RTEMS Tester and Log Files
Fri Jan 19 07:06:42 UTC 2018
Hello,
the RTEMS Tester works quite well if it can run the tests step by step.
I have a board were I can run reliably all tests at once with a custom
script. I cannot run tests individually due to an instability in the
debug support. This produces a large text file with the test output of
all tests. Is there an option to simply feed this file to the rtems-test
program and generate the report (optionally send it via e-mail)?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
