Contribute to project
Mon Feb 12 23:17:30 UTC 2018
On 13/02/2018 06:05, Gedare Bloom wrote:
> Abhinav,
> Attempt to reproduce the reported problem, try out the patch and see
> if it works. I see this was reported for 4.10. See if the problem also
> affects 4.11, master, and if the fix works for them too.
I suspect it is common to all branches.
> On Mon, Feb 12, 2018 at 11:55 AM, Abhinav Jain <jainab.2009 at gmail.com> wrote:
>> Sir,
>> I have gone through the projects available in the link provided by you and I
>> am interested in an issue (RSB can sometimes change the wrong local git
>> repository (includes a fix).) listed there.
>> Link: https://devel.rtems.org/ticket/2522#no1
>> I request you to please provide some more information regarding this so that
>> I can proceed with the coding part.
As Gedare suggests take a look at the master and 4.11 branches and if present
work I suggest you work on the master branch and then we can take git.py and
back port to 4.11 and 4.10 by simply coping git.py to those branches.
