psxhdrs: Add POSIX Conformance Test fot fmtmsg.h (GCI 2018)
Shashvat Jain shashvatjain2002 at gmail.com
Thu Dec 6 19:19:46 UTC 2018
Noted. you did what i wanted to :)
its ok
On Fri, Dec 7, 2018 at 12:44 AM Joel Sherrill <joel.sherrill at gmail.com>
wrote:
> I think I merged the first one with corrections. If what's in git isn't
> right, submit a followup.
> Please make sure your copyright block isn't one space off the margin.
> Thanks.
> --joel
> On Thu, Dec 6, 2018 at 12:56 PM Shashvat Jain <shashvatjain2002 at gmail.com>
> wrote:
>> this is an updated patch. please  ignore the above one .
>> thank you
>> On Thu, Dec 6, 2018 at 1:34 PM Shashvat Jain <shashvatjain2002 at gmail.com>
>> wrote:
>>> Hello,
>>> The only test for the header file has been added with this patch ,
>>> but has been disabled due to the absence of fmtmsg.h header file.
>>> Updates #3639
>>> Thank you
>>> Regards
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181207/4f1b825a/attachment-0002.html>
