Hello World patch
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Jan 17 08:15:02 UTC 2018
Hello Vidushi,
I think the whole wiki is only editable for registered users. That's
true for the students table too.
Regards
Christian Mauderer
Am 17.01.2018 um 07:06 schrieb Vidushi Vashishth:
> Hello!
> I sent the patch to Gedare Bloom. The student tracking table is not
> editable yet I think. Thanks for the list of projects. I will shortly
> get back to you on which project I would contribute to.
> Best,
> Vidushi
> On Tue, Jan 16, 2018 at 3:05 AM, Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
>     On Mon, Jan 15, 2018 at 2:20 PM, Christian Mauderer
>     <christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>> wrote:
>         ----- Ursprüngliche Mail -----
>         > Von: "Vidushi Vashishth" <reachvidu at gmail.com <mailto:reachvidu at gmail.com>>
>         > An: "RTEMS Devel" <devel at rtems.org <mailto:devel at rtems.org>>
>         > Gesendet: Montag, 15. Januar 2018 06:17:53
>         > Betreff: Hello World patch
>         > Hi!
>         > I have the hello world patch and screenshot. Whom should I send it to?
>         > Best,
>         > Vidushi
>         > _______________________________________________
>         > devel mailing list
>         > http://lists.rtems.org/mailman/listinfo/devel
>         <http://lists.rtems.org/mailman/listinfo/devel>
>         Hello Vidushi,
>         I assume that you think of the patch and screenshot from the
>         GSoC Getting Started guide
>         (https://devel.rtems.org/wiki/GSoC/GettingStarted
>         <https://devel.rtems.org/wiki/GSoC/GettingStarted>)? In that
>         case: Quite a number of last years student's have sent that to
>         the mailing list. But I think you can also send it to Gedare
>         Bloom directly. If you send it to the list, please make sure
>         that your screenshot isn't too big. There is a size limit on the
>         mailing list (I think around 100 or 200k) and it will be
>         delivered to a lot of people.
>     Sending it to Gedare or myself is fine.
>     Also there is a student tracking page
>     at https://devel.rtems.org/wiki/GSoC/2018
>     <https://devel.rtems.org/wiki/GSoC/2018> with a table you should add
>     yourself to. You can leave the project TBD for now. But we can
>     discuss project ideas
>         It's really great that you are interested in working with us but
>         please note that you are quite early. Not everything is set up
>         yet for GSoC2018. For example a lot of wiki pages are still only
>         updated partially. Beneath that Google didn't even publish it's
>         list of accepted organizations but we had no problems in the
>         last years so I would be quite optimistic.
>         Of course you can already start to bond with the community. If
>         you already have project ideas you should discuss them with
>         potential mentors or - if you have no idea who might could be a
>         mentor - discuss them on the mailing list. If you don't have
>         ideas, you can take a look over
>         https://devel.rtems.org/wiki/Developer/OpenProjects
>         <https://devel.rtems.org/wiki/Developer/OpenProjects>.
>     Christian is correct. It is quite early. We have applied and I have
>     made a suggestion on what I personally think are the highest
>     priority projects from an RTEMS project perspective. But that
>     doesn't mean all have mentors or that someone in the community or a
>     student doesn't have other ideas.
>     My personal starting list for high priority projects was:
>     + Wifi integration improvements (assuming Christian mentors)
>     + aarch64 port
>     + non-legacy PC support
>     + coverage reporting changes and gcov support improvements
>     + Eclipse target support for tracing and gdb (TCF?)
>     I am sure there are other projects of merit. Those were just the
>     ones off the top of my head.
>     The Open Project page is a good place to start looking but some
>     projects have had progress on them and others are possibly no longer
>     relevant.
>     --joel
>         Best regards
>         Christian Mauderer
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
