[PATCH 3/9] network/bootp: PR2031: Add and use header file
Thu Jan 11 18:13:05 UTC 2018
From: Sebastien Bourdeauducq <sebastien at milkymist.org>
 cpukit/libnetworking/Makefile.am                   |  1 +
 cpukit/libnetworking/nfs/bootp_subr.c              | 16 ++-------
 cpukit/libnetworking/rtems/bootp.h                 | 41 ++++++++++++++++++++++
 cpukit/libnetworking/rtems/rtems_bootp.c           |  2 ++
 cpukit/libnetworking/rtems/rtems_bsdnet_internal.h |  1 -
 cpukit/libnetworking/rtems/rtems_dhcp.c            | 26 +++-----------
 6 files changed, 50 insertions(+), 37 deletions(-)
 create mode 100644 cpukit/libnetworking/rtems/bootp.h
diff --git a/cpukit/libnetworking/Makefile.am b/cpukit/libnetworking/Makefile.am
index 54f144f..7f2481c 100644
--- a/cpukit/libnetworking/Makefile.am
+++ b/cpukit/libnetworking/Makefile.am
@@ -8,6 +8,7 @@ include $(top_srcdir)/automake/compile.am
 AM_CPPFLAGS += -I$(srcdir)
 EXTRA_DIST = README
+EXTRA_DIST += rtems/bootp.h
 # poll is not supported
 UNUSED_FILES = poll.h
diff --git a/cpukit/libnetworking/nfs/bootp_subr.c b/cpukit/libnetworking/nfs/bootp_subr.c
index e976227..5375b66 100644
--- a/cpukit/libnetworking/nfs/bootp_subr.c
+++ b/cpukit/libnetworking/nfs/bootp_subr.c
@@ -74,6 +74,8 @@
 #include <rtems/bsdnet/servers.h>
 #include <inttypes.h>
+#include "rtems/bootp.h"
 #define BOOTP_MIN_LEN		300	/* Minimum size of bootp udp packet */
@@ -138,20 +140,6 @@ void bootpboot_p_rtlist(void);
 void bootpboot_p_iflist(void);
 #endif
-int  bootpc_call(struct bootp_packet *call,
-		 struct bootp_packet *reply,
-		 struct proc *procp);
-int bootpc_fakeup_interface(struct ifreq *ireq,struct socket *so,
-int
-bootpc_adjust_interface(struct ifreq *ireq,struct socket *so,
-			struct sockaddr_in *myaddr,
-			struct sockaddr_in *netmask,
-			struct sockaddr_in *gw,
 #ifdef BOOTP_DEBUG
 void
 bootpboot_p_sa(struct sockaddr *sa, struct sockaddr *ma)
diff --git a/cpukit/libnetworking/rtems/bootp.h b/cpukit/libnetworking/rtems/bootp.h
new file mode 100644
index 0000000..d8eeb76
--- /dev/null
+++ b/cpukit/libnetworking/rtems/bootp.h
@@ -0,0 +1,41 @@
+/* Subroutines from cpukit/libnetworking/nfs/bootp_subr.c */
+#if !defined (__RTEMS_BOOTP_H__)
+#define __RTEMS_BOOTP_H__
+#include <stdbool.h>
+#if __cplusplus
+extern "C"
+#endif
+struct bootp_packet;
+struct proc;
+struct ifreq;
+struct socket;
+struct sockaddr_in;
+bool bootpc_init(bool, bool);
+int bootpc_call(
+     struct bootp_packet *call,
+     struct bootp_packet *reply,
+     struct proc *procp);
+int bootpc_fakeup_interface(struct ifreq *ireq,
+                                    struct socket *so,
+int bootpc_adjust_interface(struct ifreq *ireq,
+                                    struct sockaddr_in *myaddr,
+                                    struct sockaddr_in *netmask,
+                                    struct sockaddr_in *gw,
+void *bootp_strdup_realloc(char *dst, const char *src);
+#if __cplusplus
+#endif
+#endif
diff --git a/cpukit/libnetworking/rtems/rtems_bootp.c b/cpukit/libnetworking/rtems/rtems_bootp.c
index caf2faa..6a644a4 100644
--- a/cpukit/libnetworking/rtems/rtems_bootp.c
+++ b/cpukit/libnetworking/rtems/rtems_bootp.c
@@ -12,6 +12,8 @@
 #include <rtems/rtems_bsdnet_internal.h>
  * Perform a BOOTP request
diff --git a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h b/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
index a22a223..8c9ab04 100644
--- a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
+++ b/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
@@ -179,7 +179,6 @@ void domaininit (void *);
 void ifinit (void *);
 void ipintr (void);
 void arpintr (void);
-bool bootpc_init(bool, bool);
 int socket (int, int, int);
 int ioctl (int, ioctl_command_t, ...);
diff --git a/cpukit/libnetworking/rtems/rtems_dhcp.c b/cpukit/libnetworking/rtems/rtems_dhcp.c
index f71d83e..d941ee8 100644
--- a/cpukit/libnetworking/rtems/rtems_dhcp.c
+++ b/cpukit/libnetworking/rtems/rtems_dhcp.c
@@ -99,6 +99,7 @@
 #include <rtems/mkrootfs.h>
 #include "rtems/dhcp.h"
 #ifndef EALEN
 #define EALEN 6
@@ -167,25 +168,6 @@ struct dhcp_packet
- * External Declarations for Functions found in
- * rtems/c/src/libnetworking/nfs/
-extern int bootpc_call (struct dhcp_packet *call,
-                        struct dhcp_packet *reply,
-extern int bootpc_fakeup_interface (struct ifreq *ireq,
-                                    struct socket *so,
-extern int bootpc_adjust_interface (struct ifreq *ireq,
-extern void *bootp_strdup_realloc (char *dst,
-                                   const char *src);
  * Variables
 static int                dhcp_option_overload = 0;
@@ -757,7 +739,7 @@ dhcp_task (rtems_task_argument _sdl)
        * Send the Request.
-      error = bootpc_call (&call, &dhcp_req, procp);
+      error = bootpc_call ((struct bootp_packet *)&call, (struct bootp_packet *)&dhcp_req, procp);
       if (error) {
         rtems_bsdnet_semaphore_release ();
         printf ("DHCP call failed -- error %d", error);
@@ -963,7 +945,7 @@ dhcp_init (int update_files)
    * Send the Discover.
-  error = bootpc_call (&call, &reply, procp);
+  error = bootpc_call ((struct bootp_packet *)&call, (struct bootp_packet *)&reply, procp);
   if (error) {
     printf ("BOOTP call failed -- %s\n", strerror(error));
     soclose (so);
@@ -992,7 +974,7 @@ dhcp_init (int update_files)
   dhcp_request_req (&call, &reply, sdl, true);
   if (error) {
     soclose (so);
2.7.4
