[PATCH] rtems: Remove unused configuration files.
Fri Jan 19 06:12:30 UTC 2018
The RSB policy with respect to configuration files is not clear to me. I
thought these are read-only files that will be never removed? If you
want to keep only the files used by the build sets, then why do they
have file names with a version included?
Are branches in the RSB really practical? Each time something changes
you have to back port it throughout the branches. When you build the
tools you have to specify the version. So, what is the benefit of the
branches?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
