want to contribute to project
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon Feb 26 16:24:17 UTC 2018
Thank you for giving me a detailed introduction to the project objectives
and mentors.
I am interested in # 2920: "Improve Coverage analysis toolkit".
Please guide me with the resources to get started with the project and get
a deep understanding.
Thank you
Vijay
On 26 February 2018 at 15:36, Joel Sherrill <joel at rtems.org> wrote:
> On Feb 26, 2018 2:22 AM, "Christian Mauderer" <
> christian.mauderer at embedded-brains.de> wrote:
> Am 24.02.2018 um 16:21 schrieb Vijay Kumar Banerjee:
> > Hello,
> > As told by Joel, I sent the screenshots of my working hello world to his
> > personal email and have also included my name in the GSoC tracking page .
> > + Make Eclipse Target Interaction work with RTEMS
> > (https://www.eclipse.org/tcf/)
> > + Improvements to our coverage reporting. GCOV validation and covoar
> > reporting improvements
> > + wifi integration improvements
> > + aarch64 port
> > + x86_64 port / non-legacy PC BSP
> > - This project is large so we would need to work with whoever wants
> > to tackle it
> > to find the best subset for GSoC.
> > Based on this list I went through the OpenProjects page
> > and came across the following Tickets .,
> > #2920 ,#3222,#2927 and the link to eclipse tcf .
> > out of them , I find these interesting
> > 1. "Improve coverage Analysis Toolset " (#2920);
> This area is mine. The ticket mat or may not be a great description of the
> goals. There are probably three things that need to be done.
> + Integrate ran recipes for Couverture variant of qemu. This might be a
> very small task. Last year's student just didn't get this integrated and
> was waiting for some patches to be merged on their side.
> + Verify the gcov output from covoar is correct and the gcov (and similar
> tools) matches the coverage reports it generates. We have someone from the
> GCC community to help mentor here.
> + Covoar generates HTML and text output directly. There is a desire for it
> to generate something equally useful that is processed by existing tools to
> generate reports. One possible option for this output could be Sphinx like
> our regular documentation. Or it could be a data-centric format processed
> by other tools. The current HTML allows filtering and sorting so not losing
> information and ease of use is important. This probably will end up
> simplifying C++ and adding Python.
> > 2. "libbsd:WiFi support needs rc.conf integration " (#3222)
> Christian's project to mentor.
> > also I came across # 3302 :" Build system conversion of BSP Config(.cfg)
> > files to pkg-config(.pc) files"
> > (I have some knowledge of Python, but not proficient in it, I can learn
> > it better if it's required )
> > which I find interesting
> This one is Chris Johns project to mentor. It is an important and
> logically the next step in replacing our build system with the Python based
> waf. If you get through this one before the summer is out, then working on
> waf would probably make sense.
> Did I miss one?
> Hello Vijay,
> all of the projects would be good ones.
> The #2920 and #3302 are more connected to the host tools. They should be
> doable with few or no real hardware. But you should ask the two
> potential mentors about that.
> For the #3222 you would need some board supported by the libbsd (like
> Beagle Bone Black) and I would suggest a JTAG debugger (some OpenOCD
> based or similar).
> > Am I following the right tickets? If not please help me find the right
> ones.
> The tickets are the right ones.
> > Out of these , which one do you recommend me to take ?
> I would recommend to take a more detailed look at the tickets and start
> to ask some questions about it on the mailing list with CC to the
> (potential) mentors.
> Maybe you could also try to find some small tickets related to similar
> topics and just try to work on these. That could help you find out what
> you want to do.
> > My experience with C/C++ : I am proficient in C++11 with STL . Also
> > proficient in C language .
> > My experience with opensource : This is the first open source project
> > I'm taking up .
> It's no problem if it's your first Open Source project. That's the point
> of GSoC: To collect first Open Source experience.
> Best regards
> Christian Mauderer
> > Thank you ,
> > Vijay K.
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> <https://maps.google.com/?q=Dornierstr.+4+%0D+D-82178+Puchheim+%0D+Germany&entry=gmail&source=g>
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180226/84010792/attachment-0001.html>
