Hello World patch
Vidushi Vashishth reachvidu at gmail.com
Wed Jan 17 06:06:57 UTC 2018
Hello!
I sent the patch to Gedare Bloom. The student tracking table is not
editable yet I think. Thanks for the list of projects. I will shortly get
back to you on which project I would contribute to.
Best,
Vidushi
On Tue, Jan 16, 2018 at 3:05 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Jan 15, 2018 at 2:20 PM, Christian Mauderer <
> christian.mauderer at embedded-brains.de> wrote:
>> ----- Ursprüngliche Mail -----
>> > Von: "Vidushi Vashishth" <reachvidu at gmail.com>
>> > An: "RTEMS Devel" <devel at rtems.org>
>> > Gesendet: Montag, 15. Januar 2018 06:17:53
>> > Betreff: Hello World patch
>> > Hi!
>> > I have the hello world patch and screenshot. Whom should I send it to?
>> > Best,
>> > Vidushi
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> Hello Vidushi,
>> I assume that you think of the patch and screenshot from the GSoC Getting
>> Started guide (https://devel.rtems.org/wiki/GSoC/GettingStarted)? In
>> that case: Quite a number of last years student's have sent that to the
>> mailing list. But I think you can also send it to Gedare Bloom directly. If
>> you send it to the list, please make sure that your screenshot isn't too
>> big. There is a size limit on the mailing list (I think around 100 or 200k)
>> and it will be delivered to a lot of people.
> Sending it to Gedare or myself is fine.
> Also there is a student tracking page at https://devel.rtems.org/wik
> i/GSoC/2018 with a table you should add yourself to. You can leave the
> project TBD for now. But we can discuss project ideas
>> It's really great that you are interested in working with us but please
>> note that you are quite early. Not everything is set up yet for GSoC2018.
>> For example a lot of wiki pages are still only updated partially. Beneath
>> that Google didn't even publish it's list of accepted organizations but we
>> had no problems in the last years so I would be quite optimistic.
>> Of course you can already start to bond with the community. If you
>> already have project ideas you should discuss them with potential mentors
>> or - if you have no idea who might could be a mentor - discuss them on the
>> mailing list. If you don't have ideas, you can take a look over
>> https://devel.rtems.org/wiki/Developer/OpenProjects.
> Christian is correct. It is quite early. We have applied and I have made a
> suggestion on what I personally think are the highest priority projects
> from an RTEMS project perspective. But that doesn't mean all have mentors
> or that someone in the community or a student doesn't have other ideas.
> My personal starting list for high priority projects was:
> + Wifi integration improvements (assuming Christian mentors)
> + aarch64 port
> + non-legacy PC support
> + coverage reporting changes and gcov support improvements
> + Eclipse target support for tracing and gdb (TCF?)
> I am sure there are other projects of merit. Those were just the ones off
> the top of my head.
> The Open Project page is a good place to start looking but some projects
> have had progress on them and others are possibly no longer relevant.
> --joel
>> Best regards
>> Christian Mauderer
>> embedded brains GmbH
>> Christian Mauderer
>> Dornierstr. 4
>> <https://maps.google.com/?q=Dornierstr.+4+%0D+D-82178+Puchheim+%0D+Germany&entry=gmail&source=g>
>> D-82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> Phone: +49-89-18 94 741 - 18
>> Fax:   +49-89-18 94 741 - 08
>> PGP: Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180117/956ca875/attachment.html>
