Contribute to project
Abhinav Jain jainab.2009 at gmail.com
Tue Feb 6 15:23:18 UTC 2018
Sir,
I have studied about SASOS. It's really a great approach to make the
process faster by avoiding multiple copies of the data. I read about two
SASOS namely Angel system(developed at City University, London) and Mungi
system(developed by University of New South Wales, Australia). I also
studied about Memory Protection in SASOS, where the concept of address
protection is replaced by protection domain. I studied about
Multithreading, POSIX, Race condition and Synchronization to avoid the Race
condition.
Please guide me, am I  on the right path and what all do I need to learn
further?
Thanks and Regards
Abhinav Jain
On Wed, Jan 31, 2018 at 11:17 PM, Abhinav Jain <jainab.2009 at gmail.com>
wrote:
> Sir,
> Thanks for the guidance. The mail is very informative and I will follow
> the way suggested by you.
> Thanks and regards
> Abhinav Jain
> On Jan 31, 2018 5:41 PM, "Sebastian Huber" <sebastian.huber at embedded-
> brains.de> wrote:
>> The MMU support is a very challenging project. The scope of the project
>> and potential use cases must be determined. You need a lot of experience to
>> design good APIs and it helps if you know the APIs for this kind of stuff
>> on other systems like QNX, Linux, FreeBSD, etc. For the architecture
>> support a lot of background knowledge is required at least on PowerPC,
>> ARMv5..8, SPARC, Nios2, MIPS, etc. For example, changing the TLB1 based MMU
>> during application run-time on PowerPC (including SMP support, cache
>> consistency) is not easy. There are some optimization problems involved if
>> you want to determine a good cover with memory areas (alignment
>> restrictions, limited number of areas in the MMU/MPU if not page based,
>> e.g. 16).
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim,+Germany&entry=gmail&source=g>
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180206/502c1587/attachment.html>
