rtems-docs build failure
Joel Sherrill
joel at rtems.org
Sun Dec 23 22:35:06 UTC 2018
On Sun, Dec 23, 2018, 4:16 PM Chris Johns <chrisj at rtems.org wrote:
> On 24/12/18 4:11 am, Joel Sherrill wrote:
> > Chris... xindy
> > [joel at localhost rtems]$ xindy
> > xindy xindy.run
> > [joel at localhost rtems]$ type xindy
> > xindy is /usr/local/texlive/2018/bin/x86_64-linux/xindy
> > [joel at localhost rtems]$ echo $PATH
> /home/joel/.local/bin:/usr/local/texlive/2018/bin/x86_64-linux:/home/joel/rtems-work/tools/5/bin:/home/joel/rtems-work/rtems-testing/bin:/usr/lib/qt-3.3/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/bin:/home/joel/bin
> Thanks. It looks like a build from source which installs this xindy
> command.
I'm not building from source. I am installing the texlive binaries.
> > Checking on one of the other machines, it has the same version of
> texlive so
> > xindy is included. On holiday so can't check the other two
> installations. One of
> > those for sure is older. I know I have sphinx-build 1.6 to 1.8 depending
> on the
> > computer. But the texlive may not vary as much.
> Yes I suspect it does not vary too much which is why I am confused by what
> I am
> seeing. I cannot find much on the topic or I am not looking in the right
> spot.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181223/36c9d96a/attachment.html>
