GCC 8 PowerPC Argument Changes
dufault at hda.com
dufault at hda.com
Sun Feb 11 18:24:43 UTC 2018
I should be following the status of the SPE support but haven’t, it’s an important platform for one of my clients. A little googling doesn’t make it clear how well the support is moving in to GCC 8, I only found again that it would be a new target. Hopefully someone following GCC on the list has been paying attention to this and knows whether or not it’s really being supported.
> On Feb 11, 2018, at 12:08 , Joel Sherrill <joel at rtems.org> wrote:
> On Feb 11, 2018 11:29 AM, "Peter Dufault" <dufault at hda.com <mailto:dufault at hda.com>> wrote:
> What’s the context where -mno-spe is used? The last time I followed this the SPE support in the powerpc target was to be discontinued and a powerpcspe target was to be introduced.
> It is in one of the PowerPC BSP family variants.
> I don't know the state of SPE support in GCC but guess I need to ask.
> I suppose we just move the arguments to match GCC 8 when the RSB bumps to that.
>> On Feb 9, 2018, at 16:17 , Joel Sherrill <joel at rtems.org <mailto:joel at rtems.org>> wrote:
>> Hi
>> I am using GCC 8 to test my bsp_specs changes. On the
>> powerpc -mno-spe is gone.
>> I don't know of a case where we have a BSP that checks
>> if GCC supports an argument or not. I think we have just
>> changed the custom file when we upgraded GCC.
>> Any thoughts on the correct argument or better approach
>> than just to change the custom file when we bump GCC?
>> Thanks.
>> devel mailing list
>> devel at rtems.org <mailto:devel at rtems.org>
>> http://lists.rtems.org/mailman/listinfo/devel <http://lists.rtems.org/mailman/listinfo/devel>
> Peter
> Peter Dufault
> HD Associates, Inc. Software and System Engineering
> This email is delivered through the public internet using protocols subject to interception and tampering.
Peter
Peter Dufault
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180211/68bfdcfe/attachment-0002.html>
