/libmisc/record/record-server.c
> create mode 100644 cpukit/libmisc/record/record-static.c
> create mode 100644 cpukit/libmisc/record/record-text.c
> create mode 100644 cpukit/libmisc/record/record-userext.c
> create mode 100644 cpukit/libmisc/record/record.c
> create mode 100644 testsuites/libtests/record01/init.c
> create mode 100644 testsuites/libtests/record01/record01.doc
> create mode 100644 testsuites/libtests/record01/record01.scn
> create mode 100644 testsuites/libtests/record02/init.c
> create mode 100644 testsuites/libtests/record02/record02.doc
> create mode 100644 testsuites/libtests/record02/record02.scn
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index 23f4f40521..6695abd79d 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -307,6 +307,12 @@ librtemscpu_a_SOURCES += libmisc/monitor/mon-symbols.c
> librtemscpu_a_SOURCES += libmisc/monitor/mon-task.c
> librtemscpu_a_SOURCES += libmisc/mouse/mouse_parser.c
> librtemscpu_a_SOURCES += libmisc/mouse/serial_mouse.c
> +librtemscpu_a_SOURCES += libmisc/record/record.c
> +librtemscpu_a_SOURCES += libmisc/record/record-client.c
> +librtemscpu_a_SOURCES += libmisc/record/record-server.c
> +librtemscpu_a_SOURCES += libmisc/record/record-static.c
> +librtemscpu_a_SOURCES += libmisc/record/record-text.c
> +librtemscpu_a_SOURCES += libmisc/record/record-userext.c
> librtemscpu_a_SOURCES += libmisc/redirector/stdio-redirect.c
> librtemscpu_a_SOURCES += libmisc/rtems-fdt/rtems-fdt.c
> librtemscpu_a_SOURCES += libmisc/rtems-fdt/rtems-fdt-shell.c
> diff --git a/cpukit/headers.am b/cpukit/headers.am
> index 3ab97a95ca..fba976e5b1 100644
> --- a/cpukit/headers.am
> +++ b/cpukit/headers.am
> @@ -136,6 +136,9 @@ include_rtems_HEADERS += include/rtems/qreslib.h
> include_rtems_HEADERS += include/rtems/ramdisk.h
> include_rtems_HEADERS += include/rtems/rbheap.h
> include_rtems_HEADERS += include/rtems/rbtree.h
> +include_rtems_HEADERS += include/rtems/record.h
> +include_rtems_HEADERS += include/rtems/recordclient.h
> +include_rtems_HEADERS += include/rtems/recorddata.h
> include_rtems_HEADERS += include/rtems/ringbuf.h
> include_rtems_HEADERS += include/rtems/rtc.h
> include_rtems_HEADERS += include/rtems/rtems-debugger-remote-tcp.h
> diff --git a/cpukit/include/rtems/confdefs.h
> b/cpukit/include/rtems/confdefs.h
> index 45e70313fb..89b47050d6 100644
> --- a/cpukit/include/rtems/confdefs.h
> +++ b/cpukit/include/rtems/confdefs.h
> @@ -2123,6 +2123,10 @@ extern rtems_initialization_tasks_table
> Initialization_tasks[];
> defined(CONFIGURE_STACK_CHECKER_ENABLED) || \
> (defined(RTEMS_NEWLIB) &&
> !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY))
> static const rtems_extensions_table Configuration_Initial_Extensions[]
> + #if CONFIGURE_RECORD_PER_PROCESSOR_ITEMS > 0 && \
> + defined(CONFIGURE_RECORD_EXTENSIONS_ENABLED)
> + RECORD_EXTENSION,
> + #endif
> #if !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY)
> RTEMS_NEWLIB_EXTENSION,
> #endif
> @@ -2965,6 +2969,33 @@ struct _reent *__getreent(void)
> _CONFIGURE_MAXIMUM_PROCESSORS,
> #endif
> + #include <rtems/record.h>
> + #if (CONFIGURE_RECORD_PER_PROCESSOR_ITEMS &
> (CONFIGURE_RECORD_PER_PROCESSOR_ITEMS - 1)) != 0
> + #error "CONFIGURE_RECORD_PER_PROCESSOR_ITEMS must be a power of two"
> + #endif
> + #if CONFIGURE_RECORD_PER_PROCESSOR_ITEMS < 16
> + #error "CONFIGURE_RECORD_PER_PROCESSOR_ITEMS must be at least 16"
> + #endif
> + const unsigned int _Record_Item_count =
> CONFIGURE_RECORD_PER_PROCESSOR_ITEMS;
> + struct Record_Configured_control {
> + Record_Control Control;
> + rtems_record_item Items[ CONFIGURE_RECORD_PER_PROCESSOR_ITEMS ];
> + PER_CPU_DATA_ITEM( Record_Configured_control, _Record_Per_CPU );
> + RTEMS_SYSINIT_ITEM(
> + _Record_Initialize,
> + RTEMS_SYSINIT_RECORD,
> + RTEMS_SYSINIT_ORDER_MIDDLE
> + #endif
> #endif
> #if defined(RTEMS_SMP)
> diff --git a/cpukit/include/rtems/record.h b/cpukit/include/rtems/record.h
> new file mode 100644
> index 0000000000..b8f7560fbe
> --- /dev/null
> +++ b/cpukit/include/rtems/record.h
> @@ -0,0 +1,333 @@
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2018 embedded brains GmbH
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _RTEMS_RECORD_H
> +#define _RTEMS_RECORD_H
> +#include "recorddata.h"
> +#include <rtems/score/atomic.h>
> +#include <rtems/score/cpu.h>
> +#include <rtems/score/percpudata.h>
> +#include <rtems/score/watchdog.h>
> +#include <rtems/rtems/intr.h>
> +#include <rtems/rtems/tasks.h>
> +#include <rtems/counter.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +struct Record_Control {
> + Atomic_Uint head;
> + unsigned int tail;
> + unsigned int mask;
> + Watchdog_Control Watchdog;
> + rtems_record_item Header[ 3 ];
> + rtems_record_item Items[ RTEMS_ZERO_LENGTH_ARRAY ];
> +typedef struct Record_Control Record_Control;
> +typedef RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
> + struct Record_Configured_control Record_Configured_control;
> +typedef struct {
> + Record_Control *control;
> + unsigned int head;
> + uint32_t now;
> + rtems_interrupt_level level;
> +} rtems_record_context;
> +PER_CPU_DATA_ITEM_DECLARE( Record_Configured_control, _Record_Per_CPU );
> +extern const unsigned int _Record_Item_count;
> +void _Record_Initialize( void );
> +bool _Record_Thread_create(
> + struct _Thread_Control *executing,
> + struct _Thread_Control *created
> +void _Record_Thread_start(
> + struct _Thread_Control *started
> +void _Record_Thread_restart(
> + struct _Thread_Control *restarted
> +void _Record_Thread_delete(
> + struct _Thread_Control *deleted
> +void _Record_Thread_switch(
> + struct _Thread_Control *heir
> +void _Record_Thread_begin( struct _Thread_Control *executing );
> +void _Record_Thread_exitted( struct _Thread_Control *executing );
> +void _Record_Thread_terminate(
> +#define RECORD_EXTENSION \
> + _Record_Thread_create, \
> + _Record_Thread_start, \
> + _Record_Thread_restart, \
> + _Record_Thread_delete, \
> + _Record_Thread_switch, \
> + _Record_Thread_begin, \
> + _Record_Thread_exitted, \
> + NULL, \
> + _Record_Thread_terminate \
> +RTEMS_INLINE_ROUTINE unsigned int _Record_Index(
> + const Record_Control *control,
> + unsigned int index
> + return index & control->mask;
> +RTEMS_INLINE_ROUTINE unsigned int _Record_Head( const Record_Control
> *control )
> + return _Atomic_Load_uint( &control->head, ATOMIC_ORDER_RELAXED );
> +RTEMS_INLINE_ROUTINE unsigned int _Record_Tail( const Record_Control
> *control )
> + return control->tail;
> +RTEMS_INLINE_ROUTINE bool _Record_Is_overflow(
> + unsigned int tail,
> + unsigned int head
> + return head - tail >= control->mask + 1U;
> +RTEMS_INLINE_ROUTINE unsigned int _Record_Capacity(
> + unsigned int head
> + return ( tail - head - 1U ) & control->mask;
> +RTEMS_INLINE_ROUTINE rtems_counter_ticks _Record_Now( void )
> + return rtems_counter_read();
> +typedef struct RTEMS_PACKED {
> + uint32_t format;
> + uint32_t magic;
> + rtems_record_item Version;
> + rtems_record_item Count;
> + rtems_record_item Frequency;
> +} Record_Stream_header;
> +void _Record_Stream_header_initialize( Record_Stream_header *header );
> + * @addtogroup RTEMSRecord
> + * @brief Prepares to add and commit record items.
> + * This function disables interrupts.
> + * @param context The record context which must be used for the following
> + * rtems_record_add() and rtems_record_commit() calls. The record
> context
> + * may have an arbitrary content at function entry.
> + * @see rtems_record_produce().
> +RTEMS_INLINE_ROUTINE void rtems_record_prepare( rtems_record_context
> *context )
> + const Per_CPU_Control *cpu_self;
> + rtems_interrupt_local_disable( level );
> + context->now = RTEMS_RECORD_TIME_EVENT( _Record_Now(), 0 );
> + context->level = level;
> + cpu_self = _Per_CPU_Get();
> + control = cpu_self->record;
> + context->control = control;
> + head = _Record_Head( control );
> + context->head = head;
> + * @brief Adds a record item.
> + * @param context The record context initialized via
> rtems_record_prepare().
> + * @param event The record event without a time stamp for the item.
> + * @param data The record data for the item.
> +RTEMS_INLINE_ROUTINE void rtems_record_add(
> + rtems_record_context *context,
> + rtems_record_event event,
> + rtems_record_data data
> + rtems_record_item *item;
> + control = context->control;
> + head = context->head;
> + item = &control->Items[ _Record_Index( control, head ) ];
> + context->head = head + 1;
> + item->event = context->now | event;
> + item->data = data;
> + * @brief Commits a set of record items.
> +RTEMS_INLINE_ROUTINE void rtems_record_commit( rtems_record_context
> *context )
> + _Atomic_Store_uint(
> + &context->control->head,
> + context->head,
> + ATOMIC_ORDER_RELEASE
> + rtems_interrupt_local_enable( context->level );
> + * @brief Produces a record item.
> +void rtems_record_produce( rtems_record_event event, rtems_record_data
> data );
> + * @brief Produces two record items.
> + * @param event_0 The record event without a time stamp for the first
> item.
> + * @param data_0 The record data for the first item.
> + * @param event_1 The record event without a time stamp for the second
> item.
> + * @param data_1 The record data for the second item.
> +void rtems_record_produce_2(
> + rtems_record_event event_0,
> + rtems_record_data data_0,
> + rtems_record_event event_1,
> + rtems_record_data data_1
> + * @brief Produces n record items.
> + * @param item The record items without a time stamps.
> + * @param n The count of record items.
> +void rtems_record_produce_n(
> + const rtems_record_item *items,
> + size_t n
> +typedef void ( *rtems_record_drain_visitor )(
> + size_t count,
> + void *arg
> + * @brief Drains the record items on all processors.
> + * Calls the visitor function for each drained item set.
> + * @param visitor The visitor function.
> + * @param arg The argument for the visitor function.
> +void rtems_record_drain( rtems_record_drain_visitor visitor, void *arg );
> + * @brief Drains the record items on all processors an writes them to the
> file
> + * descriptor.
> + * @param fd The file descriptor.
> + * @param written Set to true if items were written to the file
> descriptor,
> + * otherwise set to false.
> + * @retval The bytes written to the file descriptor.
> +ssize_t rtems_record_writev( int fd, bool *written );
> + * @brief Runs a record TCP server loop.
> + * @param port The TCP port to listen in host byte order.
> + * @param period The drain period in clock ticks.
> +void rtems_record_server( uint16_t port, rtems_interval period );
> + * @brief Starts a record TCP server task.
> + * @param priority The task priority.
> +rtems_status_code rtems_record_start_server(
> + rtems_task_priority priority,
> + uint16_t port,
> + rtems_interval period
> +#ifdef __cplusplus
> +#endif /* _RTEMS_RECORD_H */
> diff --git a/cpukit/include/rtems/recordclient.h
> b/cpukit/include/rtems/recordclient.h
> index 0000000000..21c16665a2
> --- /dev/null
> +++ b/cpukit/include/rtems/recordclient.h
> @@ -0,0 +1,137 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> + * This file must be compatible to general purpose POSIX system, e.g.
> Linux,
> + * FreeBSD. It may be used for utility programs.
> +#ifndef _RTEMS_RECORDCLIENT_H
> +#define _RTEMS_RECORDCLIENT_H
> +#include <stddef.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#define RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT 32
> +typedef enum {
> + RTEMS_RECORD_CLIENT_SUCCESS,
> + RTEMS_RECORD_CLIENT_ERROR_INVALID_MAGIC,
> + RTEMS_RECORD_CLIENT_ERROR_UNKNOWN_FORMAT,
> + RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_VERSION,
> + RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU
> +} rtems_record_client_status;
> +typedef rtems_record_client_status ( *rtems_record_client_handler )(
> + uint32_t seconds,
> + uint32_t nanoseconds,
> + uint32_t cpu,
> + uint64_t data,
> + void *arg
> +typedef struct {
> + struct {
> + uint64_t bt;
> + uint32_t time;
> + } uptime;
> + uint32_t tail[ 2 ];
> + uint32_t head[ 2 ];
> + size_t index;
> +} rtems_record_client_per_cpu;
> +typedef struct rtems_record_client_context {
> + uint64_t to_bt_scaler;
> + rtems_record_client_per_cpu per_cpu[
> RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT ];
> + uint64_t data;
> + uint32_t cpu;
> + uint32_t event;
> + uint32_t count;
> + union {
> + rtems_record_item_32 format_32;
> + rtems_record_item_64 format_64;
> + } item;
> + size_t todo;
> + void *pos;
> + rtems_record_client_status ( *consume )(
> + struct rtems_record_client_context *,
> + const void *,
> + size_t
> + rtems_record_client_handler handler;
> + void *handler_arg;
> + uint32_t header[ 2 ];
> +} rtems_record_client_context;
> + * @brief Initializes a record client.
> + * The record client consumes a record item stream produces by the record
> + * server.
> + * @param ctx The record client context to initialize.
> + * @param handler The handler is invoked for each received record item.
> + * @param arg The handler argument.
> +void rtems_record_client_init(
> + rtems_record_client_context *ctx,
> + rtems_record_client_handler handler,
> + void *arg
> + * @brief Runs the record client to consume new stream data.
> + * @param ctx The record client context.
> + * @param buf The buffer with new stream data.
> + * @param n The size of the buffer.
> +rtems_record_client_status rtems_record_client_run(
> + const void *buf,
> + size_t n
> +#ifdef __cplusplus
> +#endif /* _RTEMS_RECORDCLIENT_H */
> diff --git a/cpukit/include/rtems/recorddata.h
> b/cpukit/include/rtems/recorddata.h
> index 0000000000..e029ece53f
> --- /dev/null
> +++ b/cpukit/include/rtems/recorddata.h
> @@ -0,0 +1,293 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> Linux,
> +#ifndef _RTEMS_RECORDDATA_H
> +#define _RTEMS_RECORDDATA_H
> +#include <stdint.h>
> +#ifdef __cplusplus
> +extern "C" {
> + * @defgroup RTEMSRecord Event Recording
> + * @brief Low-level event recording support.
> + * @brief The record version.
> + * The record version reflects the record event definitions. It is
> reported by
> + * the RTEMS_RECORD_VERSION event.
> +#define RTEMS_RECORD_THE_VERSION 1
> + * @brief The items are in 32-bit little-endian format.
> +#define RTEMS_RECORD_FORMAT_LE_32 0x11111111
> + * @brief The items are in 64-bit little-endian format.
> +#define RTEMS_RECORD_FORMAT_LE_64 0x22222222
> + * @brief The items are in 32-bit big-endian format.
> +#define RTEMS_RECORD_FORMAT_BE_32 0x33333333
> + * @brief The items are in 64-bit big-endian format.
> +#define RTEMS_RECORD_FORMAT_BE_64 0x44444444
> + * @brief Magic number to identify a record item stream.
> + * This is a random number.
> +#define RTEMS_RECORD_MAGIC 0x82e14ec1
> + * @brief The record events.
> +typedef enum {
> + /* There are 512 events reserved for the system */
> + RTEMS_RECORD_EMPTY,
> + RTEMS_RECORD_VERSION,
> + * Keep the following system events in lexicographical order, increment
> + * RTEMS_RECORD_THE_VERSION after each change.
> + RTEMS_RECORD_ACCEPT,
> + RTEMS_RECORD_BIND,
> + RTEMS_RECORD_CHOWN,
> + RTEMS_RECORD_CLOSE,
> + RTEMS_RECORD_CONNECT,
> + RTEMS_RECORD_COUNT,
> + RTEMS_RECORD_FCHMOD,
> + RTEMS_RECORD_FCNTL,
> + RTEMS_RECORD_FDATASYNC,
> + RTEMS_RECORD_FREQUENCY,
> + RTEMS_RECORD_FSTAT,
> + RTEMS_RECORD_FSYNC,
> + RTEMS_RECORD_FTRUNCATE,
> + RTEMS_RECORD_HEAD,
> + RTEMS_RECORD_HEAP_ALLOC,
> + RTEMS_RECORD_HEAP_FREE,
> + RTEMS_RECORD_HEAP_SIZE,
> + RTEMS_RECORD_HEAP_USAGE,
> + RTEMS_RECORD_INTERUPT_BEGIN,
> + RTEMS_RECORD_INTERUPT_END,
> + RTEMS_RECORD_INTERUPT_INSTALL,
> + RTEMS_RECORD_INTERUPT_REMOVE,
> + RTEMS_RECORD_IOCTL,
> + RTEMS_RECORD_KEVENT,
> + RTEMS_RECORD_KQUEUE,
> + RTEMS_RECORD_LINK,
> + RTEMS_RECORD_LSEEK,
> + RTEMS_RECORD_MKNOD,
> + RTEMS_RECORD_MMAP,
> + RTEMS_RECORD_MOUNT,
> + RTEMS_RECORD_OPEN,
> + RTEMS_RECORD_OVERFLOW,
> + RTEMS_RECORD_POLL,
> + RTEMS_RECORD_PROCESSOR,
> + RTEMS_RECORD_READ,
> + RTEMS_RECORD_READLINK,
> + RTEMS_RECORD_READV,
> + RTEMS_RECORD_RECV,
> + RTEMS_RECORD_RECVFROM,
> + RTEMS_RECORD_RECVMSG,
> + RTEMS_RECORD_RENAME,
> + RTEMS_RECORD_RTEMS_BARRIER_CREATE,
> + RTEMS_RECORD_RTEMS_BARRIER_DELETE,
> + RTEMS_RECORD_RTEMS_BARRIER_RELEASE,
> + RTEMS_RECORD_RTEMS_BARRIER_WAIT,
> + RTEMS_RECORD_RTEMS_EVENT_RECEIVE,
> + RTEMS_RECORD_RTEMS_EVENT_SEND,
> + RTEMS_RECORD_RTEMS_EVENT_SYSTEM_RECEIVE,
> + RTEMS_RECORD_RTEMS_EVENT_SYSTEM_SEND,
> + RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_BROADCAST,
> + RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_CREATE,
> + RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_DELETE,
> + RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_FLUSH,
> + RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_RECEIVE,
> + RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_SEND,
> + RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_URGENT,
> + RTEMS_RECORD_RTEMS_PARTITION_CREATE,
> + RTEMS_RECORD_RTEMS_PARTITION_DELETE,
> + RTEMS_RECORD_RTEMS_PARTITION_GET_BUFFER,
> + RTEMS_RECORD_RTEMS_PARTITION_RETURN_BUFFER,
> + RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CANCEL,
> + RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CREATE,
> + RTEMS_RECORD_RTEMS_RATE_MONOTONIC_DELETE,
> + RTEMS_RECORD_RTEMS_RATE_MONOTONIC_PERIOD,
> + RTEMS_RECORD_RTEMS_SEMAPHORE_CREATE,
> + RTEMS_RECORD_RTEMS_SEMAPHORE_DELETE,
> + RTEMS_RECORD_RTEMS_SEMAPHORE_FLUSH,
> + RTEMS_RECORD_RTEMS_SEMAPHORE_OBTAIN,
> + RTEMS_RECORD_RTEMS_SEMAPHORE_RELEASE,
> + RTEMS_RECORD_RTEMS_TIMER_CANCEL,
> + RTEMS_RECORD_RTEMS_TIMER_CREATE,
> + RTEMS_RECORD_RTEMS_TIMER_DELETE,
> + RTEMS_RECORD_RTEMS_TIMER_FIRE_AFTER,
> + RTEMS_RECORD_RTEMS_TIMER_FIRE_WHEN,
> + RTEMS_RECORD_RTEMS_TIMER_RESET,
> + RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_AFTER,
> + RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_WHEN,
> + RTEMS_RECORD_SELECT,
> + RTEMS_RECORD_SEND,
> + RTEMS_RECORD_SENDMSG,
> + RTEMS_RECORD_SENDTO,
> + RTEMS_RECORD_SOCKET,
> + RTEMS_RECORD_STATVFS,
> + RTEMS_RECORD_SYMLINK,
> + RTEMS_RECORD_TAIL,
> + RTEMS_RECORD_THREAD_BEGIN,
> + RTEMS_RECORD_THREAD_CREATE,
> + RTEMS_RECORD_THREAD_DELETE,
> + RTEMS_RECORD_THREAD_EXIT,
> + RTEMS_RECORD_THREAD_EXITTED,
> + RTEMS_RECORD_THREAD_PRIO_CURRENT_HIGH,
> + RTEMS_RECORD_THREAD_PRIO_CURRENT_LOW,
> + RTEMS_RECORD_THREAD_PRIO_REAL_HIGH,
> + RTEMS_RECORD_THREAD_PRIO_REAL_LOW,
> + RTEMS_RECORD_THREAD_RESTART,
> + RTEMS_RECORD_THREAD_STACK_CURRENT,
> + RTEMS_RECORD_THREAD_STACK_SIZE,
> + RTEMS_RECORD_THREAD_STACK_USAGE,
> + RTEMS_RECORD_THREAD_START,
> + RTEMS_RECORD_THREAD_SWITCH_IN,
> + RTEMS_RECORD_THREAD_SWITCH_OUT,
> + RTEMS_RECORD_THREAD_TERMINATE,
> + RTEMS_RECORD_UMA_ALLOC_PTR,
> + RTEMS_RECORD_UMA_ALLOC_ZONE,
> + RTEMS_RECORD_UMA_FREE_PTR,
> + RTEMS_RECORD_UMA_FREE_ZONE,
> + RTEMS_RECORD_UNLINK,
> + RTEMS_RECORD_UNMOUNT,
> + RTEMS_RECORD_UPTIME_HIGH,
> + RTEMS_RECORD_UPTIME_LOW,
> + RTEMS_RECORD_WORKSPACE_ALLOC,
> + RTEMS_RECORD_WORKSPACE_FREE,
> + RTEMS_RECORD_WORKSPACE_SIZE,
> + RTEMS_RECORD_WORKSPACE_USAGE,
> + RTEMS_RECORD_WRITE,
> + RTEMS_RECORD_WRITEV,
> + /* There are 512 events reserved for the user */
> + RTEMS_RECORD_USER = 512,
> + RTEMS_RECORD_LAST = 1023
> +} rtems_record_event;
> + * @brief Bits in the record item event member reserved for the actual
> event.
> +#define RTEMS_RECORD_EVENT_BITS 10
> + * @brief Bits in the record item event member reserved for the time of
> the
> + * event.
> +#define RTEMS_RECORD_TIME_BITS 22
> + * @brief Builds a time event for the specified time stamp and event.
> + * The events are stored in the record item with a time stamp. There are
> 22
> + * bits allocated to the time stamp and 10 bits allocated to the event.
> The 22
> + * bits are enough to get reliable time stamps on a system with a 4GHz CPU
> + * counter and a 1000Hz clock tick.
> +#define RTEMS_RECORD_TIME_EVENT( time, event ) \
> + ( ( ( time ) << RTEMS_RECORD_EVENT_BITS ) | ( event ) )
> + * @brief Gets the time of a time event.
> +#define RTEMS_RECORD_GET_TIME( time_event ) \
> + ( ( time_event ) >> RTEMS_RECORD_EVENT_BITS )
> + * @brief Gets the event of a time event.
> +#define RTEMS_RECORD_GET_EVENT( time_event ) \
> + ( ( time_event ) & ( ( 1U << RTEMS_RECORD_EVENT_BITS ) - 1U ) )
> + * @brief The record data integer type.
> + * It is big enough to store 32-bit integers and pointers.
> +typedef unsigned long rtems_record_data;
> + * @brief The native record item.
> +typedef struct __attribute__((__packed__)) {
> + uint32_t event;
> + rtems_record_data data;
> +} rtems_record_item;
> + * @brief The 32-bit format record item.
> +typedef struct {
> + uint32_t event;
> + uint32_t data;
> +} rtems_record_item_32;
> + * @brief The 64-bit format record item.
> + uint32_t event;
> + uint64_t data;
> +} rtems_record_item_64;
> +const char *rtems_record_event_text( rtems_record_event event );
> +#ifdef __cplusplus
> +#endif /* _RTEMS_RECORDDATA_H */
> diff --git a/cpukit/include/rtems/score/percpu.h
> b/cpukit/include/rtems/score/percpu.h
> index 712d1cde36..22c5c30a00 100644
> --- a/cpukit/include/rtems/score/percpu.h
> +++ b/cpukit/include/rtems/score/percpu.h
> @@ -69,6 +69,8 @@ extern "C" {
> #if !defined( ASM )
> +struct Record_Control;
> struct _Thread_Control;
> struct Scheduler_Context;
> @@ -513,6 +515,8 @@ typedef struct Per_CPU_Control {
> bool boot;
> #endif
> + struct Record_Control *record;
> Per_CPU_Stats Stats;
> } Per_CPU_Control;
> diff --git a/cpukit/include/rtems/sysinit.h
> b/cpukit/include/rtems/sysinit.h
> index 2c718af8de..60fd9ddf41 100644
> --- a/cpukit/include/rtems/sysinit.h
> +++ b/cpukit/include/rtems/sysinit.h
> @@ -33,6 +33,7 @@ extern "C" {
> #define RTEMS_SYSINIT_MP_EARLY 000500
> #define RTEMS_SYSINIT_DATA_STRUCTURES 000600
> #define RTEMS_SYSINIT_MP 000700
> +#define RTEMS_SYSINIT_RECORD 000800
> #define RTEMS_SYSINIT_USER_EXTENSIONS 000900
> #define RTEMS_SYSINIT_CLASSIC_TASKS 000a00
> #define RTEMS_SYSINIT_CLASSIC_TIMER 000b00
> diff --git a/cpukit/libmisc/record/record-client.c
> b/cpukit/libmisc/record/record-client.c
> index 0000000000..6abda2b4c3
> --- /dev/null
> +++ b/cpukit/libmisc/record/record-client.c
> @@ -0,0 +1,429 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> Linux,
> +#if HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/recordclient.h>
> +#include <string.h>
> +static void set_to_bt_scaler(
> + uint32_t frequency
> + uint64_t bin_per_s;
> + bin_per_s = UINT64_C( 1 ) << 32;
> + ctx->to_bt_scaler = ( ( bin_per_s << 31 ) + frequency - 1 ) / frequency;
> +static void check_overflow(
> + const rtems_record_client_context *ctx,
> + const rtems_record_client_per_cpu *per_cpu,
> + uint32_t new_head
> + uint32_t last_tail;
> + uint32_t last_head;
> + uint32_t capacity;
> + uint32_t new_content;
> + last_tail = per_cpu->tail[ per_cpu->index ];
> + last_head = per_cpu->head[ per_cpu->index ];
> + if ( last_tail == last_head ) {
> + return;
> + capacity = ( last_tail - last_head - 1 ) & ( ctx->count - 1 );
> + new_content = new_head - last_head;
> + if ( new_content <= capacity ) {
> + return;
> + ( *ctx->handler )(
> + 0,
> + 0,
> + ctx->cpu,
> + new_content - capacity,
> + ctx->handler_arg
> +static rtems_record_client_status visit( rtems_record_client_context *ctx
> + rtems_record_client_per_cpu *per_cpu;
> + uint32_t time;
> + rtems_record_event event;
> + uint64_t data;
> + uint64_t bt;
> + uint32_t seconds;
> + uint32_t nanosec;
> + per_cpu = &ctx->per_cpu[ ctx->cpu ];
> + time = RTEMS_RECORD_GET_TIME( ctx->event );
> + event = RTEMS_RECORD_GET_EVENT( ctx->event );
> + data = ctx->data;
> + switch ( event ) {
> + case RTEMS_RECORD_PROCESSOR:
> + if ( data >= RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT ) {
> + return RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU;
> + ctx->cpu = (uint32_t) data;
> + break;
> + case RTEMS_RECORD_UPTIME_LOW:
> + per_cpu->uptime.bt = (uint32_t) data;
> + per_cpu->uptime.time = time;
> + time = 0;
> + break;
> + case RTEMS_RECORD_UPTIME_HIGH:
> + per_cpu->uptime.bt += (int64_t) data << 32;
> + time = 0;
> + break;
> + case RTEMS_RECORD_TAIL:
> + per_cpu->tail[ per_cpu->index ] = (uint32_t) data;
> + break;
> + case RTEMS_RECORD_HEAD:
> + per_cpu->head[ per_cpu->index ]= (uint32_t) data;
> + per_cpu->index ^= 1;
> + check_overflow( ctx, per_cpu, (uint32_t) data );
> + break;
> + case RTEMS_RECORD_COUNT:
> + ctx->count = (uint32_t) data;
> + break;
> + case RTEMS_RECORD_FREQUENCY:
> + set_to_bt_scaler( ctx, (uint32_t) data );
> + break;
> + case RTEMS_RECORD_VERSION:
> + if ( data != RTEMS_RECORD_THE_VERSION ) {
> + return RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_VERSION;
> + break;
> + default:
> + break;
> + if ( time != 0 ) {
> + time = ( time - per_cpu->uptime.time )
> + & ( ( UINT32_C( 1 ) << RTEMS_RECORD_TIME_BITS ) - 1 );
> + bt = ( time * ctx->to_bt_scaler ) >> 31;
> + bt += per_cpu->uptime.bt;
> + } else {
> + bt = 0;
> + seconds = (uint32_t) ( bt >> 32 );
> + nanosec = (uint32_t) ( ( UINT64_C( 1000000000 ) * (uint32_t) bt ) >> 32
> + return ( *ctx->handler )(
> + seconds,
> + nanosec,
> + ctx->cpu,
> + event,
> + data,
> + ctx->handler_arg
> +static rtems_record_client_status consume_32(
> + const void *buf,
> + size_t n
> + while ( n > 0 ) {
> + size_t m;
> + char *pos;
> + m = ctx->todo < n ? ctx->todo : n;
> + pos = ctx->pos;
> + pos = memcpy( pos, buf, m );
> + n -= m;
> + buf = (char *) buf + m;
> + if ( m == ctx->todo ) {
> + rtems_record_client_status status;
> + ctx->todo = sizeof( ctx->item.format_32 );
> + ctx->pos = &ctx->item.format_32;
> + ctx->event = ctx->item.format_32.event;
> + ctx->data = ctx->item.format_32.data;
> + status = visit( ctx );
> + if ( status != RTEMS_RECORD_CLIENT_SUCCESS ) {
> + return status;
> + } else {
> + ctx->todo -= m;
> + ctx->pos = pos + m;
> + return RTEMS_RECORD_CLIENT_SUCCESS;
> +static rtems_record_client_status consume_64(
> + const void *buf,
> + size_t n
> + while ( n > 0 ) {
> + size_t m;
> + char *pos;
> + pos = ctx->pos;
> + n -= m;
> + ctx->todo = sizeof( ctx->item.format_64 );
> + ctx->pos = &ctx->item.format_64;
> + ctx->event = ctx->item.format_64.event;
> + ctx->data = ctx->item.format_64.data;
> + return status;
> + } else {
> + ctx->todo -= m;
> +static rtems_record_client_status consume_swap_32(
> + const void *buf,
> + size_t n
> + while ( n > 0 ) {
> + size_t m;
> + char *pos;
> + pos = ctx->pos;
> + n -= m;
> + ctx->event = __builtin_bswap32( ctx->item.format_32.event );
> + ctx->data = __builtin_bswap32( ctx->item.format_32.data );
> + return status;
> + } else {
> + ctx->todo -= m;
> +static rtems_record_client_status consume_swap_64(
> + const void *buf,
> + size_t n
> + while ( n > 0 ) {
> + size_t m;
> + char *pos;
> + pos = ctx->pos;
> + n -= m;
> + ctx->event = __builtin_bswap32( ctx->item.format_64.event );
> + ctx->data = __builtin_bswap64( ctx->item.format_64.data );
> + return status;
> + } else {
> + ctx->todo -= m;
> +static rtems_record_client_status consume_init(
> + const void *buf,
> + size_t n
> + while ( n > 0 ) {
> + size_t m;
> + char *pos;
> + pos = ctx->pos;
> + n -= m;
> + uint32_t magic;
> + magic = ctx->header[ 1 ];
> + switch ( ctx->header[ 0 ] ) {
> +#if __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__
> + case RTEMS_RECORD_FORMAT_LE_32:
> + ctx->consume = consume_32;
> + break;
> + case RTEMS_RECORD_FORMAT_LE_64:
> + ctx->consume = consume_64;
> + break;
> + case RTEMS_RECORD_FORMAT_BE_32:
> + ctx->consume = consume_swap_32;
> + magic = __builtin_bswap32( magic );
> + break;
> + case RTEMS_RECORD_FORMAT_BE_64:
> + ctx->consume = consume_swap_64;
> + break;
> +#elif __BYTE_ORDER__ == __ORDER_BIG_ENDIAN__
> + break;
> + break;
> + break;
> + break;
> +#else
> +#error "unexpected __BYTE_ORDER__"
> +#endif
> + default:
> + return RTEMS_RECORD_CLIENT_ERROR_UNKNOWN_FORMAT;
> + if ( magic != RTEMS_RECORD_MAGIC ) {
> + return RTEMS_RECORD_CLIENT_ERROR_INVALID_MAGIC;
> + return rtems_record_client_run( ctx, buf, n );
> + } else {
> + ctx->todo -= m;
> + void *arg
> + ctx = memset( ctx, 0, sizeof( *ctx ) );
> + ctx->to_bt_scaler = UINT64_C( 1 ) << 31;
> + ctx->handler = handler;
> + ctx->handler_arg = arg;
> + ctx->todo = sizeof( ctx->header );
> + ctx->pos = &ctx->header;
> + ctx->consume = consume_init;
> + const void *buf,
> + size_t n
> + return ( *ctx->consume )( ctx, buf, n );
> diff --git a/cpukit/libmisc/record/record-server.c
> b/cpukit/libmisc/record/record-server.c
> index 0000000000..7a1959cefc
> --- /dev/null
> +++ b/cpukit/libmisc/record/record-server.c
> @@ -0,0 +1,286 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#if HAVE_CONFIG_H
> +#endif
> +#include <rtems/record.h>
> +#include <rtems.h>
> +#include <sys/endian.h>
> +#include <sys/socket.h>
> +#include <sys/uio.h>
> +#include <unistd.h>
> +#include <netinet/in.h>
> +#ifdef RTEMS_SMP
> +#define CHUNKS (3 * CPU_MAXIMUM_PROCESSORS)
> +#else
> +#define CHUNKS 4
> +#endif
> +typedef struct {
> + int available;
> + struct iovec *current;
> + struct iovec iov[CHUNKS];
> +} writev_visitor_context;
> +static void writev_visitor(
> + size_t count,
> + void *arg
> + writev_visitor_context *ctx;
> + ctx = arg;
> + if ( ctx->available > 0 ) {
> + ctx->current->iov_base = RTEMS_DECONST( rtems_record_item *, items );
> + ctx->current->iov_len = count * sizeof( *items );
> + --ctx->available;
> + ++ctx->current;
> + writev_visitor_context ctx;
> + int n;
> + ctx.available = CHUNKS;
> + ctx.current = &ctx.iov[ 0 ];
> + rtems_record_drain( writev_visitor, &ctx );
> + n = CHUNKS - ctx.available;
> + if ( n > 0 ) {
> + *written = true;
> + return writev( fd, &ctx.iov[ 0 ], n );
> + } else {
> + *written = false;
> + return 0;
> +#define WAKEUP_EVENT RTEMS_EVENT_0
> +static void wakeup( rtems_id task )
> + (void) rtems_event_send( task, WAKEUP_EVENT );
> +static void wait( rtems_option options )
> + rtems_event_set events;
> + (void) rtems_event_receive(
> + WAKEUP_EVENT,
> + RTEMS_EVENT_ANY | options,
> + RTEMS_NO_TIMEOUT,
> + &events
> +static void wakeup_timer( rtems_id timer, void *arg )
> + rtems_id *server;
> + server = arg;
> + wakeup( *server );
> + (void) rtems_timer_reset( timer );
> +#if BYTE_ORDER == LITTLE_ENDIAN
> +#if __INTPTR_WIDTH__ == 32
> + header->format = RTEMS_RECORD_FORMAT_LE_32,
> +#elif __INTPTR_WIDTH__ == 64
> + header->format = RTEMS_RECORD_FORMAT_LE_64,
> +#error "unexpected __INTPTR_WIDTH__"
> +#endif
> +#elif BYTE_ORDER == BIG_ENDIAN
> + header->format = RTEMS_RECORD_FORMAT_BE_32,
> + header->format = RTEMS_RECORD_FORMAT_BE_64,
> +#else
> +#endif
> +#else
> +#error "unexpected BYTE_ORDER"
> +#endif
> + header->magic = RTEMS_RECORD_MAGIC;
> + header->Version.event = RTEMS_RECORD_TIME_EVENT( 0,
> RTEMS_RECORD_VERSION );
> + header->Version.data = RTEMS_RECORD_THE_VERSION;
> + header->Count.event = RTEMS_RECORD_TIME_EVENT( 0, RTEMS_RECORD_COUNT );
> + header->Count.data = _Record_Item_count;
> + header->Frequency.event =
> + RTEMS_RECORD_TIME_EVENT( 0, RTEMS_RECORD_FREQUENCY );
> + header->Frequency.data = rtems_counter_frequency();
> +static void send_header( int fd )
> + Record_Stream_header header;
> + _Record_Stream_header_initialize( &header );
> + (void) write( fd, &header, sizeof( header ) );
> + rtems_status_code sc;
> + rtems_id self;
> + rtems_id timer;
> + struct sockaddr_in addr;
> + int sd;
> + int rv;
> + sd = -1;
> + self = rtems_task_self();
> + sc = rtems_timer_create( rtems_build_name( 'R', 'C', 'R', 'D' ), &timer
> + if ( sc != RTEMS_SUCCESSFUL ) {
> + return;
> + sd = socket( PF_INET, SOCK_STREAM, 0 );
> + if (sd < 0) {
> + goto error;
> + memset( &addr, 0, sizeof( addr ) );
> + addr.sin_family = AF_INET;
> + addr.sin_port = htons( port );
> + addr.sin_addr.s_addr = htonl( INADDR_ANY );
> + rv = bind( sd, (const struct sockaddr *) &addr, sizeof( addr ) );
> + if (rv != 0) {
> + goto error;
> + rv = listen( sd, 0 );
> + if (rv != 0) {
> + goto error;
> + while ( true ) {
> + int cd;
> + bool written;
> + ssize_t n;
> + cd = accept( sd, NULL, NULL );
> + if ( cd < 0 ) {
> + break;
> + wait( RTEMS_NO_WAIT );
> + (void) rtems_timer_fire_after( timer, period, wakeup_timer, &self );
> + send_header( cd );
> + while ( true ) {
> + n = rtems_record_writev( cd, &written );
> + if ( written && n <= 0 ) {
> + break;
> + wait( RTEMS_WAIT );
> + (void) rtems_timer_cancel( timer );
> + (void) close( cd );
> +error:
> + (void) close( sd );
> + (void) rtems_timer_delete( timer );
> +typedef struct {
> + rtems_id task;
> + uint16_t port;
> + rtems_interval period;
> +} server_arg;
> +static void server( rtems_task_argument arg )
> + server_arg *sarg;
> + uint16_t port;
> + sarg = (server_arg *) arg;
> + port = sarg->port;
> + period = sarg->period;
> + wakeup(sarg->task);
> + rtems_record_server( port, period );
> + rtems_task_exit();
> + uint16_t port,
> + rtems_id id;
> + server_arg sarg;
> + sarg.port = port;
> + sarg.period = period;
> + sarg.task = rtems_task_self();
> + sc = rtems_task_create(
> + rtems_build_name( 'R', 'C', 'R', 'D' ),
> + priority,
> + RTEMS_MINIMUM_STACK_SIZE,
> + RTEMS_DEFAULT_MODES,
> + RTEMS_DEFAULT_ATTRIBUTES,
> + &id
> + return sc;
> + (void) rtems_task_start( id, server, (rtems_task_argument) &sarg );
> + return RTEMS_SUCCESSFUL;
> diff --git a/cpukit/libmisc/record/record-static.c
> b/cpukit/libmisc/record/record-static.c
> index 0000000000..b96ae6d0b1
> --- /dev/null
> +++ b/cpukit/libmisc/record/record-static.c
> @@ -0,0 +1,131 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#if HAVE_CONFIG_H
> +#endif
> +#include <rtems/config.h>
> +#include <rtems/sysinit.h>
> +#include <rtems/score/timecounter.h>
> +#include <rtems/score/watchdogimpl.h>
> +static Watchdog_Interval _Record_Tick_interval;
> + uint32_t cpu_max;
> + uint32_t cpu_index;
> + uintptr_t offset;
> + cpu_max = rtems_configuration_get_maximum_processors();
> + offset = PER_CPU_DATA_OFFSET( _Record_Per_CPU );
> + for ( cpu_index = 0; cpu_index < cpu_max; ++cpu_index ) {
> + Per_CPU_Control *cpu;
> + cpu = _Per_CPU_Get_by_index( cpu_index );
> + control = PER_CPU_DATA_GET_BY_OFFSET( cpu, Record_Control, offset );
> + control->mask = _Record_Item_count - 1U;
> + cpu->record = control;
> +static void _Record_Watchdog(
> + Watchdog_Control *watchdog,
> + ISR_Level level;
> + sbintime_t now;
> + _ISR_Local_disable( level );
> + _Watchdog_Per_CPU_reinsert_ticks(
> + watchdog,
> + cpu,
> + _Record_Tick_interval
> + _ISR_Local_enable( level );
> + now = _Timecounter_Sbinuptime();
> + rtems_record_produce_2(
> + (uint32_t) ( now >> 0 ),
> + (uint32_t) ( now >> 32 )
> +static void _Record_Initialize_watchdogs( void )
> + Watchdog_Interval interval;
> + uint32_t cpu_max;
> + sbintime_t now;
> + interval = rtems_counter_frequency() / _Watchdog_Ticks_per_second;
> + interval = ( UINT32_C( 1 ) << 22 ) / interval;
> + if ( interval == 0 ) {
> + interval = 1;
> + _Record_Tick_interval = interval;
> + control = cpu->record;
> + _Watchdog_Preinitialize( &control->Watchdog, cpu );
> + _Watchdog_Initialize( &control->Watchdog, _Record_Watchdog );
> + &control->Watchdog,
> + cpu,
> +RTEMS_SYSINIT_ITEM(
> + _Record_Initialize_watchdogs,
> + RTEMS_SYSINIT_DEVICE_DRIVERS,
> + RTEMS_SYSINIT_ORDER_LAST
> diff --git a/cpukit/libmisc/record/record-text.c
> b/cpukit/libmisc/record/record-text.c
> index 0000000000..cc41647a0d
> --- /dev/null
> +++ b/cpukit/libmisc/record/record-text.c
> @@ -0,0 +1,173 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> Linux,
> +#if HAVE_CONFIG_H
> +#endif
> +#include <rtems/recorddata.h>
> +static const char * const event_text[] = {
> + [ RTEMS_RECORD_EMPTY ] = "EMPTY",
> + [ RTEMS_RECORD_VERSION ] = "VERSION",
> + [ RTEMS_RECORD_ACCEPT ] = "ACCEPT",
> + [ RTEMS_RECORD_BIND ] = "BIND",
> + [ RTEMS_RECORD_CHOWN ] = "CHOWN",
> + [ RTEMS_RECORD_CLOSE ] = "CLOSE",
> + [ RTEMS_RECORD_CONNECT ] = "CONNECT",
> + [ RTEMS_RECORD_COUNT ] = "COUNT",
> + [ RTEMS_RECORD_FCHMOD ] = "FCHMOD",
> + [ RTEMS_RECORD_FCNTL ] = "FCNTL",
> + [ RTEMS_RECORD_FDATASYNC ] = "FDATASYNC",
> + [ RTEMS_RECORD_FREQUENCY ] = "FREQUENCY",
> + [ RTEMS_RECORD_FSTAT ] = "FSTAT",
> + [ RTEMS_RECORD_FSYNC ] = "FSYNC",
> + [ RTEMS_RECORD_FTRUNCATE ] = "FTRUNCATE",
> + [ RTEMS_RECORD_HEAD ] = "HEAD",
> + [ RTEMS_RECORD_HEAP_ALLOC ] = "HEAP_ALLOC",
> + [ RTEMS_RECORD_HEAP_FREE ] = "HEAP_FREE",
> + [ RTEMS_RECORD_HEAP_SIZE ] = "HEAP_SIZE",
> + [ RTEMS_RECORD_HEAP_USAGE ] = "HEAP_USAGE",
> + [ RTEMS_RECORD_INTERUPT_BEGIN ] = "INTERUPT_BEGIN",
> + [ RTEMS_RECORD_INTERUPT_END ] = "INTERUPT_END",
> + [ RTEMS_RECORD_INTERUPT_INSTALL ] = "INTERUPT_INSTALL",
> + [ RTEMS_RECORD_INTERUPT_REMOVE ] = "INTERUPT_REMOVE",
> + [ RTEMS_RECORD_IOCTL ] = "IOCTL",
> + [ RTEMS_RECORD_KEVENT ] = "KEVENT",
> + [ RTEMS_RECORD_KQUEUE ] = "KQUEUE",
> + [ RTEMS_RECORD_LINK ] = "LINK",
> + [ RTEMS_RECORD_LSEEK ] = "LSEEK",
> + [ RTEMS_RECORD_MKNOD ] = "MKNOD",
> + [ RTEMS_RECORD_MMAP ] = "MMAP",
> + [ RTEMS_RECORD_MOUNT ] = "MOUNT",
> + [ RTEMS_RECORD_OPEN ] = "OPEN",
> + [ RTEMS_RECORD_OVERFLOW ] = "OVERFLOW",
> + [ RTEMS_RECORD_POLL ] = "POLL",
> + [ RTEMS_RECORD_PROCESSOR ] = "PROCESSOR",
> + [ RTEMS_RECORD_READ ] = "READ",
> + [ RTEMS_RECORD_READLINK ] = "READLINK",
> + [ RTEMS_RECORD_READV ] = "READV",
> + [ RTEMS_RECORD_RECV ] = "RECV",
> + [ RTEMS_RECORD_RECVFROM ] = "RECVFROM",
> + [ RTEMS_RECORD_RECVMSG ] = "RECVMSG",
> + [ RTEMS_RECORD_RENAME ] = "RENAME",
> + [ RTEMS_RECORD_RTEMS_BARRIER_CREATE ] = "RTEMS_BARRIER_CREATE",
> + [ RTEMS_RECORD_RTEMS_BARRIER_DELETE ] = "RTEMS_BARRIER_DELETE",
> + [ RTEMS_RECORD_RTEMS_BARRIER_RELEASE ] = "RTEMS_BARRIER_RELEASE",
> + [ RTEMS_RECORD_RTEMS_BARRIER_WAIT ] = "RTEMS_BARRIER_WAIT",
> + [ RTEMS_RECORD_RTEMS_EVENT_RECEIVE ] = "RTEMS_EVENT_RECEIVE",
> + [ RTEMS_RECORD_RTEMS_EVENT_SEND ] = "RTEMS_EVENT_SEND",
> + [ RTEMS_RECORD_RTEMS_EVENT_SYSTEM_RECEIVE ] =
> "RTEMS_EVENT_SYSTEM_RECEIVE",
> + [ RTEMS_RECORD_RTEMS_EVENT_SYSTEM_SEND ] = "RTEMS_EVENT_SYSTEM_SEND",
> + [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_BROADCAST ] =
> "RTEMS_MESSAGE_QUEUE_BROADCAST",
> + [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_CREATE ] =
> "RTEMS_MESSAGE_QUEUE_CREATE",
> + [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_DELETE ] =
> "RTEMS_MESSAGE_QUEUE_DELETE",
> + [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_FLUSH ] =
> "RTEMS_MESSAGE_QUEUE_FLUSH",
> + [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_RECEIVE ] =
> "RTEMS_MESSAGE_QUEUE_RECEIVE",
> + [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_SEND ] = "RTEMS_MESSAGE_QUEUE_SEND",
> + [ RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_URGENT ] =
> "RTEMS_MESSAGE_QUEUE_URGENT",
> + [ RTEMS_RECORD_RTEMS_PARTITION_CREATE ] = "RTEMS_PARTITION_CREATE",
> + [ RTEMS_RECORD_RTEMS_PARTITION_DELETE ] = "RTEMS_PARTITION_DELETE",
> + [ RTEMS_RECORD_RTEMS_PARTITION_GET_BUFFER ] =
> "RTEMS_PARTITION_GET_BUFFER",
> + [ RTEMS_RECORD_RTEMS_PARTITION_RETURN_BUFFER ] =
> "RTEMS_PARTITION_RETURN_BUFFER",
> + [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CANCEL ] =
> "RTEMS_RATE_MONOTONIC_CANCEL",
> + [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CREATE ] =
> "RTEMS_RATE_MONOTONIC_CREATE",
> + [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_DELETE ] =
> "RTEMS_RATE_MONOTONIC_DELETE",
> + [ RTEMS_RECORD_RTEMS_RATE_MONOTONIC_PERIOD ] =
> "RTEMS_RATE_MONOTONIC_PERIOD",
> + [ RTEMS_RECORD_RTEMS_SEMAPHORE_CREATE ] = "RTEMS_SEMAPHORE_CREATE",
> + [ RTEMS_RECORD_RTEMS_SEMAPHORE_DELETE ] = "RTEMS_SEMAPHORE_DELETE",
> + [ RTEMS_RECORD_RTEMS_SEMAPHORE_FLUSH ] = "RTEMS_SEMAPHORE_FLUSH",
> + [ RTEMS_RECORD_RTEMS_SEMAPHORE_OBTAIN ] = "RTEMS_SEMAPHORE_OBTAIN",
> + [ RTEMS_RECORD_RTEMS_SEMAPHORE_RELEASE ] = "RTEMS_SEMAPHORE_RELEASE",
> + [ RTEMS_RECORD_RTEMS_TIMER_CANCEL ] = "RTEMS_TIMER_CANCEL",
> + [ RTEMS_RECORD_RTEMS_TIMER_CREATE ] = "RTEMS_TIMER_CREATE",
> + [ RTEMS_RECORD_RTEMS_TIMER_DELETE ] = "RTEMS_TIMER_DELETE",
> + [ RTEMS_RECORD_RTEMS_TIMER_FIRE_AFTER ] = "RTEMS_TIMER_FIRE_AFTER",
> + [ RTEMS_RECORD_RTEMS_TIMER_FIRE_WHEN ] = "RTEMS_TIMER_FIRE_WHEN",
> + [ RTEMS_RECORD_RTEMS_TIMER_RESET ] = "RTEMS_TIMER_RESET",
> + [ RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_AFTER ] =
> "RTEMS_TIMER_SERVER_FIRE_AFTER",
> + [ RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_WHEN ] =
> "RTEMS_TIMER_SERVER_FIRE_WHEN",
> + [ RTEMS_RECORD_SELECT ] = "SELECT",
> + [ RTEMS_RECORD_SEND ] = "SEND",
> + [ RTEMS_RECORD_SENDMSG ] = "SENDMSG",
> + [ RTEMS_RECORD_SENDTO ] = "SENDTO",
> + [ RTEMS_RECORD_SOCKET ] = "SOCKET",
> + [ RTEMS_RECORD_STATVFS ] = "STATVFS",
> + [ RTEMS_RECORD_SYMLINK ] = "SYMLINK",
> + [ RTEMS_RECORD_TAIL ] = "TAIL",
> + [ RTEMS_RECORD_THREAD_BEGIN ] = "THREAD_BEGIN",
> + [ RTEMS_RECORD_THREAD_CREATE ] = "THREAD_CREATE",
> + [ RTEMS_RECORD_THREAD_DELETE ] = "THREAD_DELETE",
> + [ RTEMS_RECORD_THREAD_EXIT ] = "THREAD_EXIT",
> + [ RTEMS_RECORD_THREAD_EXITTED ] = "THREAD_EXITTED",
> + [ RTEMS_RECORD_THREAD_PRIO_CURRENT_HIGH ] = "THREAD_PRIO_CURRENT_HIGH",
> + [ RTEMS_RECORD_THREAD_PRIO_CURRENT_LOW ] = "THREAD_PRIO_CURRENT_LOW",
> + [ RTEMS_RECORD_THREAD_PRIO_REAL_HIGH ] = "THREAD_PRIO_REAL_HIGH",
> + [ RTEMS_RECORD_THREAD_PRIO_REAL_LOW ] = "THREAD_PRIO_REAL_LOW",
> + [ RTEMS_RECORD_THREAD_RESTART ] = "THREAD_RESTART",
> + [ RTEMS_RECORD_THREAD_STACK_CURRENT ] = "THREAD_STACK_CURRENT",
> + [ RTEMS_RECORD_THREAD_STACK_SIZE ] = "THREAD_STACK_SIZE",
> + [ RTEMS_RECORD_THREAD_STACK_USAGE ] = "THREAD_STACK_USAGE",
> + [ RTEMS_RECORD_THREAD_START ] = "THREAD_START",
> + [ RTEMS_RECORD_THREAD_SWITCH_IN ] = "THREAD_SWITCH_IN",
> + [ RTEMS_RECORD_THREAD_SWITCH_OUT ] = "THREAD_SWITCH_OUT",
> + [ RTEMS_RECORD_THREAD_TERMINATE ] = "THREAD_TERMINATE",
> + [ RTEMS_RECORD_UMA_ALLOC_PTR ] = "UMA_ALLOC_PTR",
> + [ RTEMS_RECORD_UMA_ALLOC_ZONE ] = "UMA_ALLOC_ZONE",
> + [ RTEMS_RECORD_UMA_FREE_PTR ] = "UMA_FREE_PTR",
> + [ RTEMS_RECORD_UMA_FREE_ZONE ] = "UMA_FREE_ZONE",
> + [ RTEMS_RECORD_UNLINK ] = "UNLINK",
> + [ RTEMS_RECORD_UNMOUNT ] = "UNMOUNT",
> + [ RTEMS_RECORD_UPTIME_HIGH ] = "UPTIME_HIGH",
> + [ RTEMS_RECORD_UPTIME_LOW ] = "UPTIME_LOW",
> + [ RTEMS_RECORD_WORKSPACE_ALLOC ] = "WORKSPACE_ALLOC",
> + [ RTEMS_RECORD_WORKSPACE_FREE ] = "WORKSPACE_FREE",
> + [ RTEMS_RECORD_WORKSPACE_SIZE ] = "WORKSPACE_SIZE",
> + [ RTEMS_RECORD_WORKSPACE_USAGE ] = "WORKSPACE_USAGE",
> + [ RTEMS_RECORD_WRITE ] = "WRITE",
> + [ RTEMS_RECORD_WRITEV ] = "WRITEV"
> + size_t n;
> + n = event;
> + if ( n < sizeof( event_text ) / sizeof( event_text[ 0 ] ) ) {
> + return event_text[ n ];
> + return NULL;
> diff --git a/cpukit/libmisc/record/record-userext.c
> b/cpukit/libmisc/record/record-userext.c
> index 0000000000..3d30620e5c
> --- /dev/null
> +++ b/cpukit/libmisc/record/record-userext.c
> @@ -0,0 +1,125 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#if HAVE_CONFIG_H
> +#endif
> +#include <rtems/score/thread.h>
> + rtems_record_produce(
> + created->Object.id
> + return true;
> + started->Object.id
> + restarted->Object.id
> + deleted->Object.id
> + rtems_record_item items[ 3 ];
> + items[ 0 ].event = RTEMS_RECORD_THREAD_SWITCH_OUT;
> + items[ 0 ].data = executing->Object.id;
> + items[ 1 ].event = RTEMS_RECORD_THREAD_STACK_CURRENT;
> + items[ 1 ].data =
> +#if defined(__GNUC__)
> + (uintptr_t) __builtin_frame_address( 0 )
> + - (uintptr_t) executing->Start.Initial_stack.area;
> +#else
> + 0;
> +#endif
> + items[ 2 ].event = RTEMS_RECORD_THREAD_SWITCH_IN;
> + items[ 2 ].data = heir->Object.id;
> + rtems_record_produce_n( items, RTEMS_ARRAY_SIZE( items ) );
> + executing->Object.id
> +void _Record_Thread_terminate( struct _Thread_Control *executing )
> diff --git a/cpukit/libmisc/record/record.c
> b/cpukit/libmisc/record/record.c
> index 0000000000..3f1751de1c
> --- /dev/null
> +++ b/cpukit/libmisc/record/record.c
> @@ -0,0 +1,132 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#if HAVE_CONFIG_H
> +#endif
> +#include <rtems/score/assert.h>
> data )
> + rtems_record_context context;
> + rtems_record_prepare( &context );
> + rtems_record_add( &context, event, data );
> + rtems_record_commit( &context );
> + rtems_record_add( &context, event_0, data_0 );
> + rtems_record_add( &context, event_1, data_1 );
> + size_t n
> + _Assert( n > 0 );
> + do {
> + rtems_record_add( &context, items->event, items->data );
> + ++items;
> + --n;
> + } while ( n > 0 );
> + uint32_t cpu_max;
> + tail = _Record_Tail( control );
> + head = _Atomic_Load_uint( &control->head, ATOMIC_ORDER_ACQUIRE );
> + if ( tail == head ) {
> + continue;
> + control->tail = head;
> + control->Header[ 0 ].event = RTEMS_RECORD_PROCESSOR;
> + control->Header[ 0 ].data = cpu_index;
> + control->Header[ 1 ].event = RTEMS_RECORD_TAIL;
> + control->Header[ 1 ].data = tail;
> + control->Header[ 2 ].event = RTEMS_RECORD_HEAD;
> + control->Header[ 2 ].data = head;
> + ( *visitor )( control->Header, RTEMS_ARRAY_SIZE( control->Header ),
> arg );
> + if ( _Record_Is_overflow( control, tail, head ) ) {
> + tail = head + 1;
> + tail = _Record_Index( control, tail );
> + head = _Record_Index( control, head );
> + if ( tail < head ) {
> + ( *visitor )( &control->Items[ tail ], head - tail, arg );
> + } else {
> + ( *visitor )( &control->Items[ tail ], control->mask + 1 - tail,
> arg );
> + if ( head > 0 ) {
> + ( *visitor )( &control->Items[ 0 ], head, arg );
> diff --git a/testsuites/libtests/Makefile.am
> b/testsuites/libtests/Makefile.am
> index 810f65db8e..765096c443 100644
> --- a/testsuites/libtests/Makefile.am
> +++ b/testsuites/libtests/Makefile.am
> @@ -994,6 +994,24 @@ realloc_norun_SOURCES = POSIX/realloc.c
> realloc_norun_LDADD = $(RTEMS_ROOT)cpukit/librtemsdefaultconfig.a $(LDADD)
> endif
> +if TEST_record01
> +lib_tests += record01
> +lib_screens += record01/record01.scn
> +lib_docs += record01/record01.doc
> +record01_SOURCES = record01/init.c
> +record01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_record01) \
> + $(support_includes) -I$(RTEMS_SOURCE_ROOT)/cpukit/libnetworking
> +endif
> +if TEST_record02
> +lib_tests += record02
> +lib_screens += record02/record02.scn
> +lib_docs += record02/record02.doc
> +record02_SOURCES = record02/init.c
> +record02_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_record02) \
> +endif
> if TEST_rtmonuse
> lib_tests += rtmonuse
> lib_screens += rtmonuse/rtmonuse.scn
> diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/
> configure.ac
> index a2a0df01f1..c76fb799b4 100644
> --- a/testsuites/libtests/configure.ac
> +++ b/testsuites/libtests/configure.ac
> @@ -189,6 +189,8 @@ RTEMS_TEST_CHECK([rbheap01])
> RTEMS_TEST_CHECK([read])
> RTEMS_TEST_CHECK([readv])
> RTEMS_TEST_CHECK([realloc])
> +RTEMS_TEST_CHECK([record01])
> +RTEMS_TEST_CHECK([record02])
> RTEMS_TEST_CHECK([rtmonuse])
> RTEMS_TEST_CHECK([setjmp])
> RTEMS_TEST_CHECK([sha])
> diff --git a/testsuites/libtests/record01/init.c
> b/testsuites/libtests/record01/init.c
> index 0000000000..f172332408
> --- /dev/null
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181219/91c461a5/attachment-0001.html>
