no-preinstall: Ready for final review
Thu Jan 18 15:34:54 UTC 2018
On Thu, Jan 18, 2018 at 10:20 AM, Sebastian Huber
> I fixed the cpuopts.h problem two minutes ago.
Thanks.
I just noticed that actually when I run tester on the installed tree I
get a lot of timeouts. I'm not sure if this is my host problem.
> ----- Gedare Bloom <gedare at rtems.org> schrieb:
>> On Wed, Jan 17, 2018 at 2:24 AM, Sebastian Huber
>> > Hello,
>> > the no-preinstall branch is now in a good shape.
>> > https://git.rtems.org/sebh/rtems.git/log/?h=no-preinstall
>> > Please review this work. The next step would be to squash all commits on
>> > this branch, write a proper commit message and push it to the master.
>> Hello Sebastian,
>> I checked it out, built erc32, ran erc32 from the build, installed the
>> bsp, and ran it again fine using rtems-tools/tester.
>> However, when I try to waf-configure examples-v2, I get a problem that
>> rtems/score/cpuopts.h is not found. When I look in my installed tree,
>> I do not find the file:
>> $ find /opt/rtems-5 -name cpuopts.h
>> $ find /opt/rtems-5 -name include
>> ./sparc-rtems5/erc32/lib/include
>> I do see it in my build tree:
>> ~/work/rtems/builds/b-erc32-5$ find . -name cpuopts.h
>> ./sparc-rtems5/c/erc32/include/rtems/score/cpuopts.h
>> Relatedly, I don't see the bspopts.h file in the installed tree
>> either. I do see it in the build tree, in a different location from
>> the rest of the includes:
>> ~/work/rtems/builds/b-erc32-5$ find . -name bspopts.h
>> ./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include/bspopts.h
>> I also took a quick look through the commits, and I have a small nit.
>> Might I suggest "headers.sh" and "headers.am" instead of "header.sh"
>> and "header.am"?
>> -Gedare
>> > Sebastian Huber, embedded brains GmbH
>> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> > Phone   : +49 89 189 47 41-16
>> > Fax     : +49 89 189 47 41-09
>> > E-Mail  : sebastian.huber at embedded-brains.de
>> > PGP     : Public key available on request.
>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
