Fwd: FSF Binutils release 2.30 now available
Sat Jan 27 17:12:59 UTC 2018
I'm sure Sebastian is already on this but here is the announcement anyway.
---------- Forwarded message ----------
Date: Jan 27, 2018 10:33 AM
Subject: FSF Binutils release 2.30 now available
To: <binutils at sourceware.org>, <info-gnu at gnu.org>, <dje.gcc at gmail.com>
Cc:
Hi Everyone,
>   We are pleased to announce that version 2.30 of the Binutils project
>   sources have been released and are now available for download at:
>      https://ftp.gnu.org/gnu/binutils
>      https://sourceware.org/pub/binutils/releases/
>   This release contains numerous bug fixes, and also the
>   following new features:
>   In the assembler:
>      * Add support for location views in DWARF debug line information.
>   In the BFD linker:
>     * Add -z separate-code to generate separate code PT_LOAD segment.
>     * Add "-z undefs" command line option as the inverse of the "-z defs"
> option.
>     * Add -z globalaudit command line option to force audit libraries to
> be run
>       for every dynamic object loaded by an executable - provided that the
> loader
>       supports this functionality.
>     * Tighten linker script grammar around file name specifiers to prevent
> the use
>       of SORT_BY_ALIGNMENT and SORT_BY_INIT_PRIORITY on filenames.  These
> would
>       previously be accepted but had no effect.
>     * The EXCLUDE_FILE directive can now be placed within any SORT_*
> directive
>       within input section lists.
>   In the GOLD linker:
>     * Add support for .MIPS.options sections (MIPS only).
>     * Add support for compound relocations (MIPS only).
>     * Add --emit-stub-syms, --no-tls-optimize, --tls-get-addr-optimize
> options
>       (PowerPC only).
>     * Add -z text-unlikely-segment option.
>     * Add plugin support for adding new input files
> (LDPT_REGISTER_NEW_INPUT_HOOK).
>   In the utilities:
>     * Add --debug-dump=links option to readelf and --dwarf=links option to
> objdump
>       which displays the contents of any .gnu_debuglink or
> .gnu_debugaltlink
>       sections.
>     * Add a --debug-dump=follow-links option to readelf and a
> --dwarf=follow-links
>       option to objdump which causes indirect links into separate debug
> info files
>       to be followed when dumping other DWARF sections.
>   Our thanks go out to all of the binutils contributors, past and
>   present, for helping to make this release possible.
> Cheers
>   FSF Binutils Project
> PS. Here are the md5 checksums for the release tarballs:
>   cc47a2f256b4a593206b4d7e62a60b32  binutils-2.30.tar.bz2
>   a332503c7f72ad02f4ef624fac34c4af  binutils-2.30.tar.gz
>   e64eb5655c6c2caa78677e19c84ba5b5  binutils-2.30.tar.lz
>   ffc476dd46c96f932875d1b2e27e929f  binutils-2.30.tar.xz
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180127/a9713cff/attachment.html>
