[PATCH 4/9] librpc: PR2066: Fix for short enums
Thu Jan 11 18:13:06 UTC 2018
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
The XDR library has a problem on architectures with short enums like the
default ARM EABI.  Short enums means that the size of the enum type is
variable and the smallest integer type to hold all enum values will be
selected.  For many enums this is char.  The XDR library uses int32_t
for enum_t.  There are several evil casts from an enum type to enum_t
which leads to invalid memory accesses on short enum architectures.  A
workaround is to add appropriate dummy enum values.
 cpukit/librpc/include/rpc/auth.h       |  3 ++-
 cpukit/librpc/include/rpc/clnt_stat.h  |  3 ++-
 cpukit/librpc/include/rpc/rpc_msg.h    | 12 ++++++++----
 cpukit/librpc/include/rpc/svc.h        |  3 ++-
 cpukit/librpc/include/rpcsvc/nis_db.h  |  6 ++++--
 cpukit/librpc/include/rpcsvc/yp_prot.h |  3 ++-
 cpukit/librpc/src/xdr/xdr.c            |  8 +++-----
 7 files changed, 23 insertions(+), 15 deletions(-)
diff --git a/cpukit/librpc/include/rpc/auth.h b/cpukit/librpc/include/rpc/auth.h
index f644532..8f5273b 100644
--- a/cpukit/librpc/include/rpc/auth.h
+++ b/cpukit/librpc/include/rpc/auth.h
@@ -66,7 +66,8 @@ enum auth_stat {
 	 * failed locally
 	AUTH_INVALIDRESP=6,		/* bogus response verifier */
-	AUTH_FAILED=7			/* some unknown reason */
+	AUTH_FAILED=7,			/* some unknown reason */
+	_AUTH_STAT = 0xffffffff
 union des_block {
diff --git a/cpukit/librpc/include/rpc/clnt_stat.h b/cpukit/librpc/include/rpc/clnt_stat.h
index 397bdbc..2c68745 100644
--- a/cpukit/librpc/include/rpc/clnt_stat.h
+++ b/cpukit/librpc/include/rpc/clnt_stat.h
@@ -73,7 +73,8 @@ enum clnt_stat {
 	RPC_STALERACHANDLE = 25,
 	RPC_CANTCONNECT = 26,		/* couldn't make connection (cots) */
 	RPC_XPRTFAILED = 27,		/* received discon from remote (cots) */
-	RPC_CANTCREATESTREAM = 28	/* can't push rpc module (cots) */
+	RPC_CANTCREATESTREAM = 28,	/* can't push rpc module (cots) */
+	_CLNT_STAT = 0xffffffff
 #ifdef __cplusplus
diff --git a/cpukit/librpc/include/rpc/rpc_msg.h b/cpukit/librpc/include/rpc/rpc_msg.h
index 21fcb84..c2f3304 100644
--- a/cpukit/librpc/include/rpc/rpc_msg.h
+++ b/cpukit/librpc/include/rpc/rpc_msg.h
@@ -56,12 +56,14 @@
 enum msg_type {
 	CALL=0,
-	REPLY=1
+	REPLY=1,
+	_MSG_TYPE = 0xffffffff
 enum reply_stat {
 	MSG_ACCEPTED=0,
-	MSG_DENIED=1
+	MSG_DENIED=1,
+	_REPLY_STAT = 0xffffffff
 enum accept_stat {
@@ -70,12 +72,14 @@ enum accept_stat {
 	PROG_MISMATCH=2,
 	PROC_UNAVAIL=3,
 	GARBAGE_ARGS=4,
-	SYSTEM_ERR=5
+	SYSTEM_ERR=5,
+	_ACCEPT_STAT = 0xffffffff
 enum reject_stat {
 	RPC_MISMATCH=0,
-	AUTH_ERROR=1
+	AUTH_ERROR=1,
+	_REJECT_STAT = 0xffffffff
diff --git a/cpukit/librpc/include/rpc/svc.h b/cpukit/librpc/include/rpc/svc.h
index f7c6ebd..30fc4f7 100644
--- a/cpukit/librpc/include/rpc/svc.h
+++ b/cpukit/librpc/include/rpc/svc.h
@@ -66,7 +66,8 @@
 enum xprt_stat {
 	XPRT_DIED,
 	XPRT_MOREREQS,
-	XPRT_IDLE
+	XPRT_IDLE,
+	_XPRT_STAT = 0xffffffff
 struct rpc_msg;
diff --git a/cpukit/librpc/include/rpcsvc/nis_db.h b/cpukit/librpc/include/rpcsvc/nis_db.h
index dbdee5a..71785b0 100644
--- a/cpukit/librpc/include/rpcsvc/nis_db.h
+++ b/cpukit/librpc/include/rpcsvc/nis_db.h
@@ -69,7 +69,8 @@ enum db_status {
 	DB_BADOBJECT = 5,
 	DB_MEMORY_LIMIT = 6,
 	DB_STORAGE_LIMIT = 7,
-	DB_INTERNAL_ERROR = 8
+	DB_INTERNAL_ERROR = 8,
+	_DB_STATUS = 0xffffffff
 typedef enum db_status db_status;
@@ -80,7 +81,8 @@ enum db_action {
 	DB_FIRST = 3,
 	DB_NEXT = 4,
 	DB_ALL = 5,
-	DB_RESET_NEXT = 6
+	DB_RESET_NEXT = 6,
+	_DB_ACTION = 0xffffffff
 typedef enum db_action db_action;
diff --git a/cpukit/librpc/include/rpcsvc/yp_prot.h b/cpukit/librpc/include/rpcsvc/yp_prot.h
index 5abe0e2..f29f3ce 100644
--- a/cpukit/librpc/include/rpcsvc/yp_prot.h
+++ b/cpukit/librpc/include/rpcsvc/yp_prot.h
@@ -233,7 +233,8 @@ struct dom_binding {
 /* error code in ypbind_resp.ypbind_status */
 enum ypbind_resptype {
 	YPBIND_SUCC_VAL = 1,
-	YPBIND_FAIL_VAL = 2
+	YPBIND_FAIL_VAL = 2,
+	_YPBIND_RESPTYPE = 0xffffffff
 /* network order, of course */
diff --git a/cpukit/librpc/src/xdr/xdr.c b/cpukit/librpc/src/xdr/xdr.c
index 02631e6..80c29bb 100644
--- a/cpukit/librpc/src/xdr/xdr.c
+++ b/cpukit/librpc/src/xdr/xdr.c
@@ -458,16 +458,14 @@ xdr_enum(
 	enum_t *ep)
 #ifndef lint
-	enum sizecheck { SIZEVAL };	/* used to find the size of an enum */
 	 * enums are treated as ints
-	if (sizeof (enum sizecheck) == sizeof (long)) {
+	if (sizeof (enum_t) == sizeof (long)) {
 		return (xdr_long(xdrs, (long *)ep));
-	} else if (sizeof (enum sizecheck) == sizeof (int)) {
+	} else if (sizeof (enum_t) == sizeof (int)) {
 		return (xdr_int(xdrs, (int *)ep));
-	} else if (sizeof (enum sizecheck) == sizeof (short)) {
+	} else if (sizeof (enum_t) == sizeof (short)) {
 		return (xdr_short(xdrs, (short *)ep));
 	} else {
 		return (FALSE);
2.7.4
