new to rtems , looking for some help
Jan.Sommer at dlr.de
Mon Jan 22 09:01:05 UTC 2018
Hi Vijay,
I usually start the configuration from the top level directory of rtems, but I would assume that you need to give configure the same options about which platform and BSP to build as in the normal setup.
Just running ./configure will probably not work. Check out the getting started pages of the rtems documentation to get a more detailed description on what options are available and necessary in order to start a clean build.
Best regards,
Jan
From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Vijay Kumar Banerjee
Sent: Sunday, January 21, 2018 6:34 PM
To: devel at rtems.org
Subject: new to rtems , looking for some help
Sir ,
My name is Vijay .I'm new to rtems and trying to run my hello world
when I try to run
kernel/rtems/testsuites/configure
It stops giving an error report saying
unsupported host x86_64-pc-linux-gnu.
I'm not able to understand what am I missing , when I tried to run to run hello.exe from
rtems/5/sparc-rtems/erc32/lib/rtems-5/tests .
It gives a hello world output .
please help .
Thanks
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180122/b1e1a435/attachment-0001.html>
