rtems-docs build failure
Sun Dec 23 22:16:43 UTC 2018
On 24/12/18 4:11 am, Joel Sherrill wrote:
> Chris... xindy
> [joel at localhost rtems]$ xindy
> xindy      xindy.run
> [joel at localhost rtems]$ type xindy
> xindy is /usr/local/texlive/2018/bin/x86_64-linux/xindy
> [joel at localhost rtems]$ echo $PATH
> /home/joel/.local/bin:/usr/local/texlive/2018/bin/x86_64-linux:/home/joel/rtems-work/tools/5/bin:/home/joel/rtems-work/rtems-testing/bin:/usr/lib/qt-3.3/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/bin:/home/joel/bin
Thanks. It looks like a build from source which installs this xindy command.
> Checking on one of the other machines, it has the same version of texlive so
> xindy is included. On holiday so can't check the other two installations. One of
> those for sure is older. I know I have sphinx-build 1.6 to 1.8 depending on the
> computer. But the texlive may not vary as much.
Yes I suspect it does not vary too much which is why I am confused by what I am
seeing. I cannot find much on the topic or I am not looking in the right spot.
