new to rtems , looking for some help
Tue Jan 23 15:10:15 UTC 2018
Vijay,
On Mon, Jan 22, 2018 at 4:01 AM,  <Jan.Sommer at dlr.de> wrote:
> Hi Vijay,
> I usually start the configuration from the top level directory of rtems, but
> I would assume that you need to give configure the same options about which
> platform and BSP to build as in the normal setup.
> Just running ./configure will probably not work. Check out the getting
> started pages of the rtems documentation to get a more detailed description
> on what options are available and necessary in order to start a clean build.
You may like to go through the tutorial at
https://devel.rtems.org/wiki/GSoC/GettingStarted
> Best regards,
>    Jan
> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Vijay Kumar
> Banerjee
> Sent: Sunday, January 21, 2018 6:34 PM
> To: devel at rtems.org
> Subject: new to rtems , looking for some help
> Sir ,
> My name is Vijay .I'm new to rtems and trying to run my hello world
> when I try to run
> kernel/rtems/testsuites/configure
> It stops giving an error report saying
> unsupported host x86_64-pc-linux-gnu.
> I'm not able to understand what am I missing , when I tried to run to run
> hello.exe from
> rtems/5/sparc-rtems/erc32/lib/rtems-5/tests .
> It gives a hello world output .
> please help .
> Thanks
> devel mailing list
> devel at rtems.org
