[PATCH] 5: Update to Newlib 3.0.0 and GCC 7.3
Sebastian Huber
Fri Jan 26 14:36:14 UTC 2018
Epiphany target can now use the default build set. The or1k and m32c
targets still need special GCC versions.
rtems/config/5/rtems-default.bset | 2 +-
rtems/config/5/rtems-epiphany.bset | 11 ++---------
rtems/config/5/rtems-m32c.bset | 2 +-
rtems/config/5/rtems-or1k.bset | 2 +-
rtems/config/5/rtems-riscv32.bset | 2 +-
rtems/config/5/rtems-riscv64.bset | 2 +-
rtems/config/tools/rtems-gcc-m32c.cfg | 7 +++++++
rtems/config/tools/rtems-gcc-or1k.cfg | 7 +++++++
rtems/config/tools/rtems-gcc.cfg | 29 +++++++++++++++++++++++++++++
9 files changed, 50 insertions(+), 14 deletions(-)
create mode 100644 rtems/config/tools/rtems-gcc-m32c.cfg
create mode 100644 rtems/config/tools/rtems-gcc-or1k.cfg
create mode 100644 rtems/config/tools/rtems-gcc.cfg
diff --git a/rtems/config/5/rtems-default.bset b/rtems/config/5/rtems-default.bset
index 6f70b7c..1056e2c 100644
--- a/rtems/config/5/rtems-default.bset
+++ b/rtems/config/5/rtems-default.bset
@@ -11,7 +11,7 @@
devel/expat-2.1.0-1
tools/rtems-binutils-2.29-1
-tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1
+tools/rtems-gcc
tools/rtems-gdb-8.0.1-1
tools/rtems-tools-5-1
tools/rtems-kernel-5
diff --git a/rtems/config/5/rtems-epiphany.bset b/rtems/config/5/rtems-epiphany.bset
index 181c158..940e1d4 100644
--- a/rtems/config/5/rtems-epiphany.bset
+++ b/rtems/config/5/rtems-epiphany.bset
@@ -9,25 +9,18 @@
# Get GNU tools from external repositories.
-%define binutils_external 1
-%define gcc_external 1
%define gdb_external 1
# Expanded names of the GNU tools
-%define binutils_expand_name epiphany-binutils-gdb-b6c483b4a98424731e6e44558cb4b9863751fb1b
-%define gcc_expand_name epiphany-gcc-f7051762470c42ce7f01baa7edeb113d51c7dd72
%define gdb_expand_name epiphany-binutils-gdb-f05996c7c42e6b2781946acbab153a481ce3fd0b
# Fetch GNU tools from external repos (temporarly).
-%source set binutils https://github.com/adapteva/epiphany-binutils-gdb/archive/b6c483b4a98424731e6e44558cb4b9863751fb1b.zip
-%source set gcc https://github.com/adapteva/epiphany-gcc/archive/f7051762470c42ce7f01baa7edeb113d51c7dd72.zip
%source set gdb https://github.com/adapteva/epiphany-binutils-gdb/archive/f05996c7c42e6b2781946acbab153a481ce3fd0b.zip
-%hash sha512 f7051762470c42ce7f01baa7edeb113d51c7dd72.zip ae26ec61f90978dec724234a6c89d63a0a1437c0d9dcc2d81462199e96daa557feef0f3655b3782ea4be0b90957e677ba835e6c22166ff80e9e322307450ef3e
%hash sha256 f05996c7c42e6b2781946acbab153a481ce3fd0b.zip 2b2034fd12f2fd5108205ade66400c175ede8cef8141a38ae03fc78bf2d65325
@@ -40,7 +33,7 @@
5/rtems-autotools
devel/expat-2.1.0-1
-tools/rtems-binutils-2.23.1-1
-tools/rtems-gcc-4.9.2-newlib-2.5.0.20170922-1.cfg
+tools/rtems-binutils-2.29-1
+tools/rtems-gcc
tools/rtems-gdb-7.8.1-1
diff --git a/rtems/config/5/rtems-m32c.bset b/rtems/config/5/rtems-m32c.bset
index 34667fd..9141403 100644
--- a/rtems/config/5/rtems-m32c.bset
+++ b/rtems/config/5/rtems-m32c.bset
@@ -41,6 +41,6 @@
5/rtems-autotools
devel/expat-2.1.0-1
-tools/rtems-gcc-4.8.3-newlib-2.5.0.20170922-1
+tools/rtems-gcc-m32c
diff --git a/rtems/config/5/rtems-or1k.bset b/rtems/config/5/rtems-or1k.bset
index b4cbdec..8b20380 100644
--- a/rtems/config/5/rtems-or1k.bset
+++ b/rtems/config/5/rtems-or1k.bset
@@ -33,6 +33,6 @@
5/rtems-autotools
devel/expat-2.1.0-1
-tools/rtems-gcc-4.9.3-newlib-2.5.0.20170922-1
+tools/rtems-gcc-or1k
tools/rtems-gdb-7.11-2
diff --git a/rtems/config/5/rtems-riscv32.bset b/rtems/config/5/rtems-riscv32.bset
index 3c11da1..6ec33e8 100644
--- a/rtems/config/5/rtems-riscv32.bset
+++ b/rtems/config/5/rtems-riscv32.bset
@@ -11,6 +11,6 @@
devel/expat-2.1.0-1
+tools/rtems-gcc
diff --git a/rtems/config/5/rtems-riscv64.bset b/rtems/config/5/rtems-riscv64.bset
index c599481..57176fe 100644
--- a/rtems/config/5/rtems-riscv64.bset
+++ b/rtems/config/5/rtems-riscv64.bset
@@ -11,6 +11,6 @@
devel/expat-2.1.0-1
+tools/rtems-gcc
diff --git a/rtems/config/tools/rtems-gcc-m32c.cfg b/rtems/config/tools/rtems-gcc-m32c.cfg
new file mode 100644
index 0000000..2af4509
--- /dev/null
+++ b/rtems/config/tools/rtems-gcc-m32c.cfg
@@ -0,0 +1,7 @@
+%define gcc_version 4.8.3
+%define newlib_version 3.0.0
+%hash sha512 gcc-4.8.3.tar.bz2 2b40d231e8445f9c1654137df509f09ce1187b475138ca7f648f710d922a1718f740b2d8a37c26e16b5e27900c60358be98229ae884a6f1f70e9df44ad24d02b
+%hash sha512 newlib-3.0.0.tar.gz d4730ce9a4fc4e62052e89d20d4a3855a103b3d1a2818e94c7a68626db285aa8db8e56a684103731916bfba3e581db88e3a93264034ea0f2880ee8976283c04f
+%include tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-or1k.cfg b/rtems/config/tools/rtems-gcc-or1k.cfg
index 0000000..902e471
--- /dev/null
+++ b/rtems/config/tools/rtems-gcc-or1k.cfg
@@ -0,0 +1,7 @@
+%define gcc_version 4.9.3
+%hash sha512 gcc-4.9.3.tar.bz2 9ac57377a6975fc7adac704ec81355262b9f537def6955576753b87715470a20ee6a2a3144a79cc8fcba3443f7b44c7337d79d704b522d053f54f79aa6b442df
+%include tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg
diff --git a/rtems/config/tools/rtems-gcc.cfg b/rtems/config/tools/rtems-gcc.cfg
index 0000000..4376a08
--- /dev/null
+++ b/rtems/config/tools/rtems-gcc.cfg
@@ -0,0 +1,29 @@
+%include %{_configdir}/checks.cfg
+%include %{_configdir}/base.cfg
+%define gcc_version 7.3.0
+%define mpfr_version 3.1.4
+%define mpc_version 1.0.3
+%define gmp_version 6.1.0
+# FreeBSD specific fix for MIPS
+%if %{_build_os} == freebsd || %{_build_os} == darwin
+ %patch add gcc --rsb-file=freebsd-libgcc-sed-fix.patch -p0 https://gcc.gnu.org/bugzilla/attachment.cgi?id=41380
+ %hash sha256 freebsd-libgcc-sed-fix.patch 8a11bd619c2e55466688e328da00b387d02395c1e8ff4a99225152387a1e60a4
+%endif
+%hash sha512 gcc-7.3.0.tar.xz ad41a7e4584e40e92cdf860bc0288500fbaf5dfb7e8c3fcabe9eba809c87bcfa85b46c19c19921b0cdf6d05483faede8287bb9ea120c0d1559449a70e602c8d4
+%hash sha512 mpfr-3.1.4.tar.bz2 51066066ff2c12ed2198605ecf68846b0c96b548adafa5b80e0c786d0df488411a5e8973358fce7192dc977ad4e68414cf14500e3c39746de62465eb145bb819
+%hash sha512 mpc-1.0.3.tar.gz 0028b76df130720c1fad7de937a0d041224806ce5ef76589f19c7b49d956071a683e2f20d154c192a231e69756b19e48208f2889b0c13950ceb7b3cfaf059a43
+%hash sha512 gmp-6.1.0.tar.bz2 3c82aeab9c1596d4da8afac2eec38e429e84f3211e1a572cf8fd2b546493c44c039b922a1133eaaa48bd7f3e11dbe795a384e21ed95cbe3ecc58d7ac02246117
+%define with_threads 1
+%define with_plugin 0
+%define with_iconv 1
+%include %{_configdir}/gcc-7.2-1.cfg
2.9.2
