[PATCH v2 2/5] powerpc/shared/startup/linkcmds.base: Add wildcards on some sections
Joel Sherrill
joel at rtems.org
Tue Feb 20 14:49:05 UTC 2018
On Tue, Feb 20, 2018 at 8:10 AM, Sebastian Huber <
> Hello Joel,
> for which sections is this patch? Do you have a code example and a GCC
> command line to create one of these sections?
Honestly I have been carrying that patch for 6 months and can't remember.
On top of that, right now, we are using a custom linkcmds since I couldn't
get the segments to be properly aligned for the virtual environment. I want
to revisit it.
The only real difference should be that the code is compiled with -fPIC
which we I doubt anyone has ever tried.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180220/9cc4c2a3/attachment.html>
