Status of smptests ...?
Jiri Gaisler jiri at gaisler.se
Tue Dec 11 21:08:28 UTC 2018
On 12/11/18 3:39 PM, Sebastian Huber wrote:
> Hello Jiri,
> On 11/12/2018 15:24, Sebastian Huber wrote:
>> Hello Jiri,
>> On 11/12/2018 15:15, Jiri Gaisler wrote:
>>> What is the status of the smptests of RTEMS 5 ?
>>> I have added SMP capability to the sis simulator, and have tested it
>>> with the smptests from rtems git. I have noticed that the reference
>>> output (*.scn) are not equivalent to what the simulator or real
>>> hardware
>>> outputs. It seems that the cpus are numbered backwards compared to the
>>> .scn files.
>> the .scn files are not up to date. Also the test output is quite test
>> dependent and repeated test runs my produce different output.
>> The best method to check if a test passed is to check if the
>> *** END OF TEST XYZ ***
>> message is printed. Which real target did you use to run the tests? I
>> will do a test run tomorrow on a N2X.
> attached is a run of the smptests on a N2X board.
Thanks, that helped. I can run all SMP tests successfully now on my FPGA
hardware. On the simulator, I have about 35 passed and 20 failed. Most
of the fails are hangs during initialization, I suspect a problem with
the MP interrupt controller or timer unit. I will keep you posted on the
progress. FYI, I have attached the log from the successful runs.
Jiri.
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smp01.exe -r
 SIS - SPARC instruction simulator 2.9,  copyright Jiri Gaisler 1995
 Bug-reports to jiri at gaisler.se
 LEON3 emulation enabled, 4 cpus online, delta 25 clocks
*** BEGIN OF TEST SMP 1 ***
*** TEST VERSION: 5.0.0.b7a1f9efadd928cda0f56123a1b6245b30b076fc-modified
*** TEST STATE: EXPECTED-PASS
*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB b4e80fb8e29c47fa970b5cdb815c26f1af4fd173, Newlib 2ab57ad59bc35dafffa69cd4da5e228971de069f)
 CPU 3 start task TA0
 CPU 2 running Task TA0
 CPU 3 start task TA1
 CPU 1 running Task TA1
 CPU 3 start task TA2
 CPU 0 running Task TA2
*** END OF TEST SMP 1 ***
 Stopped at time 26207800 (524.156 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smp02.exe -r
*** BEGIN OF TEST SMP 2 ***
 CPU 3 start task TA3
 CPU 1 Task TA3 Obtain
 CPU 1 Task TA3 Release
 CPU 0 Task TA4 Obtain
 CPU 0 Task TA4 Release
 CPU 2 Task TA2 Obtain
 CPU 2 Task TA2 Release
*** END OF TEST SMP 2 ***
 Stopped at time 11265575 (225.311 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smp03.exe -r
*** BEGIN OF TEST SMP 3 ***
  CPU 3 running task Init
  CPU 2 running task TA1
  CPU 1 running task TA2
  CPU 0 running task TA3
  CPU 0 running task TA4
*** END OF TEST SMP 3 ***
 Stopped at time 14968550 (299.371 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smp05.exe -r
*** BEGIN OF TEST SMP 5 ***
 CPU 1 start task TA1
Shut down from CPU 0
*** END OF TEST SMP 5 ***
 CPU 1 start task TA2
IU in error mode (128)
 11174575  40016a80  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smp08.exe -r
*** BEGIN OF TEST SMP 8 ***
  CPU 3 running task Init - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 2 running task TA01 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 0 running task TA03 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 2 running task TA04 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 2 running task TA06 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 2 running task TA07 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 2 running task TA08 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 2 running task TA10 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 1 running task TA02 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 2 running task TA11 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 1 running task TA12 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 3 running task TA09 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 0 running task TA05 - rtems_clock_get_tod 09:00:00   12/31/1988
  CPU 0 running task TA03 - rtems_clock_get_tod 09:00:14   12/31/1988
  CPU 0 running task TA05 - rtems_clock_get_tod 09:00:24   12/31/1988
  CPU 0 running task TA03 - rtems_clock_get_tod 09:00:29   12/31/1988
*** END OF TEST SMP 8 ***
 2250106050  40018340  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smp09.exe -r
*** BEGIN OF TEST SMP 9 ***
 kill 10 clock ticks
                              CPU USAGE BY THREAD
 ID         | NAME                                   | SECONDS       | PERCENT
 0x09010001 | IDLE                                   |      1.251427 |  99.948
 0x09010002 | IDLE                                   |      1.251265 |  99.920
 0x09010003 | IDLE                                   |      1.251104 |  99.893
 0x09010004 | IDLE                                   |      1.000089 |  79.840
 0x0a010001 | UI1                                    |      0.252690 |  20.170
 0x0a010002 | TA1                                    |      0.001855 |   0.148
 0x0a010003 | TA2                                    |      0.001869 |   0.149
 0x0a010004 | TA3                                    |      0.001881 |   0.150
 TIME SINCE LAST CPU USAGE RESET IN SECONDS:                          1.253312
*** END OF TEST SMP 9 ***
 Stopped at time 23818575 (476.372 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpaffinity01.exe -r
*** BEGIN OF TEST SMPAFFINITY 1 ***
Init - rtems_task_set_affinity - Lots of cpus - SUCCESS
Init - rtems_task_set_affinity - no cpu - RTEMS_INVALID_NUMBER
Init - rtems_task_set_affinity - Invalid thread - RTEMS_INVALID_ID
Init - rtems_task_set_affinity - Invalid cpusetsize - RTEMS_INVALID_NUMBER
Init - rtems_task_set_affinity - Invalid cpuset - RTEMS_INVALID_ADDRESS
Init - rtems_task_get_affinity - Invalid thread - RTEMS_INVALID_ID
Init - rtems_task_get_affinity - Invalid cpusetsize - RTEMS_INVALID_NUMBER
Init - rtems_task_get_affinity - Invalid cpuset - RTEMS_INVALID_ADDRESS
Init - Set Init priority to high
Init - Create Medium priority tasks
Init - Create  Low priority tasks
Init - Verify affinity on Low priority tasks
Init - Change affinity on Low priority tasks
Init - Validate affinity on Low priority tasks
*** END OF TEST SMPAFFINITY 1 ***
 Stopped at time 11296000 (225.920 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpcapture01.exe -r
*** BEGIN OF TEST SMPCAPTURE 1 ***
 2     0:00:00.001529999              0a010002 TA01   8   8   8   4096  TASK_RECORD
 3     0:00:00.001532999              0a010001 UI1    7   7   7   4096  TASK_RECORD
 2     0:00:00.001538999            0 0a010002 TA01   8   8             SWITCHED_IN
 3     0:00:00.001541999         3000 0a010001 UI1    7   7             STARTED_BY
 3     0:00:00.001550999         9000 0a010002 TA01   8   8             STARTED
 2     0:00:00.001566999        16000 0a010002 TA01   8   8             BEGIN
 3     0:00:00.001648999        82000 0a010001 UI1    7   7             CREATED_BY
 3     0:00:00.001664999              0a010003 TA02   5   5   5   4096  TASK_RECORD
 3     0:00:00.001674999        26000 0a010003 TA02   5   5             CREATED
 1     0:00:00.001735999        61000 0a010003 TA02   5   5             SWITCHED_IN
 3     0:00:00.001738999         3000 0a010001 UI1    7   7             STARTED_BY
 3     0:00:00.001748999        10000 0a010003 TA02   5   5             STARTED
 1     0:00:00.001764999        16000 0a010003 TA02   5   5             BEGIN
 3     0:00:00.001845999        81000 0a010001 UI1    7   7             CREATED_BY
 3     0:00:00.001861999              0a010004 TA03   6   6   6   4096  TASK_RECORD
 3     0:00:00.001871999        26000 0a010004 TA03   6   6             CREATED
 0     0:00:00.001932999        61000 0a010004 TA03   6   6             SWITCHED_IN
 3     0:00:00.001936999         4000 0a010001 UI1    7   7             STARTED_BY
 3     0:00:00.001945999         9000 0a010004 TA03   6   6             STARTED
 0     0:00:00.001961999        16000 0a010004 TA03   6   6             BEGIN
 3     0:00:00.002042999        81000 0a010001 UI1    7   7             CREATED_BY
 3     0:00:00.002058999              0a010005 TA04   9   9   9   4096  TASK_RECORD
 3     0:00:00.002068999            0 0a010005 TA04   9   9             CREATED
 3     0:00:00.002128999        60000 0a010001 UI1    7   7             STARTED_BY
 3     0:00:00.002138999        10000 0a010005 TA04   9   9             STARTED
 1     0:00:00.100059999     97921000 0a010003 TA02   5   5             SWITCHED_OUT
 1     0:00:00.100069999        10000 0a010005 TA04   4   4             SWITCHED_IN
 0     0:00:00.100094999        25000 0a010004 TA03   6   6             SWITCHED_OUT
 0     0:00:00.100103999         9000 0a010003 TA02   5   5             SWITCHED_IN
 2     0:00:00.100141999        38000 0a010002 TA01   8   8             SWITCHED_OUT
 3     0:00:00.100142999         1000 0a010001 UI1    7   7             SWITCHED_OUT
 1     0:00:00.100146999         4000 0a010005 TA04   4   4             BEGIN
 2     0:00:00.100150999         4000 0a010001 UI1    7   7             SWITCHED_IN
 3     0:00:00.100151999         1000 0a010004 TA03   6   6             SWITCHED_IN
 2     0:00:00.300088999    199937000 0a010001 UI1    7   7             SWITCHED_OUT
 2     0:00:00.300097999         9000 0a010002 TA01   7   7             SWITCHED_IN
 2     0:00:00.300120999        23000 0a010002 TA01   7   7             TERMINATED
 2     0:00:00.300207999        87000 0a010002 TA01   7   7             SWITCHED_OUT
 2     0:00:00.300216999         9000 0a010001 UI1    7   7             SWITCHED_IN
 0     0:00:00.300273999        57000 0a010003 TA02   5   5             TERMINATED
 2     0:00:00.300305999        32000 0a010001 UI1    7   7             SWITCHED_OUT
 2     0:00:00.300367999        62000 0a010001 UI1    7   7             SWITCHED_IN
 0     0:00:00.300369999         2000 0a010003 TA02   5   5             SWITCHED_OUT
 3     0:00:00.300423999        54000 0a010004 TA03   6   6             TERMINATED
 2     0:00:00.300455999            0 0a010001 UI1    7   7             SWITCHED_OUT
 3     0:00:00.300517999        62000 0a010004 TA03   6   6             SWITCHED_OUT
 3     0:00:00.300527999        10000 0a010001 UI1    7   7             SWITCHED_IN
 1     0:00:00.300585999        58000 0a010005 TA04   4   4             TERMINATED
 3     0:00:00.300615999        30000 0a010001 UI1    7   7             SWITCHED_OUT
 3     0:00:00.300680999        65000 0a010001 UI1    7   7             SWITCHED_IN
 1     0:00:00.300687999         7000 0a010005 TA04   4   4             SWITCHED_OUT
*** END OF TEST SMPCAPTURE 1 ***
 Stopped at time 28662175 (573.244 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpfatal03.exe -r
*** BEGIN OF TEST SMPFATAL 3 ***
*** END OF TEST SMPFATAL 3 ***
   597675  4000fa20  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpfatal04.exe -r
*** BEGIN OF TEST SMPFATAL 4 ***
*** END OF TEST SMPFATAL 4 ***
    58000  4000c640  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpfatal05.exe -r
*** BEGIN OF TEST SMPFATAL 5 ***
*** END OF TEST SMPFATAL 5 ***
 11119450  4000ede0  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpfatal06.exe -r
*** BEGIN OF TEST SMPFATAL 6 ***
*** END OF TEST SMPFATAL 6 ***
 Stopped at time 139925 (2.799 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpfatal08.exe -r
*** BEGIN OF TEST SMPFATAL 8 ***
*** END OF TEST SMPFATAL 8 ***
    58700  4000e960  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpmigration01.exe -r
*** BEGIN OF TEST SMPMIGRATION 1 ***
total cycles 1058483
average cycles 176413
runner 0
	cpu 0 tokens 88205
	cpu 0 cycles 176422
	cpu 0 cycle deviation 0.000051
	cpu 1 tokens 88204
	cpu 1 cycles 176407
	cpu 1 cycle deviation -0.000034
runner 1
	cpu 0 tokens 88204
	cpu 0 cycles 176402
	cpu 0 cycle deviation -0.000062
	cpu 1 tokens 88205
	cpu 1 cycles 176410
	cpu 1 cycle deviation -0.000017
runner 2
	cpu 0 tokens 88205
	cpu 0 cycles 176403
	cpu 0 cycle deviation -0.000057
	cpu 1 tokens 88204
	cpu 1 cycles 176439
	cpu 1 cycle deviation 0.000147
*** END OF TEST SMPMIGRATION 1 ***
 1011803750  40016920  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smppsxaffinity01.exe -r
*** BEGIN OF TEST SMPPSXAFFINITY 1 ***
Init - pthread_attr_setaffinity_np - Invalid attr - EINVAL
Init - pthread_attr_setaffinity_np - Invalid cpusetsize - EINVAL
Init - pthread_attr_setaffinity_np - Not initialized attr - EINVAL
Init - pthread_attr_getaffinity_np - Invalid attr - EINVAL
Init - pthread_attr_getaffinity_np - Invalid cpusetsize - EINVAL
Init - pthread_attr_getaffinity_np - Not initialized attr - EINVAL
Init - Validate pthread_attr_setaffinity_np and pthread_attr_getaffinity_np
*** END OF TEST SMPPSXAFFINITY 1 ***
 Stopped at time 203450 (4.069 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smppsxaffinity02.exe -r
*** BEGIN OF TEST SMPPSXAFFINITY 2 ***
Init - pthread_setaffinity_np - Lots of cpus - SUCCESS
Init - pthread_setaffinity_np - no cpu - EINVAL
Init - pthread_setaffinity_np - Invalid thread - ESRCH
Init - pthread_setaffinity_np - Invalid cpusetsize - EINVAL
Init - pthread_setaffinity_np - Invalid cpuset - EFAULT
Init - pthread_getaffinity_np - Invalid thread - ESRCH
Init - pthread_getaffinity_np - Invalid cpusetsize - EINVAL
Init - pthread_getaffinity_np - Invalid cpuset - EFAULT
Init - Verify Medium priority tasks
Init - Verify Low priority tasks
*** END OF TEST SMPPSXAFFINITY 2 ***
 Stopped at time 11285225 (225.704 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smppsxmutex01.exe -r
*** BEGIN OF TEST SMPPSXMUTEX 1 ***
*** END OF TEST SMPPSXMUTEX 1 ***
   183425  40013ea0  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smppsxsignal01.exe -r
*** BEGIN OF TEST SMPPSXSIGNAL 1 ***
*** END OF TEST SMPPSXSIGNAL 1 ***
 Stopped at time 158300 (3.166 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpschedaffinity01.exe -r
*** BEGIN OF TEST SMPSCHEDAFFINITY 1 ***
Set TA0 affinity to cpu 2
Start TA0 on cpu 2
Set TA1 affinity to cpu 0
Start TA1 on cpu 0
Set TA2 affinity to cpu 3
Start TA2 on cpu 3
Set TA3 affinity to cpu 1
Start TA3 on cpu 1
Verify Tasks Ran
TA00: ran=1 expected=2 actual=2
TA01: ran=1 expected=0 actual=0
TA02: ran=1 expected=3 actual=3
TA03: ran=1 expected=1 actual=1
*** END OF TEST SMPSCHEDAFFINITY 1 ***
 50124650  400131c0  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpschedaffinity02.exe -r
*** BEGIN OF TEST SMPSCHEDAFFINITY 2 ***
Create Semaphore
Create TA1
Init: expected=1 actual=1
TA01: expected=0 actual=0 ran=1
Set TA01 to cpu 0
Set TA01 to cpu 1
TA01: expected=1 actual=0 ran=0
Set Affinity of init task to cpu 0
Init: expected=0 actual=0
TA01: expected=1 actual=1 ran=1
*** END OF TEST SMPSCHEDAFFINITY 2 ***
 90650600  40014da0  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpschedaffinity03.exe -r
*** BEGIN OF TEST SMPSCHEDAFFINITY 3 ***
Set Affinity for cpu 3
On cpu 3
Set Affinity for cpu 2
On cpu 2
Set Affinity for cpu 1
On cpu 1
Set Affinity for cpu 0
On cpu 0
*** END OF TEST SMPSCHEDAFFINITY 3 ***
 200109700  40012140  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpschedaffinity04.exe -r
*** BEGIN OF TEST SMPSCHEDAFFINITY 4 ***
Create Semaphore
Start TA1
Verify Init task is on cpu 3
Set Affinity TA1 to cpu 0
TA1 expected cpu: 0 actual cpu 0
Set Affinity TA1 to cpu 1
TA1 expected cpu: 1 actual cpu 1
Set Affinity TA1 to cpu 2
TA1 expected cpu: 2 actual cpu 2
Set Affinity TA1 to cpu 3
TA1 expected cpu: 3 actual cpu 3
*** END OF TEST SMPSCHEDAFFINITY 4 ***
 Stopped at time 1018137375 (20362.748 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpschedaffinity05.exe -r
*** BEGIN OF TEST SMPSCHEDAFFINITY 5 ***
Create Semaphore
Start TA1 at priority 8 on cpu 2
Start TA2 at priority 5 on cpu 1
Start TA3 at priority 6 on cpu 0
Start TA4 at priority 9 on cpu -1
Verify Tasks Ran
Init(7): ran=1 expected=3 actual=3
TA01(8): ran=1 expected=2 actual=2
TA02(5): ran=1 expected=1 actual=1
TA03(6): ran=1 expected=0 actual=0
Set TA4 priority 4
Verify Tasks Ran
Init(7): ran=1 expected=2 actual=2
TA01(8): ran=0 expected=-1 actual=-1
TA02(5): ran=1 expected=0 actual=0
TA03(6): ran=1 expected=3 actual=3
*** END OF TEST SMPSCHEDAFFINITY 5 ***
 Stopped at time 1112663375 (22253.268 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpschededf01.exe -r
*** BEGIN OF TEST SMPSCHEDEDF 1 ***
                              CPU USAGE BY THREAD
 0x09010001 | IDLE                                   |      0.354256 |   9.419
 0x0a010001 | UI1                                    |      0.000843 |   0.022
 0x0a010002 | T1                                     |      1.903673 |  50.613
 0x0a010003 | T2                                     |      1.502219 |  39.938
 TIME SINCE LAST CPU USAGE RESET IN SECONDS:                          3.761344
Period information by period
--- CPU times are in seconds ---
--- Wall times are in seconds ---
   ID     OWNER COUNT MISSED          CPU TIME                  WALL TIME
                                    MIN/MAX/AVG                MIN/MAX/AVG
0x42010001 T1      75      0 0.025029/0.025040/0.025035 0.025031/0.030155/0.026691
0x42010002 T2      49      0 0.030029/0.030037/0.030031 0.050106/0.055251/0.052726
*** END OF TEST SMPSCHEDEDF 1 ***
 188339125  40016f80  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpschededf04.exe -r
*** BEGIN OF TEST SMPSCHEDEDF 4 ***
*** END OF TEST SMPSCHEDEDF 4 ***
   171325  40015d60  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpschedsem01.exe -r
*** BEGIN OF TEST SMPSCHEDSEM 01 ***
Init: priority 8 expected 8
Init: Obtain Semaphore
Init: priority 5 expected 5
Init: Release Semaphore
*** END OF TEST SMPSCHEDSEM 01 ***
   157350  40014440  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpscheduler01.exe -r
*** BEGIN OF TEST SMPSCHEDULER 1 ***
*** END OF TEST SMPSCHEDULER 1 ***
 Stopped at time 11185750 (223.715 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpscheduler02.exe -r
*** BEGIN OF TEST SMPSCHEDULER 2 ***
*** END OF TEST SMPSCHEDULER 2 ***
  1199750  4001f3e0  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpscheduler03.exe -r
*** BEGIN OF TEST SMPSCHEDULER 3 ***
*** END OF TEST SMPSCHEDULER 3 ***
   282450  400130c0  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpscheduler05.exe -r
*** BEGIN OF TEST SMPSCHEDULER 5 ***
*** END OF TEST SMPSCHEDULER 5 ***
   268850  400126c0  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpscheduler06.exe -r
*** BEGIN OF TEST SMPSCHEDULER 6 ***
*** END OF TEST SMPSCHEDULER 6 ***
   292950  40014b60  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpscheduler07.exe -r
*** BEGIN OF TEST SMPSCHEDULER 7 ***
*** END OF TEST SMPSCHEDULER 7 ***
   277900  40017360  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpswitchextension01.exe -r
*** BEGIN OF TEST SMPSWITCHEXTENSION 1 ***
toggler 0
	toggles 642764
toggler 1
	toggles 642763
extension 0
	context switches 660189
extension 1
	context switches 626136
extension 2
	context switches 625061
extension switches 346969
*** END OF TEST SMPSWITCHEXTENSION 1 ***
 Stopped at time 1899141150 (37982.823 ms)
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpthreadlife01.exe -r
*** BEGIN OF TEST SMPTHREADLIFE 1 ***
*** END OF TEST SMPTHREADLIFE 1 ***
 30962175  40016f40  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpthreadpin01.exe -r
*** BEGIN OF TEST SMPTHREADPIN 1 ***
test simple wait unpin (run 1)
test pin wait unpin (blocked, run 1)
test pin wait unpin (ready, run 1)
test pin preempt unpin (blocked, run 1)
test pin preempt unpin (ready, run 1)
test simple wait unpin (run 2)
test pin wait unpin (blocked, run 2)
test pin wait unpin (ready, run 2)
test pin preempt unpin (blocked, run 2)
test pin preempt unpin (ready, run 2)
test simple wait unpin (run 3)
test pin wait unpin (blocked, run 3)
test pin wait unpin (ready, run 3)
test pin preempt unpin (blocked, run 3)
test pin preempt unpin (ready, run 3)
reconfigure scheduler
test pin home no help unpin (blocked, run 1)
test pin home no help unpin (ready, run 1)
test pin foreign no help unpin (blocked, run 1)
test pin foreign no help unpin (ready, run 1)
test pin home no help unpin (blocked, run 2)
test pin home no help unpin (ready, run 2)
test pin foreign no help unpin (blocked, run 2)
test pin foreign no help unpin (ready, run 2)
test pin home no help unpin (blocked, run 3)
test pin home no help unpin (ready, run 3)
test pin foreign no help unpin (blocked, run 3)
test pin foreign no help unpin (ready, run 3)
*** END OF TEST SMPTHREADPIN 1 ***
 11992900  40017980  91d02000  ta  0
./sim/erc32/sis -mp 4 /home/jiri/smptests.ok/smpunsupported01.exe -r
*** BEGIN OF TEST SMPUNSUPPORTED 1 ***
*** END OF TEST SMPUNSUPPORTED 1 ***
 Stopped at time 141550 (2.831 ms)
