Unstable RTEMS 6 tool chain?
    Joel Sherrill
    joel at rtems.org
    Wed Dec  5 12:25:19 UTC 2018
On Wed, Dec 5, 2018, 4:55 AM Sebastian Huber <
sebastian.huber at embedded-brains.de wrote:
> On 04/12/2018 04:37, Chris Johns wrote:
> > On 03/12/2018 17:45, Sebastian Huber wrote:
> >> what about adding an unstable RTEMS 6 tool chain to the RSB which is
> >> automatically updated weekly? I would like to test the Newlib,
> Binutils, GCC and
> >> GDB head regularly. I could set up a cron job to check out the Git
> master each
> >> Sunday (RTEMS, Newlib, Binutils, GCC and GDB), update the RSB, build
> the tools,
> >> run the tests on erc32. If everything goes well push the change to RSB,
> >> otherwise report the problem.
> > This sounds fantastic. If you want to place the scripts in
> > https://git.rtems.org/chrisj/rtems-admin.git/ please let me know and I
> can make
> > sure the perms are ok.
> Should I create new files in rtems/config/tools for each tool snapshot
> or should I create in rtems/config/tools something like this
> rtems-gdb-latest.cfg
> rtems-binutils-latest.cfg
> rtems-gcc-latest-newlib-latest.cfg
> which are updated?
I like this and we have the hashes.
Will this also periodically update the support libraries for GCC. Probably
by hand I guess as needed.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181205/f0192da6/attachment-0002.html>
