[PATCH] bsps/sparc: Add grlib_malloc(), grlib_calloc()
Daniel Hellstrom daniel at gaisler.com
Fri Dec 21 14:34:11 UTC 2018
On 2018-12-21 15:20, Sebastian Huber wrote:
> On 21/12/2018 15:18, Daniel Hellstrom wrote:
>> On 2018-12-21 15:12, Sebastian Huber wrote:
>>> On 21/12/2018 15:06, Daniel Hellstrom wrote:
>>>> On 2018-12-21 15:02, Sebastian Huber wrote:
>>>>> On 21/12/2018 14:59, Daniel Hellstrom wrote:
>>>>>> On 2018-12-21 14:57, Sebastian Huber wrote:
>>>>>>> Hello Daniel,
>>>>>>> On 21/12/2018 14:42, Daniel Hellstrom wrote:
>>>>>>>> Hi Sebastian,
>>>>>>>> Sorry for my very late response! I have reviewed the code but
>>>>>>>> not executed it, it looks okay with me. I'm guessing it is also
>>>>>>>> a positive thing to remove malloc for another approach to
>>>>>>>> allocate memory when it comes to validation of the SW.
>>>>>>> thanks for the review.
>>>>>>> My next step is to move the grlib to bsps/shared/grlib so that
>>>>>>> it can be used for RISC-V BSPs.
>>>>>> Great news! how will you do with the driver manager in this case,
>>>>>> will you add a connection between FDT and the driver manager via
>>>>>> FDT-bus driver? I think that would be of interest also for LEON,
>>>>>> I would be happy to review such a solution or similar one.
>>>>> Sorry, I don't have time to match the FDT with the driver manager.
>>>>> The libbsd has already this functionality. All I plan to do at the
>>>>> moment is to move the files and make them compile clean.
>>>> Okay, in the long-term do you think it is better to move to the
>>>> libbsd way than using the driver manager? The driver manager is
>>>> around 10k, and the required stuff around 5k on sparc if I recall
>>>> correctly. Do you have an idea how large the device discovery, etc.
>>>> is in libbsd?
>>> I don't have figures, but the libbsd is more for systems that
>>> provide RAM in quantities of 1MiBs and not 10KiBs.
>> Thats my assumption too, then we will stick with the driver manager.
>> However at some point we would want to add a GRETH_GBIT network
>> driver for the libbsd stack, maybe it is required for that particular
>> driver then, I don't know. I will have to dig into that at some point.
> The network stack interfaces are separate from the FreeBSD bus
> abstraction. You can use your driver manager and write a network
> interface driver for libbsd.
Ok, this was what I was hoping. Thanks!
