Build Failures on Master
    Sebastian Huber
    Wed Jan 31 11:09:38 UTC 2018
On 27/01/18 23:49, Joel Sherrill wrote:
> Hi
> This bsp builder test report shows about 25 build failures.
> https://lists.rtems.org/pipermail/build/2018-January/000333.html
The problems seem to be an issue with the BSP builder:
../configure --target=powerpc-rtems5 --enable-rtemsbsp=qoriq_e6500_64 ss555
configure: WARNING: you should use --build, --host, --target
configure: loading site script /usr/share/site/x86_64-unknown-linux-gnu
checking for gmake... gmake
checking for RTEMS Version... 5.0.0
checking build system type... Invalid configuration `ss555': machine
`ss555' not recognized
configure: error: /bin/sh /home/EB/sebastian_h/git-rtems/./config.sub
ss555 failed
On powerpc only the qoriq and t32mppc BSPs support SMP. How does the BSP
builder know that SMP is supported for a particular BSP?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
