[PATCH] rtems-docs: Eliminate UTF-8 characters, PDF still broken
Joel Sherrill
joel at rtems.org
Thu Dec 20 13:19:07 UTC 2018
I don't disagree but there was a suspicion it was related to building PDF.
Until PDF is building again, let's keep them out.
Once PDFs are coming out again, feel free to revert or figure out how to
do a superscript for the i2c. For names, utf8 should be ok if we can
produce PDFs reliably and correctly across the various hosts.
On Thu, Dec 20, 2018, 1:24 AM Sebastian Huber <
sebastian.huber at embedded-brains.de wrote:
> Hello Joel,
> I don't think we should remove ALL the UTF-8 characters. I would like to
> be able to properly mention authors in the bibliography. I worked well
> for example for the RTEMS BSP and Driver Guide so far:
> https://docs.rtems.org/branches/master/bsp-howto.pdf
> I use UTF-8 for all my Latex document sources. Not everything is English
> text in the world.
> The problem in the new manual was the Unicode character (U+200B) which
> your command line hasn't found:
> https://git.rtems.org/rtems-docs/commit/?id=e24c5e9682ee4d85474cbd326d25e99f0207731c
> The special " and ' characters should be fixed, but the I²C is fine from
> my point of view.
> find . -name "*.rst" | xargs -e file | grep Unicode | cut -d':' -f1
> | xargs -e grep --color='auto' -P -n '[^\x00-\x7F]'
> ./bsp-howto/i2c.rst:9:The Inter-Integrated Circuit (I2C, I²C, IIC) bus
> drivers should use the
> ./eng/test-plan.rst:24:“fully tested.” A fully tested requirement is one
> which is implemented
> ./eng/vc-users.rst:387:of the two branches, stores each commit of the
> branch you’re on to temporary
> ./eng/license-requirements.rst:12:for documentation and “Two Paragraph
> BSD” for source code.
> ./eng/appendix-a.rst:12:by a mission as a baselined starting point for
> “pre-qualification”
> ./eng/appendix-a.rst:129: | Usability | Software User’s |
> The Software User Manual |
> ./eng/appendix-a.rst:136:that encompasses the artifacts’ intents. The
> idea is that this living
> ./eng/vc-authors.rst:28:account on dispatch.rtems.org one should be
> requested on the devel@… list.
> ./eng/vc-authors.rst:45:master repository generate email to the vc@…
> list and development type commits
> ./eng/prequalification.rst:17:change process, coding style, testing
> requirements, and a user’s
> ./eng/prequalification.rst:18:manual. During system test, these
> standards call for a review – usually
> ./eng/prequalification.rst:19:by an independent entity – that the
> standard has been adhered too. These
> ./eng/prequalification.rst:23:term “qualification” independent of the
> standard.
> ./eng/prequalification.rst:39:“pre-qualification”. True qualification
> must be performed on the
> ./eng/prequalification.rst:40:project’s target hardware in a system
> context. The FAA has provided
> ./eng/prequalification.rst:56:term “resources” is often used by open
> source projects to refer to
> ./eng/prequalification.rst:77:qualification standards. It will maintain
> “scorecards” which
> ./eng/users-manuals.rst:12:Reference the RTEMS C User’s Manual
> ./user/tracing/introduction.rst:43:Step 2: The RTEMS Trace Linker reads
> the user’s configuration file and that
> ./user/tracing/introduction.rst:47:wraps the functions defined in the
> user’s configuration with code that captures
> ./user/tracing/introduction.rst:56:Step 4: RTEMS shell provides the
> “rtrace” command to display and save trace
> ./user/tracing/examples.rst:59:fileio’s executable and object files in
> the last line of the command according
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181220/22e656e6/attachment-0002.html>
