Build Failures on Master
Wed Jan 31 11:40:39 UTC 2018
On 31/01/18 12:09, Sebastian Huber wrote:
> On 27/01/18 23:49, Joel Sherrill wrote:
>> Hi
>> This bsp builder test report shows about 25 build failures.
>> https://lists.rtems.org/pipermail/build/2018-January/000333.html
> The problems seem to be an issue with the BSP builder:
> ../configure --target=powerpc-rtems5 --enable-rtemsbsp=qoriq_e6500_64
> ss555
> configure: WARNING: you should use --build, --host, --target
> configure: loading site script /usr/share/site/x86_64-unknown-linux-gnu
> checking for gmake... gmake
> checking for RTEMS Version... 5.0.0
> checking build system type... Invalid configuration `ss555': machine
> `ss555' not recognized
> configure: error: /bin/sh /home/EB/sebastian_h/git-rtems/./config.sub
> ss555 failed
The above is one issue. The below is another issue.
> On powerpc only the qoriq and t32mppc BSPs support SMP. How does the
> BSP builder know that SMP is supported for a particular BSP?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
