Contribute to project
Abhinav Jain
jainab.2009 at gmail.com
Tue Feb 13 05:20:20 UTC 2018
Sir,
Thanks for the guidance. I will study the code available and will try to
resolve the issue as soon as possible.
Thanks and Regards
Abhinav Jain
On Tue, Feb 13, 2018 at 4:47 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 13/02/2018 06:05, Gedare Bloom wrote:
> > Abhinav,
> > Attempt to reproduce the reported problem, try out the patch and see
> > if it works. I see this was reported for 4.10. See if the problem also
> > affects 4.11, master, and if the fix works for them too.
> I suspect it is common to all branches.
> > On Mon, Feb 12, 2018 at 11:55 AM, Abhinav Jain <jainab.2009 at gmail.com>
> wrote:
> >> Sir,
> >> I have gone through the projects available in the link provided by you
> and I
> >> am interested in an issue (RSB can sometimes change the wrong local git
> >> repository (includes a fix).) listed there.
> >> Link: https://devel.rtems.org/ticket/2522#no1
> >> I request you to please provide some more information regarding this so
> that
> >> I can proceed with the coding part.
> As Gedare suggests take a look at the master and 4.11 branches and if
> present
> work I suggest you work on the master branch and then we can take git.py
> and
> back port to 4.11 and 4.10 by simply coping git.py to those branches.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180213/9617e9ce/attachment.html>
